  2. KiCad
  3. Possible for novice to create PCB?
Scheduled Pinned Locked Moved KiCad
16 Posts 7 Posters 10.9k Views 5 Watching
  • Cliff KarlssonC
    Cliff KarlssonC
    Cliff Karlsson
    I would like to create a custom PCB for RFM69,battery or ac-relay and an arduino mini pro 5v or 3.3v. But where do I start? What program do I use and are there any easy programs where you just place the components and the software makes all the traces in a optimal way?
    • tbowmoT
      tbowmoT
      tbowmo
      you could go with kicad, and then use the "official" mysensors kicad repository for components, where both rfm69 and arduino mini have footprints available
      See https://github.com/mysensors-kicad/part_management for information on how to set things up..
      • FotoFieberF
        FotoFieberF
        FotoFieber
        I use http://fritzing.org/home/ for the design. I am usually looking for an existing design in the community, that does nearly what I want and then change it to my needs.
        Then I upload the exported gerber files to https://oshpark.com/.
        It is quite simple.
        • TD22057T
          TD22057T
          TD22057
          Ki-Cad or Eagle are both free PCB design software packages that will work. Eagle is commercial and limits free designs to 8cm x 10cm. Google for "Eagle vs kicad" and you'll see lots of discussions. Both have YouTube videos which are the best way (IMO) to learn them (search for "eagle/kicad tutorial" on youtube) and both have tons of parts libraries that are easy to use. I came across Eagle first so I started using that. If you can handle a basic schematic, you can be designing your first PCB in a week or so.
          You have to position your components on a board first, then both programs have an "auto-router" which will lay out the traces for you but it won't be good. At least for me, the fun in PCB design is doing the traces yourself.
          • AnticimexA
            AnticimexA
            Anticimex
            I second that on autorouting. It may sound like a good idea, but it rarely works out as you hope.
            Also, it is good to start of with a large board. As large as possible (given constraints like cost, boxes, mounting area etc).
            Things get tricky when space is scarce. Take my word for it ;) You can have a look at my 5x5 board which is pretty crowded.
            Another problem with crowded boards (as you see with mine) is that you usually won't be able to place components in neat rows which is also a good design practice. An example of that is @tbowmo's new gateway.
            • K
              K
              kalle
              @Cliff-Karlsson Fritzing should be a good start for a beginner and as FotoFieber said - export your design as "Gerber" files (fritzing has these function on board), zip the gerber-folder and upload it to oshpark.com.
              • A
                ahhk
                Eagle is much easier than it looks. I started a few ago with my first pcb. After looking one or two tutorials, i got my first successful schema. Just give it a try. One evening and a beer or glass of wine is enough to learn eagle.
                • AnticimexA
                  AnticimexA
                  Anticimex
                  I don't want to start another Eagle - kicad flame war here, but I would recommend kicad for the following reasons:
                  • Open source. Always the safest option if you want to use open hardware licenses (some are more demanding when it comes to tools than other)
                  • limitless in terms of board size, layers, number of holes, etc.
                  • good MySensors support in terms of common modules and components related to MySensors networks (see tbowmo's link above) (the core team uses kicad for all new "official" boards (and quite some unofficial too))
                  • tbowmoT
                    tbowmoT
                    tbowmo
                    I second on the opensource, and open hardware licenses.. I know that I can't get into any legal mumble jumble, when using kicad. And as I make use of open hardware licenses, I know that others can open / edit my files, without getting into any legal twists, due to the chosen layout program.
                    • Cliff KarlssonC
                      Cliff KarlssonC
                      Cliff Karlsson
                      I am trying to install the Kicad Mysensors library on a windows maching but don´t get it.
                      I have added
                      MYSGITHUB & https://github.com/mysensors-kicad
                      then it says I should
                      "On Windows, KiCad does not permit free-text entry to this location. Instead you have to edit your environment variables and add a "User variable" named MYSLOCAL instead (with the appropriate value)."
                      What should I do ? and are there more steps?
                      AnticimexA 1 Reply Last reply
                      • tbowmoT
                        tbowmoT
                        tbowmo
                        @Cliff-Karlsson
                        I think it was @blacey that wrote the windows specific stuff. I haven't got a windows machine (where I am allowed to install kicad). My pc simply refuses to start with windows (BSOD). So I am unable to help you on that part.
                          I have added
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @Cliff-Karlsson yes, you need to add a user variable on Windows. If you are unfamiliar with this here is a link to help you out. Replace PATH with MYSLOCAL.
                          • Cliff KarlssonC
                            Cliff KarlssonC
                            Cliff Karlsson
                            Thanks but what are the "appropriate value"?
                              AnticimexA
                              AnticimexA
                              Anticimex
                              From the text: "The path must be named MYSLOCAL and it should point out the root of your cloned libraries."
                              • Cliff KarlssonC
                                Cliff KarlssonC
                                Cliff Karlsson
                                I have tried and failed trying to add the mysensors.org items to kicad. If anyone have time I would really apricioate a step by step instruction.
                                  AnticimexA
                                  AnticimexA
                                  Anticimex
                                  @Cliff-Karlsson can you be more specific on what information you lack? There are detailed instructions in the repos for how to set it up: https://github.com/mysensors-kicad/part_management
