  3. Windows GUI/Controller for MySensors
myscontrollermysbootloader
486 Posts 101 Posters 513.6k Views 73 Watching
    mvader
    • petewillP petewill
      @tekka said:
      I will add the manual sensor adding to the feature requests.
      Great, thanks!
      As for the variables, I don't think I was clear in what I was asking. The variable is a MySensors variable. It just doesn't look like it's picked up by the MYSController. I am doing a horrible job describing this but here is that I see in the log file:
      50	10/02/15 7:30:16.689	luup_log:27: Arduino: Request: 1;2;2;0;24;Front Yard <0x308de680>
      50	10/02/15 7:30:16.689	luup_log:27: Arduino: Requesting status for: 1;2 <0x308de680>
      50	10/02/15 7:30:16.690	luup_log:27: Arduino: Request status for Variable1 <0x308de680>
      50	10/02/15 7:30:16.690	luup_log:27: Arduino: Sending: 1;2;1;0;24;8 <0x308de680>
      I'm not seeing the '8' in the MYSController though. Hopefully that makes a little more sense.
      Thanks again for all the hard work!
      tekkaT
      tekkaT
      tekka
      The controller receives messages from the GW but does not intercept messages sent from other controllers (due to the architecture). Similarly, messages sent with MYSController won't appear in Vera.
      But this leads me to an interesting idea...let's see :)
      petewillP 1 Reply Last reply
        mvader
        wrote on last edited by mvader
        #279
        looking for some help with OTA and a sensebender board.
        if i manually reset the board, then it will take the OTA and that works fine.
        however, that's the only way i can get it to work.
        it doesn't respond to a reboot command (I assume this is because it's sleeping)
        and even if i select the battery/sleeping option, when a transmission does come in, it doesn't reset or start an OTA.
        the only way so far is to physically PF the device and then the OTA works.
        what am i missing?
        thanks!
        EDIT: so this does seems to work.. i spent all morning trying to come up with hack-y ways to get this to work.
        using the default sensebender sketch the OTA wait time is set to 300 milli seconds. which is like .3 seconds.
        i changed that 3000 (3 seconds) set the FW and waited for the next transmission..boom off it went (the OTA).
        so for anyone running into this issue. try this solution.
        I cant imagine 3 seconds vs .3 seconds is going to make a huge difference in battery life.
        • N
          N
          novicit
          Looking for help to interpret log data after an OTA update. I am just learning, and successfully OTA'ed a simple DS18B temperature sketch to a node using MysController. Now I am trying to OTA an DHT22 node (the example sketch in 1.5 version, no changes to it.) The firmware OTA seems to go fine, but the Pro Mini never seems to start. Below is the log, I have bolded the log entries I don't understand. As shown, the first bold section comes right after the OTA. The second 16 minutes later is because I pushed the reset button on the pro mini. Any help understanding the log entry is appreciated.
          10/5/2015 7:04:01 RX 2;255;4;0;2;820001000200
          10/5/2015 7:04:01 TX 2;255;4;0;3;8200010001000C94AE010C94AE010C94ED020C94AE01
          10/5/2015 7:04:01 RX 2;255;4;0;2;820001000100
          10/5/2015 7:04:01 TX 2;255;4;0;3;8200010000000C9486010C94D11A0C94FE1A0C94AE01
          10/5/2015 7:04:01 RX 2;255;4;0;2;820001000000
          10/5/2015 7:04:01 INFO BL version=257
          10/5/2015 7:04:01 INFO Send FW info to node 2: type=82, version=1, blocks=0x0570, CRC=0x9AEC
          10/5/2015 7:04:01 TX 2;0;4;0;1;820001007005EC9A
          10/5/2015 7:04:01 RX 2;255;4;0;0;820001007005EC9A0101
          10/5/2015 7:07:23 RX 24;1;1;0;0;60.5
          10/5/2015 7:07:23 RX 24;2;1;0;1;59
          10/5/2015 7:11:41 RX 24;1;1;0;0;60.5
          10/5/2015 7:11:41 RX 24;2;1;0;1;59
          10/5/2015 7:13:24 RX 23;0;1;0;1;55.7
          10/5/2015 7:15:59 RX 24;1;1;0;0;60.5
          10/5/2015 7:15:59 RX 24;2;1;0;1;59
          10/5/2015 7:18:27 CHILD New child discovered, node id=23, child id=1
          10/5/2015 7:18:27 RX 23;1;1;0;0;63.0
          10/5/2015 7:18:27 RX 23;0;1;0;1;55.9
          10/5/2015 7:20:14 INFO BL version=257
          10/5/2015 7:20:14 INFO Send FW info to node 2: type=82, version=1, blocks=0x0570, CRC=0x9AEC
          10/5/2015 7:20:14 TX 2;0;4;0;1;820001007005EC9A
          10/5/2015 7:20:14 RX 2;255;4;0;0;820001007005EC9A0101
          10/5/2015 7:21:50 TX 2;0;3;0;13;0
          10/5/2015 7:23:32 RX 23;0;1;0;1;56.0
          10/5/2015 7:24:26 RX 24;3;1;0;24;78
          tekkaT 1 Reply Last reply
          • tekkaT tekka
            petewillP
            petewillP
            petewill
            Oh, sorry. I thought it did. I can see my light (relays) messages when turning on/off with my Vera but maybe that's the ACKs?
            • N novicit
              tekkaT
              tekkaT
              tekka
              @novicit The bold section is the bootloader sending/requesting the current node configuration. Did you set a static node ID in your sketch?
              • N
                N
                novicit
                @tekka Thank you for your response. The sketch does not have a static ID - the line is "gw.begin();" So it should receive a node ID. I had MysController set to "AutoID" and it successfully issued the next free ID, which was 2. How would I test further to see why it does not begin execution. (I am using ethernet gateway with authentication, but the configuration is set to 'false', so a node not asking for Atsha response does not get one. Other non-atsha nodes work fine-as shown in the log. Don't know if this would make a difference.)
                • N
                  N
                  novicit
                  @tekka, In thinking about your question .... As the sketch begins execution after OTA'ing, it then asks for a node id to be issued (even though it has received one from the MysController) - and since I am using an ethernet gateway (& Domoticz) which does not automatically issue a node ID, the pro mini just sits there and waits for a node id? Would it then work if I put in a static node ID, even if it is different than the one issued by Myscontroller? And the node then adopts the static ID. ??
                  • N
                    N
                    novicit
                    @tekka I tried 2 new nodes with static id assigned [gw.begin(incomingMessage, 21, false);] and [gw.begin(NULL, 23, false);] ---- still same frozen response.
                    10/5/2015 17:18:46 TX 3;255;4;0;3;1400010000000C9486010C94D81A0C94051B0C94AE01
                    10/5/2015 17:18:46 RX 3;255;4;0;2;140001000000
                    10/5/2015 17:18:47 INFO BL version=257
                    10/5/2015 17:18:47 INFO Send FW info to node 3: type=14, version=1, blocks=0x0570, CRC=0xE30B
                    10/5/2015 17:18:47 TX 3;0;4;0;1;1400010070050BE3
                    10/5/2015 17:18:47 RX 3;255;4;0;0;1400010070050BE30101
                    10/5/2015 17:20:32 RX 1;0;1;0;0;19.5
                    and:
                    10/5/2015 16:59:29 TX 2;255;4;0;3;1400010000000C9486010C94D11A0C94FE1A0C94AE01
                    10/5/2015 16:59:29 RX 2;255;4;0;2;140001000000
                    10/5/2015 16:59:29 INFO BL version=257
                    10/5/2015 16:59:29 INFO Send FW info to node 2: type=14, version=1, blocks=0x0570, CRC=0x2E9E
                    10/5/2015 16:59:29 TX 2;0;4;0;1;1400010070059E2E
                    10/5/2015 16:59:29 RX 2;255;4;0;0;1400010070059E2E0101
                    10/5/2015 17:00:59 RX 24;1;1;0;0;62.8
                    Any idea what the nodes are waiting for?
                    I also reset the gateway to see if it sent anything that cleared the freeze, but no response. Hmmm.
                    • N novicit
                      and:
                      tekkaT
                      tekkaT
                      tekka
                      @novicit Can you temporarily use a serial gateway with debug enabled and upload a debug-enabled sketch to see what's going on on both sides? Please post the node and gateway log for further hints.
                      • A
                        azlan
                        Can I set up Hydroponic Greenhouse automation with MYSController???
                        • OitzuO
                          OitzuO
                          Oitzu
                          @tekka just wondering.. is there anywhere a documentation how the OTA works?
                          I'm currently trying to write a little perl-script with OTA support and had a hard time misreading the source code of the MYSController and OTABootloader.
                          • N
                            N
                            novicit
                            @tekka, problem solved! I took a debug log from the node per your suggestion and was surprised to get:
                            radio init fail
                            radio init fail
                            radio init fail
                            This of course surprised me after it just finished downloading 20kb+. Turns out after I made the first test of OTA which worked fine, my home network automatically synchronized my laptops & desktop. This brought over a copy of myconfig.h which had softspi enabled! (I had been setting up the gateway on a different computer). So when I went to OTA on the second and third nodes it picked up the synched myconfig.h. Ugh, such little strange things that take so much time to find.
                            @tekka, my apologies for using some of your time. And my Thanks for your great work and sharing with the community!! Hopefully others will avoid similar mistakes by reading this.
                            • korttomaK
                              korttomaK
                              korttoma
                              Hi @tekka , I'm trying to create a simple thermostat device and I'm usually using your fantastic controller for prototype testing and debugging. Now I would need the possibility to send setpoint values from the controller and the current version of MYSController does not seem to support the following:
                              V_HVAC_SETPOINT_COOL 44 HVAC cold setpoint S_HVAC
                              V_HVAC_SETPOINT_HEAT 45 HVAC/Heater setpoint S_HVAC, S_HEATER
                              V_HVAC_FLOW_MODE 46 Flow mode for HVAC ("Auto", "ContinuousOn", "PeriodicOn") S_HVAC
                              I would greatly appreciate it is these features were implemented to your fantastic controller also.
                              Best regards,
                              Tomas
                              • Tomas
                                mvader
                                sorry if this has been asked before.
                                but I have a nano with mySbootloader installed and when i look at it in the serial monitor its just all gibberish.
                                i tried different speeds, but still the same.
                                is it not possible if you have that bootloader installed? or do i need to do something else.?
                                thx
                                • korttomaK korttoma
                                  Best regards,
                                  Tomas
                                  tekkaT
                                  tekkaT
                                  tekka
                                  @korttoma is implemented in 0.1.2.284 - release pending
                                  • M mvader
                                    thx
                                    tekkaT
                                    tekkaT
                                    tekka
                                    @mvader this is not related to MYSBootloader. Try doubling the baud rate setting, i.e. 230400....
                                    • AnticimexA
                                      AnticimexA
                                      Anticimex
                                      @tekka Would it be possible in a future version to have the controller save the detected network nodes? Right know, I have to re-present the nodes in order for them to appear properly in the tree every time MYSController is restarted since it starts up with an empty tree.
                                      • R
                                        R
                                        rubal
                                        Hi @tekka , I've gone through the steps in your guide using MQTTGateway as gw sketch.
                                        When I start my new node (burned with mysbootloader) I only see the repeating message "FIND_PARENT" in MySensor Debug window and "RX 0;0;3;0;9;read: 0-0-255 s=255,c=3,t=7,pt=0,l=0,sg=0:" in the MYSController Debug window.
                                        The message appears every time the led is blinking on the node (approx every 2 seconds).
                                        Any idea why it doesn't request node id? Have also tried with AutoID without success.
                                        Thx!
                                        • AnticimexA Anticimex
                                          tekkaT
                                          tekkaT
                                          tekka
                                          @Anticimex is implemented in the upcoming release :)
                                          AnticimexA 1 Reply Last reply
