  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 657.0k Views 35 Watching
  • J johnr
    My sense bender works perfect when sending directly data directly to serial gateway (vera 5), however when I move it out of range to the serial gateway and want it to connect to my repeater node it does not want to discover the repeater node. Anyone else had this problem?
    DwaltD
    DwaltD
    Dwalt
    @johnr
    Is your repeater node still on MySensors 1.4? I had a similar problem and upgrading to 1.5 solved it.
    • J
      J
      johnr
      You are probably right. I did not realise sense bender was pre loaded with 1.5
      I think easiest for me would be to downgrade sense bender to 1.4 is it possible?
      • tbowmoT
        tbowmoT
        tbowmo
        Sensebender is still on 1.4, as we haven't prepared new firmware for it yet.
        Mysensors 1.4 and 1.5 should be compatible with each other, right @hek ?
          Yes, it should.
          But as @Dewalt says, there was a bug in repeater functionality. So upgrading the repeater is a good tip.
          • J
            J
            johnr
            Upgrading repeater to 1.5 solved this issue. Thanks for the quick help. 1.4 sensors communicate OK with the 1.5 repeater as far as I can see right now.
            • F
              F
              Fabien
              I try to make a 3D box for SenseBender Micro with CR123 battery.
              Screenchot :
              • F
                F
                Fabien
                first print test : IMG_20150921_230740.jpg
                • tbowmoT
                  tbowmoT
                  tbowmo
                  @Fabien
                  Nice work, what is the dimensions of the enclosure?
                    mvader
                    @mvader said:
                    question about the default sketch for this board.
                    if i read correctly
                    // How many milli seconds should we wait for OTA?
                    #define OTA_WAIT_PERIOD 300
                    #define FORCE_TRANSMIT_INTERVAL 30
                    if temps don't change more than .5 i shouldn't see a transmit but once every 30 minutes
                    i have 2 running right now
                    and both send temp and humidity every 1-2 minutes and the numbers are the same or in some cases only different by .1
                    i have it set to .5 so the question is
                    1. why does it transmit every minutes when the temp and humidity are the same
                    2. why is it transmitting even with as little as .1 change
                      1 board is running 1.2 and the other is running the 1.3 sketch from git
                      Battery however does transmit every 60 minutes as it's supposed to.,
                      thx
                    • tbowmoT
                      tbowmoT
                      tbowmo
                      @mvader
                      Have you tried to hook up a serial connection to your sensebender? It writes the difference from the last transmitted measurement, everytime a new measurement is taken (every minute).
                      • F
                        F
                        Fabien
                        @tbowmo 47x37 height : 27
                        I will make some improvment (can not test, my printer is in maintenance mode !) and post files for others.
                        • tbowmoT tbowmo
                          @mvader
                          mvader
                          @tbowmo said:
                          @mvader
                          so if i want it to transmit less frequently (save battery?) i would increase the measure interval. correct?
                          I have some situations where i want frequent measuring (1 minute), and some where 15 minutes or 30 minutes would do fine.
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            @mvader
                            Yes, you could save battery, by changing to 10/15 minute check interval..
                            But still, the interesting thing is why it transmits every minute.. That's why I would suggest to check the serial output..
                            • G gloob
                              Hello
                              needs to be replaced with
                              korttomaK
                              korttomaK
                              korttoma
                              #272
                              There is an explanation to the problem further up in the thread:
                              @gloob said:
                              Hello
                              • Tomas
                              • tbowmoT
                                tbowmoT
                                tbowmo
                                @korttoma
                                thanks for helping my memory :)
                                • korttomaK korttoma
                                  @gloob said:
                                  Hello
                                  mvader
                                  @korttoma i did see that. but your saying that is what is causing it to transmit every 1 minute?
                                  korttomaK 1 Reply Last reply
                                  • M mvader
                                    korttomaK
                                    korttomaK
                                    korttoma
                                    @mvader yes, it is rounding the temperature difference to the nearest degree so the difference is almost always more then the 0.5.
                                    • Tomas
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      Just a hint, itead studio is starting a sale with 10% off on all imall items.. So maybe it's time to buy some Christmas presents for the inner geek :)
                                      • A
                                        akbooer
                                        Oh no! Lousy timing, I just bought some...
                                        ... in fact, they arrived today.
                                        Speaking of which, whilst I got them to run the default sketch, do I actually need a programmer to do anything different, or can this be done OTA (from a Mac) ?
                                        • tbowmoT
                                          tbowmoT
                                          tbowmo
                                          @akbooer
                                          The default sketch doesn't support OTA, as it wasn't available in the stable branch at the time of launch
