  3. Connecting sensor to gateway via RS485 instead of nRF24
rs485
13 Posts 5 Posters 10.9k Views 3 Watching
  • Johny MielonyJ
    Johny MielonyJ
    Johny Mielony
    @axillent looking at gateway's sketch I find it quite easy to modify for listening on serial interface, it just passes messages between interfaces.
    But how about sensors? I find it more tricky. Do I understand it right? I mainly need to modify functions in MySensor.cpp as sendWrite and process? Or there is something else?
    • axillentA
      axillentA
      axillent
      all it depends on the protocol design on your RS485 network
      Possibly are 2 scenario here:
      1. using any free design for the communication between your rs485 sensors and rs485 gateway
        It can be any existing third party design
        In this scenario you will need to make sure that your gateway will translate messages from rs485 network to match the logic of mysensors network before sending data to Vera
      2. take a look to mysensors library. you can replicate the same data exchange using rs485 instead of nordic radio
        this thay your gateway will not need a translation, it will have just to pass data between Vera and rs485 network
      sense and drive
      • Johny MielonyJ
        Johny MielonyJ
        Johny Mielony
        I don't have any protocol on RS485, I wanted to use MySensors protocol.
        Idea is that I want to replace the physical layer of transmission.
        Where I can place cables I want to place them, but where I can't do that I want to use radio.
        I'm not using Vera, I'm going to use OpenHAB on single board computer.
        I need just hint where to start.
        axillentA 1 Reply Last reply
        • Johny MielonyJ Johny Mielony
          axillentA
          axillentA
          axillent
          @Johny-Mielony just read about modbus today. Its logic is very similar to Mysensors - it have ID of the sender and ID of the reciever.
          Take a look, may be one of the modbus implementation can be used to pass mysensors data. I'm not sure it can match the need but may be it will - http://www.freemodbus.org/
          If you will succeed on this it can be a good value for the MySensors
          sense and drive
          • Johny MielonyJ
            Johny MielonyJ
            Johny Mielony
            I know about modbus. At first I thought about using it, but it's more for industrial than home use.
            I will experiment with RS485. I have some ideas, just need to find some time to test it.
            Of course I will share if I get to something useful.
            • ch3b7C
              ch3b7C
              ch3b7
              See this https://www.kickstarter.com/projects/1370454848/chainduino
              • ch3b7C ch3b7
                axillentA
                axillentA
                axillent
                @ch3b7 cool idea
                but cat5 is too much
                i just purchased a set of 6p6c connectors - phone standard
                RS485 + power requires just 4 wires
                have an idea of the set of devices to control my swimming pool
                in my idea only the master device will be integrated to Mysensors, all other will not, it will be local RS485 network
                But if Johny will be successful I will probably will connect all devices to MySensors)
                sense and drive
                • Johny MielonyJ
                  Johny MielonyJ
                  Johny Mielony
                  This chainduino looks good, but it is just arduino with on-board RS485 hardware. Still all job is done in software.
                  I'm thinking about encapsulating MySensors message into frame which will be sent via RS485 bus.
                  • ch3b7C
                    ch3b7C
                    ch3b7
                    http://sourceforge.net/p/arduino-icsc/wiki/RS-485/ this is a good library to start! now im stuck with ethernet controller in my program in .net at now i cant see any string but the gateway work good ¬¬ i need more time ^^
                    • N
                      N
                      nickma
                      Hi, Have you seen the following:
                      rs485-rs232-serial-transport-class-for-mysensors-org
                      Is that what you are looking for?
