  3. Can't get switch closed signal due to length of wire - anyway to compensate?
7 Posts 2 Posters 2.4k Views 2 Watching
  • D Offline
    drock1985
    I'm re-wiring my current doorbell/chime system and instead of the wiring running low voltage AC, I am going to use them as digital switches. I installed everything, but the doorbell does nothing. I then installed my breadboard again, using just the TACT switches as doorbell buttons, and it worked fine. So I think my problem is due to the signal not making it back to the arduino.
    Is there anyway to increase signal in a length of wire?
    My Projects
    2 Door Chime Sensor
    Washing Machine Monitor
    • D Offline
      Dirk_H
      I assume you use internal pullup from the Arduino and switch to GND with the switch?
      In this case you can try to use an external pullup (with dedicated resistor). I'd start with 1k and then try 470Ohm.
      If this does not fit your quetion, please try to make a small sketch / diagram about your actual circuit. So we can give more precise answers :)
      Greetings
      DirkH.
      • D Offline
        drock1985
        Hi @Dirk_H
        Here is the thread with my project.
        http://forum.mysensors.org/topic/2293/how-to-2-door-chime-automation-hack-thanks-petewill
        And you are correct, I am using my internal pin-up resistor currently in the sketch. Should I remove it and just add the external resistor, or add the external resistor on to it?
        My Projects
        2 Door Chime Sensor
        • D Offline
          Dirk_H
          wrote on last edited by Dirk_H
          Hi, I'd deactivate the internal pullup when using an external one. But it shouldn't really matter (the internal pullup would just be in parallel with the external one, reducing its value somewhat).
          If the external pullup does not work, please check the resistance of the wiring when button is not pressed (shuld be infinite) and when button is pressed with a multimeter.
          • D Offline
            drock1985
            I'll try that when I get home later, thanks. Where would I put the resistors in the circuit? Closer to the switch, microcontroller, or does it matter?
            My Projects
            2 Door Chime Sensor
            • D Offline
              Dirk_H
              pls do a quick (picture) search for "pullup resistor". It should become clear then. Yor are likely to put it at the microcontroller because you would need 3 cables to your door key when putting the resistor somewhere else :)
              D 1 Reply Last reply
              • D Dirk_H
                drock1985
                @Dirk_H
                Thanks for all your help. I got it to work using an external pull-up resistor. I did a check on all my wiring just to make sure all was ok, and it was. The one thing I did get was a resistance on my front doorbell on what I thought was an open circuit; then I realized there was a lamp in the button.
                This video helped explain why it works, in a way that I understand at least. https://youtu.be/wxjerCHCEMg
                Thanks again @Dirk_H
                My Projects
                2 Door Chime Sensor
