  3. Gateway device
Gateway device
151 Posts 19 Posters 155.0k Views 21 Watching
    yeah :smile:
    • tbowmoT
      tbowmoT
      tbowmo
      A small update before I hit the bed tonight..
      I've got radio up and running on the SAMD, and got the first message from one of my sensebender micros through to my pc.
      It's still in debug mode, using a serial port on the samd as output (And my logic analyzer to decode the serial stream). So no ethernet / wifi or the like up yet.
      The next step will be to have it use USB instead of the serial port..
      • AnticimexA
        AnticimexA
        Anticimex
        :+1: good work!
        • sundberg84S
          sundberg84S
          Great! I will buy one of these as soon as this is working as you want :)
          • alexsh1A
            alexsh1A
            alexsh1
            Wow - excellent! I'd buy one
            • tbowmoT
              tbowmoT
              tbowmo
              a new small update..
              Got it working as a serial GW.. Receiving the first messages from one of my sensebenders..
              Also got the ethernet going, this is not integrated with the mysensors parts though, as I have to refactor nrf / ethernet libraries a bit, in order to support multiple (HW) SPI interfaces..
              TD22057T 1 Reply Last reply
              • tbowmoT tbowmo
                TD22057T
                TD22057T
                TD22057
                Sounds great. I'm definitely interested in using this as a gateway as well. Any chance you're going to add SPI transaction support to those libraries (more info in my post here)? I know there are RFM library versions that have that as well (see here).
                tbowmoT 1 Reply Last reply
                • TD22057T TD22057
                  tbowmoT
                  tbowmoT
                  tbowmo
                  @TD22057
                  Here is more hw spi ports available on this beauty. So radio and ethernet is separated on their own spi bus. There is a 3rd spi bus available on the MYSX connector, that is at free disposal to the end user.
                  • TD22057T
                    TD22057T
                    TD22057
                    Nice - I forgot that you upgraded and weren't using a 328 processor.
                    • tbowmoT
                      tbowmoT
                      tbowmo
                      #141
                      A small Christmas progress update.
                      I got external eeprom, and w5100 module running now.
                      That means I have a working ethernet GW running with nrf24 running on SAMD.
                      I'm waiting for rfm69 modules from China before I can verify that this part also works as expected.
                      An ethernet GW with hw signing is using 35.988 bytes, or 13% of the available flash size, which is 256kbyte. So we have "plenty" of room to do other fun stuff on the GW
                      • tbowmoT
                        tbowmoT
                        tbowmo
                        I have updated the original posting, with updated hardware details.
                        • Removed the ESP8266 from the feature list (It's supporting the mysensors library native).
                        • Removed onboard SPI flash, but will probably add sdcard / micro sdcard reader
                        • Might add battery backup for an onboard RTC.. (the SAMD have an onboard RTC, only using 2-3uA in low power RTC keep alive mode)
                          @tbowmo: I love your project , I can't wait to try your awesome baby GW :smile:
                          I agree with you with your updates too. RTC could be interesting.
                          Humm, when I see price and memory, I am very tempted to update one of my sensors board with atsamL21 family to give a try...do you have an advice for a good&cheap jtag programmer???
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            #144
                            @scalz
                            I'm using an atmel jtagice3, with a custom PCB for converting from jtagice3 pinouts to standard cortex m0 debug connector. (have plans on selling this converter board elsewhere sometime in the future)
                            I got the jtagice3 5 years ago as a gift from atmel, for attending a course on their xmega series of MCU's. Don't know of any cheaper alternatives out there
                            • sundberg84S
                              sundberg84S
                              Hi. How far from finished is this gw? It looks awesome. My is acting fishy and I need to order a new one. I can wait some for this if you have some sort of eta.
                                oki, thx :smiley: I see for connectors..I will look if I can find a cheaper "working" alternative for atsam...
                                • tbowmoT
                                  tbowmoT
                                  tbowmo
                                  @sundberg84
                                  My best guess is that this will probably be end Q1 2016, as I have to verify RFM69, and probably have a second look at some kind of battery backup for RTC, and sdcard reader. (I have a sdcard reader breakout board, so I should be able to verify that part relatively quickly)
                                  We have also discussed this briefly in the "core team" we would like to have the next revision of the library out first, because support for the GW is only in development branch at the moment. So to minimize confusion on what branch to use for the board, we would like to have an official release that supports the board.
                                  • sundberg84S
                                    sundberg84S
                                    @tbowmo Ok thanks for a quick reply - looking forward to your gw! I will buy me a new gateway from ebay to secure my HA, but when you needs beta tester let me know as i already use dev.
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      @sundberg84
                                      I know that things are not progressing as fast with the GW. There have been some non mysensors bumps on the road, and I still have some to overcome.
                                      If it wasn't for that daytime job, that takes up too much of the precious spare time that could be used for fun hobbies like mysensors, it would have been finished a long time ago :)
                                      • sundberg84S
                                        sundberg84S
                                        Didnt mean to rush @tbowmo - it looked so good at the pictures so I thought it was ready soon!And yea... that thing called daytime job takes way to much time :)
                                        • tbowmoT
                                          tbowmoT
                                          tbowmo
                                          New comments should be in the thread over in the open hardware section here
