Strange problem with relay board
Hello!
The ground is separate. Relay Board takes the ground from the 12V adapter, also Arduino and the Relay Board have their own ground not connected together.
Yes, I have a 4 uF capacitor on the radio. Do you think I need to increase the capacitor? Seems like powering on/off the relays (only the led connected to the IN[1-4], the relays itself are powered via AC 12V) are creating a kind of disturb....
If I can make some tests to give more informations, let me know ;)Thanks!
Simon@xefil Hi Simon, I would make sure that you have one common ground. You could try a larger capacitor as well. Also, maybe post which specific relay board you are using. Which power supply is connected to the Raw and Gnd pins on the Arduino?
Al -
Hello @Sparkman,
This is EXACTLY the board I'm using:I've seen it has only one ground pin which is connected to the external power supply.
So, the wires are connected as follow:Relay Board:
[IN1-4] -> Arduino digital PINS
[VCC] -> Arduino 5V
[JD-VCC] -> External power supply 12V (via 7805 to obtain 5V)
[GROUND] -> External power supply 12V groundThe Arduino is actually powered on via the FT232 adapter then via USB on a 1A power supply.
I've seen that, if I remove the JD-VCC the relays are not working as expected, but the leds on the relay board, that are showing if the relay is on/off are working correctly. I mean, if I dont give power to the JD-VCC the board is working well without issues. I can send then on/off via Openhab to the relays without problems. As soon I connect the JD-VCC and I use the same relay, it stops to work after one or two tries. Seems really that the relay, powering on, creates a disturb to the antenna that brings it to stop to work. I need to reset all and then it works again for one or two times.
Any suggestion?
Thanks, Simon
[VCC] -> Arduino 5VHi. relay board need not be powered by Arduino, but from a separate power supply is 5 volts. if you eat more than 1 relay from Arduino he lacks the power to instruct the other relays, it affects his work.
As I understand it is the radio which stops working. I had similar issues which in the end made me to move to solid state relays. A few possible causes : ESD caused by the coil in the relay (you can try to change the orientation of the relay with respect to the radio) ; powerline spikes (careful layout of ground wires: no loops, solid wire, isolated vcc's ; bad components ie : fake optoisolators on the relay board ; sensitive radio.
Happy debugging ;)
Hello @vampircik and @AWI
Thanks for the replies!
I've ended adding a 220uF to the radio. This helps definetly to send the commands well. Then I've added this little hack to gain the range, posted somewhere in this forum as well:
https://www.youtube.com/watch?v=NpMnauHeR7YNow seems MORE stable. Well, it happens that turning on the first relay, the arduino reboots (takes 3 secs) and then all the other relays are working well, the first relay too. Maybe some spikes in power?
Simon
Hello @Nuubi
Sorry, as written I'm not so proof with electronic but, on the other hand, as soon I get something to work, I'm happy like a kid with his new gift :)
BTW, what do you mean exactly? I should solder some capacitor between 5V and GND? Directly on the Arduino? Which size in case?Thanks a lot!
Simon
Oh well, it can be actually extremely complicated. But, basically, add a larger cap + a small one together. Larger one acts as a power reservoir and smaller one filters high voltage spikes. Basically like that, as I understand the situation. Large ones are in the range of micro Fs, smaller ones nano Fs.
I had the same problem a few months ago.
The problem solved powering the arduino from a different power supply.
You can read a bout it hereNo more problems since
