Arm / by-pass message not broadcast-ed to MySensor module
I was busy creating a security type of sensor which i needed to set in the arm and by-pass mode.
However Vera showed the correct status (arm/by-pass) the sensor was not aware that it was by-passed.Looking trough the Vera: I_Arduino.lua code i did figure out the setArmed on caused a local variable update.
Bij adding a sendCommand function call my mysensor gets an update on setArmed. This is the new code (MySensors version 1.4.1):
-- Security commands function setArmed(device, newArmedValue) -- Line added by BartE sendCommand(luup.devices[device].id,"ARMED",newArmedValue) -- Add ends setVariableIfChanged(tVarTypes.ARMED[2], tVarTypes.ARMED[3], newArmedValue, device) endIn a sketch running on an Arduino one can handle the setArmed like this
void incomingMessage(const MyMessage &message) { if (message.type==V_ARMED) { bArmed = message.getBool(); // Do something wise with the global bArmed boolean } } -
Nice :) I did make both pull requests
