[Tutorial] openHAB with serial gateway
A 2.0 binding would be great. How far did you get?
Last time I've tested Openhab 2.0 there were some (well known) serious bugs and it still is only an alpha version. An MySensors binding for Openhab would be really cool and I will give it a try, but not for the 1.X Version, because of the lack of autodiscovery mechanisms in Openhab itself and because I think it is a little bit too early for Openhab 2.0.
@TimO ok 2.0 alpha...
An idea for 1.x; Ready-Discovery ?
We write 250 mysensors items like ID=1-30 for switches, 31-50 for contacts, 51-70 for motion etc... if item is available then sitemap will show them.Is there anyway to create rules on frontend? Maybe IFTTT + MySensors goes well..
Hi
Please check this http://forum.mysensors.org/topic/1543/universal-gateway-for-315-433mhz-devices/2
Is there anyway to use directly 433 with openhab --- serial gateway will be 433 receiver and transmitter (without mysensors lib and devices)
hi,
just wanted to ask if anybody developed l154 work here http://forum.mysensors.org/topic/655/serial-gateway-connection-to-openhab/31? any arduino code for the node point with a few relays and a few sensors?
thanks! -
How to I add I_BATTERY_LEVEL to the openhab rules? Being internal I wasnt sure if hashmap would do it.
Something like this? Where Item is NodeX_Batt
// Internal Command if(msgType == 3){ if(subType == I_BATTERY_LEVEL){ postUpdate("Node" + nodeId + "_Batt, msg) println("Node" + nodeId + "_Batt:" + msg) }} -
This is a BRILLIANT tutorial. Up and running with a single temp/humidity node in minutes. Thanks so much.
I built a second node (identical simple DHT22 temp/humidity) and set the Node-id to 110. I'm just wondering how to add the second node into OpenHAB? I have confirmed that openhab is receiving the signals from the second node correctly, but not quite sure about the OpenHAB rules, sitemap and items configs for a second node - that is identical in every way save for the Node ID and different item names. I've simply duplicated all of the code in the relevant config files, changed the item names and added four extra lines to the mapping to map the second 110 node. When I do this I get no data from either of the nodes. If I comment out my changes, I get the values from my first node just fine.
Can anyone with multiple nodes post a link to their configs so I can see what I might be doing wrong? Cheers.
Scratch that...I figured it out. In the rules file, I needed to add a extra comma after the first chunk of mapping. As it stood, I presume it failed to process the whole rule, as there was a syntax error (missing comma) which mean't the 'list' of mappings were incomplete. Added a comma and all was right once again. :)
Hi guys,
I'm running in an interesting issue here, posting to see where I'm missing a step.
I have a Serial Gateway, connected to openHAB and working without issue. I see messages from the arduino Monitor and I can see the messages in openHAB without issue.
I'm running openHAB on Raspberry PI. arduino connected to PI by USB (on serial port /dev/ttyUSB0) declared as below:
String itmSensor_gateway_rawmessage { serial="/dev/ttyUSB0@115200" }The problem that I'm facing is related to the parse process ( I think ).
Message sent from my node:
send: 124-124-0-0 s=0,c=1,t=1,pt=7,l=5,sg=0,st=ok:32.0with this code:
This is the section of the arduino sketch that I'm using to send the Humidity status:float humidity = dht.getHumidity(); if (isnan(humidity)) { Serial.println("Failed reading humidity from DHT"); } else if (humidity != lastHum) { lastHum = humidity; gw.send(msgHum.set(humidity, 1)); Serial.print("H: "); Serial.println(humidity); numAttemptsHum = 0; } else { Serial.print("Attempt "); Serial.print(numAttemptsHum); Serial.print("/"); Serial.print(MAX_NUM_ATTEMPTS_HUM); Serial.print(" - Same Humidity level presented"); Serial.print(" (Previous:"); Serial.print(lastHum); Serial.print(" vs Current: "); Serial.print(humidity); Serial.println(") - not sending"); numAttemptsHum ++; if ( numAttemptsHum > MAX_NUM_ATTEMPTS_HUM ) { lastHum = 0; numAttemptsHum = 0; } }(it's based on the Humidity & Temp example with minor changes to avoid traffic witout reducing the sampling frequency but with consistent updates based on a specific threshold.).
Message received in openHAB:
13:27:54.142 [DEBUG] [b.serial.internal.SerialDevice:194 ] - Received message '0;0;3;0;9;read: 124-124-0 s=0,c=1,t=1,pt=7,l=5,sg=0:31.0 ' on serial port /dev/ttyUSB0So at this point I see that all messages are type 3 ( not 1 as in the above example ).
That message updates my openHAB item, as per this example I have a rule that descompose the original message ( no modifications done yet to the one posted here ).
So, when I finally get to the core msg ( the one that in this example is directly assigned to the openHAB item ) the value is:
124-124-0 s=0,c=1,t=1,pt=7,l=5,sg=0:31.0instead of the 31.0 that I was expecting.
Any ideas?
(happy to provide more sections of code if needed, didn't want to put everyting here to avoid garbage)
Thanks in advance for any help.
@Dave-Dan
0;0;3 means a debug message.. you can throw these away. Shouldn't be processed by your controller. -
Ok cool.
That means that I'm doing something else wrong bc I still see that part after disabling DEBUG.I'm curious on why having the same sketch + openHAB rule from thia thread I xan make it work ...
Will review carefully because sounds weird for me.
Thanks!!!!
Hi TimO,
I want to make a permanent USB setting for my Radberry and I follow your tutorial here.
In my etc/udev/rules.d I have two documents: 40-scratch.rules and 99-input.rules and I don't know where to make the needed modifications as you show in this tutorial.
The file you point to make the modifications has another name and I can't figure where to add the vendor, product and serial no for my arduino. Shall I make a new file called 99-usb-serial.rules and to write in it the ATTRS{idVendor} and the rest of them according to my dmesg as you say here above or to do that in one of the two files I have?
Thanks! -
Hi! Can somebody please help here? I got stuck with my openhab server on my raspberry!
By now I was starting the server by:Sudo /opt/openhab/start.shBut I wanted more, to make it auto start on reboot so in case of power failure to auto start when the power is back. Therefore I followed some tutorials found on the www and I got it done, now the server starts alone but I cannot do anything from web page or from my phone. I also can't see the temp and humidity on the web or phone!
The question is how to stop this server? I tried different commands found on the internet but non of them can stop this invincible server I have lunched :)
I tried to stop it, remove, delete... Nothing works!
Is there any way to remove everything from my raspberry pi and to start it all over again with all the installation as for windows ? Format the partition, install the noobs again and so on?
Thanks. -
udev: Just create the new file if it is not there yet. It should be processed automatically.
The best way to start a service in Linux is using an etc-script. You will find an example here: https://github.com/openhab/openhab/wiki/Samples-Tricks#how-to-configure-openhab-to-start-automatically-on-linux
The script will start OpenHab at boot and you're able to start/stop/restart with/etc/init.d/openhab start or service openhab start
I'm having issues getting the ttyUSB99 fix to work.
I'm running openhab 1.7.1 and it was installed using apt-get.
My dmseg output looks like this[10167.765598] usb 1-1.2: USB disconnect, device number 4 [10167.766311] ch341-uart ttyUSB0: ch341-uart converter now disconnected from ttyUSB0 [10167.766407] ch341 1-1.2:1.0: device disconnected [10171.843803] usb 1-1.2: new full-speed USB device number 5 using dwc_otg [10171.946998] usb 1-1.2: New USB device found, idVendor=1a86, idProduct=7523 [10171.947025] usb 1-1.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0 [10171.947042] usb 1-1.2: Product: USB2.0-Serial [10171.948288] ch341 1-1.2:1.0: ch341-uart converter detected [10171.952514] usb 1-1.2: ch341-uart converter now attached to ttyUSB0As you can see there is no SerialNumber here, but I found it using
pi@raspberrypi ~ $ udevadm info -a -n /dev/ttyUSB0 | grep '{serial}' | head -n1 ATTRS{serial}=="3f980000.usbSo I created a rules file looking like this:
pi@raspberrypi ~ $ cat /etc/udev/rules.d/99-usb-serial.rules SUBSYSTEM=="tty", ATTRS{idVendor}=="1a86", ATTRS{idProduct}=="7523", ATTRS{serial}=="3f980000.usb", SYMLINK+="ttyUSB99"I have disconnected and reconnected my gateway.
But starting openhab now just results in the following error:2015-09-20 09:24:48.867 [ERROR] [i.internal.GenericItemProvider] - Binding configuration of type 'serial' of item ?Arduino? could not be parsed correctly. org.openhab.model.item.binding.BindingConfigParseException: Could not open serial port /dev/ttyUSB99: Serial port '/dev/ttyUSB99' could not be found. Available ports are: /dev/ttyUSB0What can I do to resolve this?
Eventually solved it by just omitting SerialNumber, i.e.
SUBSYSTEM=="tty", ATTRS{idVendor}=="1a86", ATTRS{idProduct}=="7523", ATTRS{serial}=="3f980000.usb", SYMLINK+="ttyUSB99I guess that could cause problems if I would attached more similar devices to my RPI, but I don't know if there is any point in having more than one gateway? (unless you have > 255 sensors I guess)
I am new with mysensors and i am trying to make it work with openhab.
I have a soil sensor and with same copy paste from the forum i manage to sent the value on the openhab, now i am trying to translate the battery level on the opnehab side but i dont know how to do it. can someone help me please?? this is what i get on the openhab 0;0;3;0;9;read: 254-254-0 s=255,c=3,t=0,pt=1,l=1,sg=0:68
254;255;3;0;0;68 this is the battery value.
But i am lost on the rule how to decode the message.Thanks
Nikos -
I also would like to share my working
default.rules+ examples with you. Hope it can help someone.
