  3. OpenHab with smart door lock
8 Posts 4 Posters 6.6k Views 3 Watching
  • J
    J
    jemish
    Have any one tried to OPEN and CLOSE the door using openhab.
    I want to make smart door lock and setup in at my home.
    • greglG
      greglG
      gregl
      What door lock?
      If its zwave then I don't think OpenHab can do it as zwave locks have some encryption or similar.
      Or are you wanting to use MySensors with a standard electric door strike?? In which case, have a look at one of the various "Garage Door" sketches. This should be a good base for driving a door strike... probably just change the period that the lock is disabled.
      • J
        J
        jemish
        I seen this type of electric door lock, but I looking for lock will control through openhab mysensore as well as lock mechanical key also.
        link text
        • J
          J
          jemish
          any one know any other door lock
          SparkmanS 1 Reply Last reply
          • T
            TimO
            I own a door with: http://www.fuhr.de/fuhr/en/produkte/prod_tuer_881.php
            According to the manual it is pretty easy to connect it to a MySensor node, but I don't think it is easy to upgrade your door with this lock and it is expensive too. ;-)
            • J jemish
              SparkmanS
              SparkmanS
              Sparkman
              @jemish How about something like this: https://www.sparkfun.com/products/13648. It's to be used with a standard deadbolt / keys.
              Cheers
              Al
              • J
                J
                jemish
                I required door lock that can work with mysensore
                • greglG
                  greglG
                  gregl
                  @jemish ,
                  There are thousands of locks out there which can be controlled by electricity - several examples have already been given to you.
                  Why dont you go and research the hardware lock you think will work for you and your door and come back here with the link to it, and we can help you to control it with mySensors.
