  3. Windows GUI/Controller for MySensors
myscontrollermysbootloader
486 Posts 101 Posters 515.1k Views 73 Watching
  • tekkaT tekka
    @mvader please upload the entire log file to check a few things. Also, if the node is next to (or too close) you will get RF interferences (this has been observed for the large antenna and max tx power).
    EDIT: before I forget, also upload the log from the node - this will help to elicit the problem...
    mvader
    wrote on last edited by mvader
    #264
    @mvader said:
    i'm not sure how to grab the log from the node, please advise.
    here is the MYSController debug log in full.
    MySensors_20150930-203313.log
    tekkaT 1 Reply Last reply
    • J
      J
      jkandasa
      @tekka MYSBootloader is a great gift for us. With zero touch we can upgrade our firmware in to target board.
      In some cases I want to recompile the source code for 8 MHz or lesser frequency or different boards. As this is not a Arduino code, I do not know how to recompile this software. I hope many people facing issue with recompiling. Could you please add some document how to recompile this source code under https://github.com/mysensors/Arduino/tree/master/MYSBootloader
      Also can you post source code of MYSBootloader 1.5 version?
      Thank you!
      • J jkandasa
        Thank you!
        tekkaT
        tekkaT
        tekka
        @jkandasa The source code for 1.5 will be available upon release (mid-end October if time allows).
        • M mvader
          tekkaT
          tekkaT
          tekka
          @mvader For the node log: simply connect a serial adapter to the sensebender node and retrieve the serial output.
          • AnticimexA Anticimex
            @tekka I think I might have found a bug (or perhaps this is considered a feature request):
            The GW "version" (1.5) is not shown in the node info although it has sent a response to a version request as shown here:
            upload-59d5fea8-52ae-4f8c-8bfa-bdb9ebac82a2
            upload-fbd28c37-06f4-46d5-bba4-be8e6f6ad412
            Also, I am not sure what the "signing" field is intended for. Showing signing request status? It says "Unknown" for both my GW and my "secure" node. The node require signing and the gw is signing messages sent to it. Perhaps reserved for future functionality?
            Still a great and very useful tool!
            tekkaT
            tekkaT
            tekka
            @Anticimex No, not a bug and in the feature request list (I_VERSION handling). The signing field is updated once the node sends its signing preferences.
            AnticimexA 1 Reply Last reply
            • tekkaT tekka
              AnticimexA
              AnticimexA
              Anticimex
              @tekka Ok, but then I believe I found a bug, because I have reset my node and it did send its presentation messages, but the field did not update. I'm not at home right now so I can't get you the logs but I will see if I can replicate the steps and send you later on.
              • petewillP
                petewillP
                petewill
                @tekka Thanks for this great tool! I have been using it to monitor my nodes successfully for over a day. It's great. I do have a couple of questions.
                Is there a way to see Variables that are sent from my controller (Vera)? I see the request sent from the node but not the response from Vera. Here is a screenshot. I would expect to see numbers sent back from Vera but maybe I'm missing something.
                Is there a way to send a message to a node that hasn't checked in with the controller yet? I tried to manually type in a Node and Sensor but was unable to. I'd like to be able to send commands to nodes that haven't checked in if possible. For example, if the controller wasn't running for a while but I want to start it up to send a reboot command to a node that is no longer communicating. Or, if I have a relay node that doesn't check in often but I need to change the state.
                Thanks again!!
                • petewillP petewill
                  Thanks again!!
                  tekkaT
                  tekkaT
                  tekka
                  No, not to my knowledge - anybody?
                  You can manually add a node, but not a sensor: in the node tree view: right click | Add node | enter ID.
                  I will add the manual sensor adding to the feature requests.
                  petewillP 1 Reply Last reply
                    tekkaT
                    tekkaT
                    tekka
                    @Anticimex Just had a quick look at the library code: if signing is enabled (in the GW), the I_REQUEST_SIGNING message is not published. This field is only updated if signing is disabled (in the GW). However, MYSController will reply with a "signing not supported" message.
                    • tekkaT tekka
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @tekka right. Signing exchange is currently only done in the rf protocol, not to the controller. So are there currently any ways for the controller to populate that field?
                      A future addition of a I_CONFIG message is under discussion where node properties such as signing and other things can be published to a controller, so I suppose that field in the ui is for future use then :)
                        tekkaT
                        tekkaT
                        tekka
                        @Anticimex ~yup :)
                        • tekkaT tekka
                          petewillP
                          petewillP
                          petewill
                          Great, thanks!
                          As for the variables, I don't think I was clear in what I was asking. The variable is a MySensors variable. It just doesn't look like it's picked up by the MYSController. I am doing a horrible job describing this but here is that I see in the log file:
                          50	10/02/15 7:30:16.689	luup_log:27: Arduino: Request: 1;2;2;0;24;Front Yard <0x308de680>
                          50	10/02/15 7:30:16.689	luup_log:27: Arduino: Requesting status for: 1;2 <0x308de680>
                          50	10/02/15 7:30:16.690	luup_log:27: Arduino: Request status for Variable1 <0x308de680>
                          50	10/02/15 7:30:16.690	luup_log:27: Arduino: Sending: 1;2;1;0;24;8 <0x308de680>
                          I'm not seeing the '8' in the MYSController though. Hopefully that makes a little more sense.
                          Thanks again for all the hard work!
                          • tekkaT tekka
                            mvader
                            I have to do more testing over the weekend, but i updated my gateway to 1.5, as my nodes where 1.5 but gate was 1.4, the 1st one i tried, worked without issue.
                            dont know if it was a fluke/lucky or updating to 1.5 on the gateway solved my issue.. i'll post more as i test more nodes
                              mvader
                                Great, thanks!
                                tekkaT
                                tekkaT
                                tekka
                                The controller receives messages from the GW but does not intercept messages sent from other controllers (due to the architecture). Similarly, messages sent with MYSController won't appear in Vera.
                                But this leads me to an interesting idea...let's see :)
                                  mvader
                                  #279
                                  looking for some help with OTA and a sensebender board.
                                  if i manually reset the board, then it will take the OTA and that works fine.
                                  however, that's the only way i can get it to work.
                                  it doesn't respond to a reboot command (I assume this is because it's sleeping)
                                  and even if i select the battery/sleeping option, when a transmission does come in, it doesn't reset or start an OTA.
                                  the only way so far is to physically PF the device and then the OTA works.
                                  what am i missing?
                                  thanks!
                                  EDIT: so this does seems to work.. i spent all morning trying to come up with hack-y ways to get this to work.
                                  using the default sensebender sketch the OTA wait time is set to 300 milli seconds. which is like .3 seconds.
                                  i changed that 3000 (3 seconds) set the FW and waited for the next transmission..boom off it went (the OTA).
                                  so for anyone running into this issue. try this solution.
                                  I cant imagine 3 seconds vs .3 seconds is going to make a huge difference in battery life.
                                  • N
                                    N
                                    novicit
                                    Looking for help to interpret log data after an OTA update. I am just learning, and successfully OTA'ed a simple DS18B temperature sketch to a node using MysController. Now I am trying to OTA an DHT22 node (the example sketch in 1.5 version, no changes to it.) The firmware OTA seems to go fine, but the Pro Mini never seems to start. Below is the log, I have bolded the log entries I don't understand. As shown, the first bold section comes right after the OTA. The second 16 minutes later is because I pushed the reset button on the pro mini. Any help understanding the log entry is appreciated.
                                    10/5/2015 7:04:01 RX 2;255;4;0;2;820001000200
                                    10/5/2015 7:04:01 TX 2;255;4;0;3;8200010001000C94AE010C94AE010C94ED020C94AE01
                                    10/5/2015 7:04:01 RX 2;255;4;0;2;820001000100
                                    10/5/2015 7:04:01 TX 2;255;4;0;3;8200010000000C9486010C94D11A0C94FE1A0C94AE01
                                    10/5/2015 7:04:01 RX 2;255;4;0;2;820001000000
                                    10/5/2015 7:04:01 INFO BL version=257
                                    10/5/2015 7:04:01 INFO Send FW info to node 2: type=82, version=1, blocks=0x0570, CRC=0x9AEC
                                    10/5/2015 7:04:01 TX 2;0;4;0;1;820001007005EC9A
                                    10/5/2015 7:04:01 RX 2;255;4;0;0;820001007005EC9A0101
                                    10/5/2015 7:07:23 RX 24;1;1;0;0;60.5
                                    10/5/2015 7:07:23 RX 24;2;1;0;1;59
                                    10/5/2015 7:11:41 RX 24;1;1;0;0;60.5
                                    10/5/2015 7:11:41 RX 24;2;1;0;1;59
                                    10/5/2015 7:13:24 RX 23;0;1;0;1;55.7
                                    10/5/2015 7:15:59 RX 24;1;1;0;0;60.5
                                    10/5/2015 7:15:59 RX 24;2;1;0;1;59
                                    10/5/2015 7:18:27 CHILD New child discovered, node id=23, child id=1
                                    10/5/2015 7:18:27 RX 23;1;1;0;0;63.0
                                    10/5/2015 7:18:27 RX 23;0;1;0;1;55.9
                                    10/5/2015 7:20:14 INFO BL version=257
                                    10/5/2015 7:20:14 INFO Send FW info to node 2: type=82, version=1, blocks=0x0570, CRC=0x9AEC
                                    10/5/2015 7:20:14 TX 2;0;4;0;1;820001007005EC9A
                                    10/5/2015 7:20:14 RX 2;255;4;0;0;820001007005EC9A0101
                                    10/5/2015 7:21:50 TX 2;0;3;0;13;0
                                    10/5/2015 7:23:32 RX 23;0;1;0;1;56.0
                                    10/5/2015 7:24:26 RX 24;3;1;0;24;78
                                    • tekkaT tekka
                                      petewillP
                                      petewillP
                                      petewill
                                      Oh, sorry. I thought it did. I can see my light (relays) messages when turning on/off with my Vera but maybe that's the ACKs?
                                      • N novicit
                                        tekkaT
                                        tekkaT
                                        tekka
                                        @novicit The bold section is the bootloader sending/requesting the current node configuration. Did you set a static node ID in your sketch?
                                        • N
                                          N
                                          novicit
                                          @tekka Thank you for your response. The sketch does not have a static ID - the line is "gw.begin();" So it should receive a node ID. I had MysController set to "AutoID" and it successfully issued the next free ID, which was 2. How would I test further to see why it does not begin execution. (I am using ethernet gateway with authentication, but the configuration is set to 'false', so a node not asking for Atsha response does not get one. Other non-atsha nodes work fine-as shown in the log. Don't know if this would make a difference.)
