  3. Req Id
Req Id
6 Posts 2 Posters 3.4k Views 1 Watching
  • E
    E
    Elfnoir
    wrote on last edited by Elfnoir
    I build a gateway and a Humidity Sensor. Unfortunately, I've this message on the Gateway:
    0;0;3;0;9;read: 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0:
    255;255;3;0;3;
    255;255;3;0;3;
    255;255;3;0;3;
    255;255;3;0;3;
    255;255;3;0;3;
    On the Humidity Sensor, there is this message:
    req id
    req id
    T: 21.00
    req id
    H: 60.00
    req id
    H: 59.00
    Could you please tell me what do I have to do in order to search where issue is coming from? I think Gateway has to communicate the Id number to the Sensor, correct?
    Also, when I plug it into a Raspberry under Domoticz, and declare My Sensors USB Gateway, please find what I see in Domoticz log:
    2015-09-21 21:35:34.116 MySensors: Using serial port: /dev/ttyUSB1
    2015-09-21 21:35:35.596 MySensors: Gateway Ready...
    2015-09-21 21:35:45.405 Hardware Monitor: Fetching data (System sensors)
    2015-09-21 21:36:15.817 Hardware Monitor: Fetching data (System sensors)
    2015-09-21 21:36:46.058 Hardware Monitor: Fetching data (System sensors)
    2015-09-21 21:37:16.306 Hardware Monitor: Fetching data (System sensors)
    Thanks in advance for your support.
    • E
      E
      Elfnoir
      Hi, some additionnal tests I've done. When I put this script inside a sensor, I have the same message "ReqId", but it has an Id (3), isn't it?
      #define ID 3
      #define OPEN 1
      #define CLOSE 0
      MyMessage msg(ID, V_TRIPPED);
      gw.begin();
      gw.present(ID, S_DOOR);
      gw.send(msg.set(OPEN));
      delay(10000); // Wait 10 seconds
      Thanks for your help :-)
      • tbowmoT
        tbowmoT
        tbowmo
        You need a controller that can assign node Id's to your sensors. That is not done by the GW.
        As an alternative, you can hardwire the firmware to use a specific node Id in your mysensors constructor. Check example sketches etc on jow to do it.
        • E
          E
          Elfnoir
          Thanks for your feedback;
          I put it on USB on my raspberry with Domoticz, and I was happy (!) to read in Domoticz logs:
          "2015-09-11 08:17:09.306 MySensors: Using serial port: /dev/ttyUSB1
          2015-09-11 08:17:10.786 MySensors: Gateway Ready..."
          but I have the same error message for the humidity sensor, and no visibility in Domoticz:
          "req id
          H: 51.00
          req id
          T: 21.00
          req id
          H: 50.00
          req id
          H: 49.00
          req id
          T: 20.00"
          Then I build Car Park Sensors, and it's working well: shown in Domoticz, and no 'req id' in loop.
          Do you know, for my Humidity Sensors what could be wrong please?
          Regards.
          • E
            E
            Elfnoir
            I also created a motion, door, and with the humidity sensors, there is the same message: 'Req Id' in loop.
            I understand Domoticz didn't get it, but could you please tell me what should I modify in Domoticz to obtain these Id's please? Which files or configuration? Is there any tutos to follow please?
            Thanks for your support.
            Regards.
            • E
              E
              Elfnoir
              I erase my arduino with EEPROM_clear script, and It works now.
              12.5k
