  3. sensors in boxes
sensors in boxes
57 Posts 11 Posters 44.1k Views 16 Watching
  • Moshe LivneM Moshe Livne
    @GuyP PCB arrived from oshpark!
    What capacitors did you use for the crystal? and what resistor for the dallas?
    mntlvrM
    mntlvrM
    mntlvr
    What is the name for this board on OSHpark? I would like to order 3 of these boards myself
    • mntlvrM mntlvr
      Moshe LivneM
      Moshe LivneM
      Moshe Livne
      @mntlvr don't use this as it has shorts. Use the corrected one someone posted a few comments back
      mntlvrM 1 Reply Last reply
        mntlvrM
        mntlvrM
        mntlvr
        wrote on last edited by mntlvr
        #50
        Thanks Moshe-Livne but I can't find any comments on this posting about anyone buying boards that work can you help with this or is it best just to make your own?
        • mntlvrM mntlvr
          Moshe LivneM
          Moshe LivneM
          Moshe Livne
          Just upload the brd file pjeterinfo posted
          • P
            P
            pjeterinfo
            Use it on your own risk, it's nog yet arrived and thus not tested ;-)
            • P pjeterinfo
              Moshe LivneM
              Moshe LivneM
              Moshe Livne
              @pjeterinfo I still need to cut the traces on mine....
              • P
                P
                pjeterinfo
                All parts received and programmed using a pro mini, man that's frustrating ;-) . But works great..
                • G
                  G
                  gonzalonal
                  Nice little board.
                  Do you know how long does the dallas temp sensor keeps working on?
                  I ask this because its minumun supply voltage is 3.0V and you are feeding the board exactly with that.
                  So, what happens when the battery voltage get a bit below 3.0V?
                  Thanks, regards.
                  • P
                    P
                    pjeterinfo
                    @gonzalonal We'll see, I have setup datamine for this sensor in Vera.
                    • 5546dug5
                      5546dug5
                      5546dug
                      @GuyP many posts ago you guided @Moshe-Livne to arduino cc/ file for downloading the bootloader files but I see only the files for 168 DIP and not 328P
                      Do I use the 168p file?
