  2. Enclosures / 3D Printing
  3. Project boxes for MySensor's nodes and gateway?
31 Posts 19 Posters 28.9k Views 18 Watching
  • NeverDieN Offline
    NeverDieN Offline
    Starting a separate thread here to continue the discussion started there: http://forum.mysensors.org/topic/1731/best-platform-currently-for-running-rfm69hw/37
    It's a chicken-and-egg problem. I can't pick a project box out of thin air, because I need to know the PCB dimensions and whether it will fit well inside the project box. Yet, ideally, an easily available and inexpensive project box would be known in advance, and the PCB could be optimized to fit within it.
    Anyone thought ahead to the end game and maybe already has an answer?
    As a starting point, on Ebay, perhaps some might be:
    http://www.ebay.com/itm/Hot-DIY-Electronics-Plastic-Project-Box-Enclosure-Case-Waterproof-IP66-/321487958642?hash=item4ada2cf272
    http://www.ebay.com/itm/85x58x33mm-Waterproof-Cover-Clear-Plastic-Electronic-Project-Box-Enclosure-CASE-/281390875149?hash=item418434020d
    In the above, I happened to search for something waterproof, so it can be used indoors and outdoors and therefore have maximum applicability. Feel free to disagree with that presumption if you wish.
    Depending on how it's powered, even smaller might be even better. If you assume it's battery powered, it would probably cover the scenario where it isn't.
    SparkmanS 1 Reply Last reply
      SparkmanS Offline
      SparkmanS Offline
      Sparkman
      wrote on last edited by Sparkman
      @NeverDie I use an assortment of cases and still looking for others for some sensors I have built. To be honest, I think that finding the right case is the hardest part of the MySensors system :D
      For my gateway, I used this box: http://imall.itead.cc/project-case-white-and-black-110-80-25mm.html. It's a tight squeeze with the Uno and NRF24L01+ PA/LNA along with a small proto board to mount the LEDs. A smaller Arduino would fit better, but I used an Uno clone to ensure enough power for the PA/LNA module. I had to remove the Uno headers in order for it to fit as the headers were interfering with the circuit board for the LEDs. I'll open it up and take some pics.
      I've been looking at these cases for indoor battery powered sensors. They are a good price, but are only in inventory in the UK, so shipping is $25 for any quantity, so I'll have to do a large enough order to minimize the shipping cost per unit.
      Al
      • C Offline
        C Offline
        chickey
        wrote on last edited by chickey
        I stumbled on a youtube video where he used a project box with a pcb designed for the box which i thought could be pretty handy
        http://www.ebay.co.uk/itm/ABS-Project-Box-Cases-Lids-Matrix-Boards-5pk-300651-/121366415075?hash=item1c420086e3
        Anyone tried these?
        Edit: This was the youtube vid https://www.youtube.com/ watch?v=e1y4IG6YSoc&list=WL&index=16
        Oh and does anyone know a source for the box shown above in the UK or someone that ships to the UK for reasonable costs. i looked on ebay but couldn't see any.
        • C chickey
          Anyone tried these?
          NeverDieN Offline
          NeverDieN Offline
          Anyone tried these?
          Edit: This was the youtube vid https://www.youtube.com/watch?v=e1y4IG6YSoc&list=WL&index=16
          The video doesn't play. It keeps saying: "An error occurred. Please try again later."
          C 1 Reply Last reply
          • L Offline
            L Offline
            LastSamurai
            Waho that box looks great ("router style"). Does anyone know a source thats available form germany? (also ebay/aliexpress).
            The video isn't working for me either.
              Anyone tried these?
              C Offline
              C Offline
              chickey
              @NeverDie For some reason it keeps auto converting the link but as you pointed out it doesn't then work! I've put a space in so you can see the url, you'll need to copy and paste but then remove the space. If anyone knows why it won't work when linked normally i'd love to know :-)
              • TD22057T Offline
                TD22057T Offline
                TD22057
                I ordered one of these boxes a few weeks ago (hasn't arrived yet). My requirements:
                1. looks nice - will be mounted where it's visible.
                2. reasonably deep - I'm planning on using external mini xlr connectors for things which require a 12 mm hole.
                3. side wall on either the top or the bottom piece (see 2) - if it's split in 1/2 some boxes, it's harder to mount connectors.
                4. big enough for a custom PCB with 4-5 JST style connectors
                The box I ordered is a reasonable match. The thing I don't like about it is that the top of the box is the deep part (the back part is thin - like a lid). I'd like to mount a PCB into the box, then mount external connectors into the box sides, then wire the connectors to the PCB. In the box I ordered, the PCB would be on the top (outside) of the box. That makes it a lot harder/impossible to add switches, LED's, or a display to the front of the box. It's not a deal breaker, but if I could find a box that was like the one I ordered but where the top and bottom thickness dimensions were reversed, that would be nice.
                I was really hoping I could find a single box that worked everywhere (including outside) so I could design a single PCB (or a few variations) for the various projects I want to build. So far that's looking unlikely...
                • K Offline
                  K Offline
                  kalle
                  @LastSamurai
                  http://www.ebay.de/sch/i.html?_from=R40&_trksid=p2057872.m570.l1313.TR2.TRC1.A0.H0.Xkemo+gehäuse.TRS0&_nkw=kemo+gehäuse&_sacat=0
                  • L LastSamurai
                    C Offline
                    C Offline
                    chickey
                    @LastSamurai http://www.ebay.co.uk/itm/215-Router-Shell-Network-Communication-Plastic-Project-Case-Box-160x100x30mm-/171579990253?_trksid=p2141725.m3641.l6368
                    • L Offline
                      L Offline
                      LastSamurai
                      The youtube link still doen't work for me though. I am just getting the youtube landing page
                      • L LastSamurai
                        C Offline
                        C Offline
                        chickey
                        @LastSamurai you need to paste in the test after the link onto the end of the url. Else search for "Scullcom Hobby Electronics #14 - GPS System with Arduino Mini & OLED Display" in youtube.
                        • M Offline
                          M Offline
                          mvdarend
                          wrote on last edited by mvdarend
                          The Custom Enclosure Factory on AliExpress has some nice cases.
                          And for a ghetto option, I've got a few old Mentos chewing gum containers around the place :) (This one is stuck to the side of the Central heating unit with magnets. WIN_20150919_11_00_45_Pro.jpg
                          • A Offline
                            A Offline
                            ahhk
                            i will make my own cases for my 25x50 boards with 2xAA....see => http://forum.mysensors.org/topic/1901/my-own-board-50mm-x-24mm/18
                            • D Offline
                              Dheeraj
                              My compact serialGateway with nrf201 long range , power indicator LED and USB cable connected to Pi.IMG_20150922_200826.jpg
                              • GertSandersG Offline
                                GertSanders
                                @Dheeraj: Where did this case come from ? Was the board inside custom made or pro mini ?
                                D 1 Reply Last reply
                                • D Offline
                                  Dalhoj
                                  This is my gateway.
                                  J 1 Reply Last reply
                                  • epierreE Offline
                                    epierreE Offline
                                    epierre
                                    My Gateway:
                                    A Gateway and a node for a friend:
                                    Comparison of the MysenSor and the famous RFXTRX:
                                    And the solar powered+LiPo water proof box:
                                    z-wave - Vera -> Domoticz
                                    K 1 Reply Last reply
                                    • NeverDieN Offline
                                      NeverDieN Offline
                                      I'm starting to think I'll need a 3D printer after all.... Any recommendations on which one to get?
                                      barduinoB 1 Reply Last reply
                                      • epierreE epierre
                                        My Gateway:
                                        K Offline
                                        K Offline
                                        koen01
                                        @epierre said:
                                        My Gateway:
                                        What kind of box is that? Do you have a link where i can order these?
                                        epierreE 1 Reply Last reply
                                          barduinoB Offline
                                          barduinoB Offline
                                          barduino
                                          @NeverDie Ihave one of these and im very happy with it
                                          11.9k
                                          113.3k
