  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 658.9k Views 35 Watching
    @epierre said:
    is that because I don't have a 1.5 serial gateway ?
    Gateway version shouldn't matter if you get this message at startup of node.
    I have the socket and the FTDI on the same side so I may avoid the above ?
    I don't understand what you mean.
    epierreE
    epierreE
    epierre
    what should I do from there ?
    this was related to the electric perturbation with headers close to the radio
    z-wave - Vera -> Domoticz
    SparkmanS 1 Reply Last reply
    • epierreE epierre
      SparkmanS
      SparkmanS
      Sparkman
      @epierre Can you confirm the settings you used in the IDE to program it? Are you sure there are no solder bridges where you soldered the radio or socket for the radio? Have you tried powering it with a couple of AA batteries after you uploaded the sketch?
      Al
      epierreE 1 Reply Last reply
      • HeinzH
        HeinzH
        Heinz
        Today I integrated my first 2 sensebender micros into my homeautomation and they almost worked out of the box. I like this board really much! Good work, I will order more!
        Pitfall:
        When updating the mysensors lib from 1.4.x to 1.5 the sensor failed to get an id from the controller which btw was still running on 1.4.x.
        After having done all the things like "clearing eeprom", "soldering a capacitor to the radio" and so on... I noticed that I changed the RF_CHANNEL from the default 76 to some other value in MyConfig.h some months ago (probably for some paranoia reason).
        When updating to lib 1.5 the sensor sketch got the 76 while the gateway still used the other one and so the communication between both failed. After changing the radio channel to the one the controller uses, everything worked very quickly!
        Probably this post helps someother guy who fell into the same trap.
        • J
          J
          johnr
          My sense bender works perfect when sending directly data directly to serial gateway (vera 5), however when I move it out of range to the serial gateway and want it to connect to my repeater node it does not want to discover the repeater node. Anyone else had this problem?
          DwaltD 1 Reply Last reply
            Remember that it takes a few ( ~5) failed transmits until it searches for a new parent node.
            • J johnr
              DwaltD
              DwaltD
              Dwalt
              @johnr
              Is your repeater node still on MySensors 1.4? I had a similar problem and upgrading to 1.5 solved it.
              • J
                J
                johnr
                You are probably right. I did not realise sense bender was pre loaded with 1.5
                I think easiest for me would be to downgrade sense bender to 1.4 is it possible?
                • tbowmoT
                  tbowmoT
                  tbowmo
                  Sensebender is still on 1.4, as we haven't prepared new firmware for it yet.
                  Mysensors 1.4 and 1.5 should be compatible with each other, right @hek ?
                    Yes, it should.
                    But as @Dewalt says, there was a bug in repeater functionality. So upgrading the repeater is a good tip.
                    • J
                      J
                      johnr
                      Upgrading repeater to 1.5 solved this issue. Thanks for the quick help. 1.4 sensors communicate OK with the 1.5 repeater as far as I can see right now.
                      • F
                        F
                        Fabien
                        I try to make a 3D box for SenseBender Micro with CR123 battery.
                        Screenchot :
                        • F
                          F
                          Fabien
                          first print test : IMG_20150921_230740.jpg
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            @Fabien
                            Nice work, what is the dimensions of the enclosure?
                              mvader
                              @mvader said:
                              question about the default sketch for this board.
                              if i read correctly
                              // How many milli seconds should we wait for OTA?
                              #define OTA_WAIT_PERIOD 300
                              #define FORCE_TRANSMIT_INTERVAL 30
                              if temps don't change more than .5 i shouldn't see a transmit but once every 30 minutes
                              i have 2 running right now
                              and both send temp and humidity every 1-2 minutes and the numbers are the same or in some cases only different by .1
                              i have it set to .5 so the question is
                              1. why does it transmit every minutes when the temp and humidity are the same
                              2. why is it transmitting even with as little as .1 change
                                1 board is running 1.2 and the other is running the 1.3 sketch from git
                                Battery however does transmit every 60 minutes as it's supposed to.,
                                thx
                              • tbowmoT
                                tbowmoT
                                tbowmo
                                @mvader
                                Have you tried to hook up a serial connection to your sensebender? It writes the difference from the last transmitted measurement, everytime a new measurement is taken (every minute).
                                • F
                                  F
                                  Fabien
                                  @tbowmo 47x37 height : 27
                                  I will make some improvment (can not test, my printer is in maintenance mode !) and post files for others.
                                  • tbowmoT tbowmo
                                    @mvader
                                    mvader
                                    @tbowmo said:
                                    @mvader
                                    so if i want it to transmit less frequently (save battery?) i would increase the measure interval. correct?
                                    I have some situations where i want frequent measuring (1 minute), and some where 15 minutes or 30 minutes would do fine.
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      @mvader
                                      Yes, you could save battery, by changing to 10/15 minute check interval..
                                      But still, the interesting thing is why it transmits every minute.. That's why I would suggest to check the serial output..
                                      • G gloob
                                        Hello
                                        needs to be replaced with
                                        korttomaK
                                        korttomaK
                                        korttoma
                                        #272
                                        There is an explanation to the problem further up in the thread:
                                        @gloob said:
                                        Hello
                                        • Tomas
                                        • tbowmoT
                                          tbowmoT
                                          tbowmo
                                          @korttoma
                                          thanks for helping my memory :)
