  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 657.0k Views 35 Watching
    Yes, it should.
    But as @Dewalt says, there was a bug in repeater functionality. So upgrading the repeater is a good tip.
    • J
      J
      johnr
      Upgrading repeater to 1.5 solved this issue. Thanks for the quick help. 1.4 sensors communicate OK with the 1.5 repeater as far as I can see right now.
      • F
        F
        Fabien
        I try to make a 3D box for SenseBender Micro with CR123 battery.
        Screenchot :
        • F
          F
          Fabien
          first print test : IMG_20150921_230740.jpg
          • tbowmoT
            tbowmoT
            tbowmo
            @Fabien
            Nice work, what is the dimensions of the enclosure?
              mvader
              @mvader said:
              question about the default sketch for this board.
              if i read correctly
              // How many milli seconds should we wait for OTA?
              #define OTA_WAIT_PERIOD 300
              #define FORCE_TRANSMIT_INTERVAL 30
              if temps don't change more than .5 i shouldn't see a transmit but once every 30 minutes
              i have 2 running right now
              and both send temp and humidity every 1-2 minutes and the numbers are the same or in some cases only different by .1
              i have it set to .5 so the question is
              1. why does it transmit every minutes when the temp and humidity are the same
              2. why is it transmitting even with as little as .1 change
                1 board is running 1.2 and the other is running the 1.3 sketch from git
                Battery however does transmit every 60 minutes as it's supposed to.,
                thx
              • tbowmoT
                tbowmoT
                tbowmo
                @mvader
                Have you tried to hook up a serial connection to your sensebender? It writes the difference from the last transmitted measurement, everytime a new measurement is taken (every minute).
                • F
                  F
                  Fabien
                  @tbowmo 47x37 height : 27
                  I will make some improvment (can not test, my printer is in maintenance mode !) and post files for others.
                  • tbowmoT tbowmo
                    @mvader
                    mvader
                    @tbowmo said:
                    @mvader
                    so if i want it to transmit less frequently (save battery?) i would increase the measure interval. correct?
                    I have some situations where i want frequent measuring (1 minute), and some where 15 minutes or 30 minutes would do fine.
                    • tbowmoT
                      tbowmoT
                      tbowmo
                      @mvader
                      Yes, you could save battery, by changing to 10/15 minute check interval..
                      But still, the interesting thing is why it transmits every minute.. That's why I would suggest to check the serial output..
                      • G gloob
                        Hello
                        needs to be replaced with
                        korttomaK
                        korttomaK
                        korttoma
                        #272
                        There is an explanation to the problem further up in the thread:
                        @gloob said:
                        Hello
                        • Tomas
                        • tbowmoT
                          tbowmoT
                          tbowmo
                          @korttoma
                          thanks for helping my memory :)
                          • korttomaK korttoma
                            @gloob said:
                            Hello
                            mvader
                            @korttoma i did see that. but your saying that is what is causing it to transmit every 1 minute?
                            korttomaK 1 Reply Last reply
                            • M mvader
                              korttomaK
                              korttomaK
                              korttoma
                              @mvader yes, it is rounding the temperature difference to the nearest degree so the difference is almost always more then the 0.5.
                              • Tomas
                              • tbowmoT
                                tbowmoT
                                tbowmo
                                Just a hint, itead studio is starting a sale with 10% off on all imall items.. So maybe it's time to buy some Christmas presents for the inner geek :)
                                • A
                                  akbooer
                                  Oh no! Lousy timing, I just bought some...
                                  ... in fact, they arrived today.
                                  Speaking of which, whilst I got them to run the default sketch, do I actually need a programmer to do anything different, or can this be done OTA (from a Mac) ?
                                  • tbowmoT
                                    tbowmoT
                                    tbowmo
                                    @akbooer
                                    The default sketch doesn't support OTA, as it wasn't available in the stable branch at the time of launch
                                    • 5546dug5
                                      5546dug5
                                      5546dug
                                      @tbowmo Good sales but did not see the Sensebender too bad .
                                      • tbowmoT
                                        tbowmoT
                                        tbowmo
                                        @akbooer
                                        It's here http://www.itead.cc/mysensors-micro.html
                                        • epierreE
                                          epierreE
                                          epierre
                                          #281
                                          @hek I've soldered a second unit to compare, same error, I flashed back the sensebender version from the examples and on both I am stuck here: "Sensebender Micro FW 1.2radio init fail"
                                          Gateway is 1.5 BTW, one radio is from itead the other not.
                                          z-wave - Vera -> Domoticz
