  3. ESP8266 WiFi gateway port for MySensors
328 Posts 56 Posters 403.3k Views 39 Watching
  • P
    P
    Pseudomizer
    I tried my Home Wifi and my Cell Hotspot. The crashes occur on both wifi networks. :-(
    • R
      R
      ridge
      wrote on last edited by ridge
      #109
      @Pseudomizer , Is the esp8266 on a breadboard or is it part of a commercial product like HUZZAH or nodemcu ? I ask because the esp devices can reset themselves from a brownout condition during the WiFi transmit if the power supply circuit is not up to handling the momentary 'high current draw' requirements of the radio. From reading www.esp8266.com, breadboard circuits have caused many hours of troubleshooting enjoyment with the esp8266 parts.
      I replace the battery packs on these with 2 Amp cell phone charger power supplies. I have 8 under power 24/7 for months with no problems. They are available from multiple vendors.
      http://www.aliexpress.com/item/Free-shipping-ESP8266-ESP-12-serial-WIFI-Industrial-stable-version-A-full-test-board-Full-IO/32260095422.html?spm=2114.01020208.3.49.0YGvDs&ws_ab_test=201556_7,201527_4_3_2_1_4_71_72_73_74_75,0_0
      • P
        P
        Pseudomizer
        I followed the instructions exactly as shown here and I purchased that exact equipment.
        http://www.mysensors.org/build/esp8266_gateway
        I even powered the NRF24L01+ from a different power source just to make sure that power fluctuation is not the issue but it didn't make any difference.
        I even tried transfer rates 115k, 57k and 9600 Baud but none of that made any difference either.
        I also downloaded the flash eeprom ino program to clear all the data but again, no difference.
        • P
          P
          Pseudomizer
          I even reflashed the ESP8266 with those instructions and then loaded the mysensors ino but still the same outcome. :-(
          http://benlo.com/esp8266/esp8266QuickStart.html
          • P Pseudomizer
            @Pseudomizer did you make any changes to the gateway sketch out the MySensors library/config?
            Could you post the output of the gateway just before the crash occurs (it might give an indication of where this crash occurs)
            • P
              P
              Pseudomizer
              The only changes to the sketch are the SSID, the pass and the debug line
              Serial.setDebugOutput(true);
              as instructed. No other changes were made.
              Here the the debug output....you will see multiple resets in a row based on the internal watchdog timer.
              ESP8266 MySensors Gateway
              Connecting to MYWIFI
              scandone
              f 0, scandone
              .add 0
              aid 1
              pm open phy_2,type:2 0 0
              cnt
              connected with MYWIFI, channel 6
              dhcp client start...
              ......ip:192.168.1.222,mask:255.255.255.0,gw:192.168.1.1
              .Connected!
              IP: 192.168.1.222
              wdt reset
              tail 0
              chksum 0x42
              csum 0x42
              ~ld
              scandone
              f 0, scandone
              .add 0
              aid 1
              cnt
              .......ip:192.168.1.222,mask:255.255.255.0,gw:192.168.1.1
              .Connected!
              IP: 192.168.1.222
              wdt reset
              tail 0
              chksum 0x42
              csum 0x42
              ~ld
              scandone
              f 0, scandone
              .add 0
              aid 1
              cnt
              .Connected!
              IP: 192.168.1.222
                Triple-check your radio wiring.
                  Or try with a different radio. The crash seems to happen in the radio init part.
                  • P
                    P
                    Pseudomizer
                    I just replaced the NRF with a new NRF and then again as I have 4 total. With every single one the same error.
                    The wiring matches exactly the picture from mysensors.
                    This is driving me crazy...
                      miguelingles
                      Hi, I tried the bridge with a rfm69hw module. It starts all well but does not receive any information. Neither shows startup information module .
                      Where to put the DIO0 . I tried on several pins ( changing IRQ number) but no thoughts about doing anything.
                      • M miguelingles
                        @miguelingles I didn't test with a rfm69hw module and I'm not aware of anybody else testing with this setup.
                        Probably you have to test step by step what work and what not.
                        Start with the radio initialization to see if the communication is ok, and go on from there.
                        • P Pseudomizer
                          @Pseudomizer past few days @hek and I have been working on better diagnosis for the ESP8266 regarding radio communication failures.
                          Please try if the version of MySensors development helps in diagnosing your problems.
                          Make sure to uncomment the line
                          //#define MY_DEBUG_VERBOSE
                          in MyConfig.h and make the same changes to ssid & password as you did before.
                          This version will dump diagnostics of NRF communications and a full register dump when starting up.
                          Good luck!
                          • P
                            P
                            Pseudomizer
                            Thanks a lot. This version provides much more details but at this stage of my learning progress I am not able to understand all those registers where I have to rely on your help guys. I assume that my password is not being exposed here.
                            Connecting to ZEUS
                            scandone
                            f 0, scandone
                            .add 0
                            aid 1
                            cnt
                            connected with ZEUS, channel 6
                            .Connected!
                            IP: 192.168.1.222
                            write_register(0x04,0x5F)
                            write_register(0x06,0x23)
                            write_register(0x06,0x03)
                            write_register(0x00,0x0E)
                            write_register(0x07,0x70)
                            write_register(0x05,0x4C)
                            STATUS 0x0E RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
                            RX_ADDR_P0-1 0x0E0E0E0E0E 0707070707
                            RX_ADDR_P2-5 0xFF C4 C5 C6
                            TX_ADDR 0x0E0E0E0E0E
                            RX_PW_P0-6 0x00 00 20 00 00 00
                            EN_AA 0x3B
                            EN_RXADDR 0x07
                            RF_CH 0x4C
                            RF_SETUP 0x03
                            CONFIG 0x0E
                            DYNPD/FEATURE 0x3F 06
                            Data Rate 1MBPS
                            Model nRF24L01+
                            CRC Length 16 bits
                            PA Power PA_LOW
                            write_register(0x01,0x3F)
                            write_register(0x01,0x3B)
                            write_register(0x1D,0x06)
                            FEATURE=0x06
                            write_register(0x1C,0x3F)
                            ets Jan 8 2013,rst cause:4, boot mode:(3,7)
                            wdt reset
                            tail 0
                            chksum 0x42
                            csum 0x42
                            ~ld
                            Connecting to ZEUS
                            scandone
                            f 0, scandone
                            .add 0
                            aid 1
                            cnt
                            .Connected!
                            IP: 192.168.1.222
                            EN_AA 0x3B
                            EN_RXADDR 0x07
                            RF_CH 0x4C
                            RF_SETUP 0x03
                            CONFIG 0x0E
                            Data Rate 1MBPS
                            Model nRF24L01+
                            CRC Length 16 bits
                            PA Power PA_LOW
                            FEATURE=0x06
                            wdt reset
                            tail 0
                            chksum 0x42
                            csum 0x42
                            ~ld
                            YveauxY 2 Replies Last reply
                            • P Pseudomizer
                              Connecting to ZEUS
                              scandone
                              f 0, scandone
                              .add 0
                              aid 1
                              cnt
                              .Connected!
                              IP: 192.168.1.222
                              EN_AA 0x3B
                              EN_RXADDR 0x07
                              RF_CH 0x4C
                              RF_SETUP 0x03
                              CONFIG 0x0E
                              Data Rate 1MBPS
                              Model nRF24L01+
                              CRC Length 16 bits
                              PA Power PA_LOW
                              FEATURE=0x06
                              wdt reset
                              tail 0
                              chksum 0x42
                              csum 0x42
                              ~ld
                              Connecting to ZEUS
                              scandone
                              f 0, scandone
                              .add 0
                              aid 1
                              cnt
                              .Connected!
                              IP: 192.168.1.222
                              EN_AA 0x3B
                              EN_RXADDR 0x07
                              RF_CH 0x4C
                              RF_SETUP 0x03
                              CONFIG 0x0E
                              Data Rate 1MBPS
                              Model nRF24L01+
                              CRC Length 16 bits
                              PA Power PA_LOW
                              FEATURE=0x06
                              wdt reset
                              tail 0
                              chksum 0x42
                              csum 0x42
                              ~ld
                              @Pseudomizer just had a quick look at your results. Radio config (and this communication) seem to be OK, but it restarts due to watchdog timeout.
                              Hopefully tonight I can have a better look.
                                miguelingles
                                when I put the development package I can not compile anything (all gives me error). I tried it with a clean install and nothing.
                                I think the problem is the IRQ pin DIØØ , if the ESP cpu does not recognize this interruption when the RF module receives data is unable to apply for the request .
                                • M miguelingles
                                  The irq pin from the nrf24 stays unconnected, like the build instructions clearly state!
                                    miguelingles
                                    but RF69 need irq.
                                    • M miguelingles
                                      but RF69 need irq.
                                      @miguelingles didn't know you were talking about rf69... Sorry but I cannot keep track of what everyone is using.
                                      • P Pseudomizer
                                        scandone
                                        f 0, scandone
                                        .add 0
                                        aid 1
                                        cnt
                                        .Connected!
                                        IP: 192.168.1.222
                                        wdt reset
                                        tail 0
                                        chksum 0x42
                                        csum 0x42
                                        ~ld
                                        scandone
                                        f 0, scandone
                                        .add 0
                                        aid 1
                                        cnt
                                        .Connected!
                                        IP: 192.168.1.222
                                        wdt reset
                                        tail 0
                                        chksum 0x42
                                        csum 0x42
                                        ~ld
                                        scandone
                                        f 0, scandone
                                        .add 0
                                        aid 1
                                        cnt
                                        .Connected!
                                        IP: 192.168.1.222
                                        #126
                                        For everyone wondering what serial output during startup of the ESP8266-NRF24 gateway should look like (all captures taken using link development branch from Oct 6, 2015 (hek just merged gateway-refactoring this morning, so output might have slightly changed)) .
                                        WiFi startup comes first after reset, followed by MySensors (nRF24) startup:
                                        • WiFi startup (not using Serial.setDebugOutput(true) )
                                        Connecting to YOUR_SSID
                                        ...........Connected!
                                        IP: 192.168.1.101
                                        • WiFi startup (using Serial.setDebugOutput(true) )
                                        scandone
                                        f 0, ....scandone
                                        .add 0
                                        aid 10
                                        cnt
                                        connected with YOUR_SSID, channel 1
                                        .....ip:192.168.1.101,mask:255.255.255.0,gw:192.168.1.1
                                        .Connected!
                                        IP: 192.168.1.101
                                        • MySensors startup (not using DEBUG and MY_DEBUG_VERBOSE)
                                        • MySensors startup (using DEBUG and MY_DEBUG_VERBOSE)
                                        write_register(0x06,0x27)
                                        write_register(0x06,0x07)
                                        write_register(0x00,0x0C)
                                        RX_ADDR_P2-5	0xC3 C4 C5 C6
                                        EN_AA		0x3F
                                        EN_RXADDR	0x03
                                        RF_CH		0x4C
                                        RF_SETUP	0x07
                                        CONFIG		0x0E
                                        DYNPD/FEATURE	0x00 00
                                        Data Rate	1MBPS
                                        Model		nRF24L01+
                                        CRC Length	16 bits
                                        PA Power	PA_MAX
                                        FEATURE=0x06
                                        write_register(0x1C,0x03)
                                        FEATURE=0x06
                                        write_register(0x13,0x20)
                                        write_register(0x02,0x07)
                                        write_register(0x11,0x20)
                                        write_register(0x12,0x20)
                                        write_register(0x00,0x0F)
                                        write_register(0x02,0x06)
                                        • P Pseudomizer
                                          Connecting to ZEUS
                                          scandone
                                          f 0, scandone
                                          .add 0
                                          aid 1
                                          cnt
                                          .Connected!
                                          IP: 192.168.1.222
                                          EN_AA 0x3B
                                          EN_RXADDR 0x07
                                          RF_CH 0x4C
                                          RF_SETUP 0x03
                                          CONFIG 0x0E
                                          Data Rate 1MBPS
                                          Model nRF24L01+
                                          CRC Length 16 bits
                                          PA Power PA_LOW
                                          FEATURE=0x06
                                          wdt reset
                                          tail 0
                                          chksum 0x42
                                          csum 0x42
                                          ~ld
                                          Connecting to ZEUS
                                          scandone
                                          f 0, scandone
                                          .add 0
                                          aid 1
                                          cnt
                                          .Connected!
                                          IP: 192.168.1.222
                                          EN_AA 0x3B
                                          EN_RXADDR 0x07
                                          RF_CH 0x4C
                                          RF_SETUP 0x03
                                          CONFIG 0x0E
                                          Data Rate 1MBPS
                                          Model nRF24L01+
                                          CRC Length 16 bits
                                          PA Power PA_LOW
                                          FEATURE=0x06
                                          wdt reset
                                          tail 0
                                          chksum 0x42
                                          csum 0x42
                                          ~ld
                                          @Pseudomizer Had a better look at your crashdump.
                                          Your ESP seems to crash with a watchdog timeout when MySensors is setting the datarate (or shortly after that) after nRF24 has been initialized.
                                          Default datarate is RF24_250KBPS.
                                          Some questions, trying to rule things out:
                                          • Do you use this default datarate?
                                          • Could it be that you have an nRF24L01+ clone, which in reality is a nRF24L01 (clone)?
                                          • Did you ever try and succeed to connect these radios to a regular Arduino?
                                          • Are all radio's from the same batch/order?
