  3. Gateway device
Gateway device
151 Posts 19 Posters 155.6k Views 21 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    @ServiceXp
    I just received the PCBs for the second prototype spin yesterday, the first spin had too many errors in the routing around SPI / UARTS so I decided to ditch it, and do a second spin. Dirtypcbs got some hickups processing my gerbers but finaly made the boards.
    I hope that I can get around to assemble one this weekend, but I can't promise anything, as I have been loaded more than 150% with work (both from my employer, and from the wife).
    RJ_MakeR 1 Reply Last reply
    • tbowmoT tbowmo
      @ServiceXp
      RJ_MakeR
      RJ_MakeR
      RJ_Make
      @tbowmo Sounds Good, Thanks for the update.
      RJ_Make
      • tbowmoT
        tbowmoT
        tbowmo
        #126
        Images of the latest pcb's (Before SMD assembly)
        Unfortunately I "injured" my back today (aah, maybe not injured, but feels like it :() so I'm on strong medics to keep the pain away. That means that didn't get around to do the SMD assembly today as I planned, as I can't sit at the desk for a longer time.. hope that it gets better during the weekend.
        • tbowmoT tbowmo
          RJ_MakeR
          RJ_MakeR
          RJ_Make
          @tbowmo Oh now that is sexy.. From someone with back problems, you take it easy for the next 3 days Sir!! :point_left:
          RJ_Make
          • tbowmoT
            tbowmoT
            tbowmo
            Aahh.. I'm back in the man-cave. Been too long since I had a chance to power up the soldering irons..
            Anyways, I've mounted the first of the second prototype spin, so next up is getting firmware written, and tested..
              @tbowmo: it looks very nice. I like the way you place components. I think I need to look more at your design and learn :wink:
              With a firmware, it looks promising :smiley:
              • tbowmoT
                tbowmoT
                tbowmo
                @scalz
                Thanks :) I hope that I at least can get some LED's flashing tonight :). And then perhaps the bootloader programmed.
                / Thomas
                • tbowmoT
                  tbowmoT
                  tbowmo
                  And we have lights..
                  https://www.youtube.com/watch?v=SHNmJMJg2b8
                    yeah :smile:
                    • tbowmoT
                      tbowmoT
                      tbowmo
                      A small update before I hit the bed tonight..
                      I've got radio up and running on the SAMD, and got the first message from one of my sensebender micros through to my pc.
                      It's still in debug mode, using a serial port on the samd as output (And my logic analyzer to decode the serial stream). So no ethernet / wifi or the like up yet.
                      The next step will be to have it use USB instead of the serial port..
                      • AnticimexA
                        AnticimexA
                        Anticimex
                        :+1: good work!
                        • sundberg84S
                          sundberg84S
                          Great! I will buy one of these as soon as this is working as you want :)
                          • alexsh1A
                            alexsh1A
                            alexsh1
                            Wow - excellent! I'd buy one
                            • tbowmoT
                              tbowmoT
                              tbowmo
                              a new small update..
                              Got it working as a serial GW.. Receiving the first messages from one of my sensebenders..
                              Also got the ethernet going, this is not integrated with the mysensors parts though, as I have to refactor nrf / ethernet libraries a bit, in order to support multiple (HW) SPI interfaces..
                              TD22057T 1 Reply Last reply
                              • tbowmoT tbowmo
                                TD22057T
                                TD22057T
                                TD22057
                                Sounds great. I'm definitely interested in using this as a gateway as well. Any chance you're going to add SPI transaction support to those libraries (more info in my post here)? I know there are RFM library versions that have that as well (see here).
                                tbowmoT 1 Reply Last reply
                                • TD22057T TD22057
                                  tbowmoT
                                  tbowmoT
                                  tbowmo
                                  @TD22057
                                  Here is more hw spi ports available on this beauty. So radio and ethernet is separated on their own spi bus. There is a 3rd spi bus available on the MYSX connector, that is at free disposal to the end user.
                                  • TD22057T
                                    TD22057T
                                    TD22057
                                    Nice - I forgot that you upgraded and weren't using a 328 processor.
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      #141
                                      A small Christmas progress update.
                                      I got external eeprom, and w5100 module running now.
                                      That means I have a working ethernet GW running with nrf24 running on SAMD.
                                      I'm waiting for rfm69 modules from China before I can verify that this part also works as expected.
                                      An ethernet GW with hw signing is using 35.988 bytes, or 13% of the available flash size, which is 256kbyte. So we have "plenty" of room to do other fun stuff on the GW
                                      • tbowmoT
                                        tbowmoT
                                        tbowmo
                                        I have updated the original posting, with updated hardware details.
                                        • Removed the ESP8266 from the feature list (It's supporting the mysensors library native).
                                        • Removed onboard SPI flash, but will probably add sdcard / micro sdcard reader
                                        • Might add battery backup for an onboard RTC.. (the SAMD have an onboard RTC, only using 2-3uA in low power RTC keep alive mode)
                                          @tbowmo: I love your project , I can't wait to try your awesome baby GW :smile:
                                          I agree with you with your updates too. RTC could be interesting.
                                          Humm, when I see price and memory, I am very tempted to update one of my sensors board with atsamL21 family to give a try...do you have an advice for a good&cheap jtag programmer???
