  3. Greenhouse controller
7 Posts 2 Posters 3.2k Views 2 Watching
  • A
    azlan
    What if I can not use any controllers out there, is there any sample code on controller site, like how do controller communicate to sensor wirelessly, is there example code to retrieve/send data/command from/to sensor/actuator?
    • OitzuO
      OitzuO
      Oitzu
      Well, the api documentation should give a good hint howto communicate with the MySensors network.
      I think most of the controllers/controller-plugins are based on the this documentations.
      You should look at the available controllers if there isn't a controller that fits your need.
      Maybe, if you outline your needs, someone can you point in the right direction. :)
      • A
        azlan
        Where is the documentation?
        • OitzuO
          OitzuO
          Oitzu
          @azlan
          http://www.mysensors.org/download/serial_api_15
          http://www.mysensors.org/download/sensor_api_15
          Especially the serial api gives a good hint how a controller should handle messages.
          A 1 Reply Last reply
          • OitzuO Oitzu
            @azlan
            azlan
            @Oitzu I have another question. If I decide to use gateway as controller, How do I pull data to use in my controller code in gateway instead of forwarding to Raspberry PI. Can you help me with a simple code showing how it can be done?
            • OitzuO
              OitzuO
              Oitzu
              @azlan you mean using the gateway itself to control the nodes?
              Never done that.
              This would mean you wouldn't use a gateway at all.
              Normally the gateway represents a point in the mysensors network a controller is connected to.
              What do you acutally want to do? Maybe we can answer better with a picture of the whole situation.
              Hint: A mySensors network without an gateway would need something like an "master-node". A node with id 0 that assigns new node ids and control the other nodes.
              But the functionallity of this master node would be very limited due to ressource limitations.
              • OitzuO Oitzu
                Never done that.
                azlan
                @Oitzu Well, What I want to do is; Make gateway my controller ( intend to use arduino yun), the reason for that is none of the controllers fit my need, which is I want to automate hydroponic greenhouse and it is something like this ; https://www.youtube.com/watch?v=-IfvbrZJ4sY
                I want to ask again " How do I pull data to use in my controller code in gateway instead of forwarding to Raspberry PI. Can you help me with a simple code showing how it can be done?".
