  3. Step-by-step procedure to connect the NRF24L01+ to the GPIO pins and use the Raspberry as a Serial Gateway (MySensors 1.x)
nrf24raspberry piraspberryraspberry nrf24l01 gpiogateway
168 Posts 47 Posters 213.0k Views 36 Watching
  • martinhjelmareM
    martinhjelmareM
    martinhjelmare
    Very nice writeup.
    One thing that comes to mind is, the latest rasbian Jessie uses systemd instead of init. It would be good if we could add a systemd unit file to the library and a description here how to use it.
      wrote on last edited by hek
      Thanks for the writeup @mfalkvidd. I'll add it to the main site when updating for the 1.6 release.
      If someone feel comfortable merging the RPi specific code to the MySensors library in the development branch, let me know. Would've been nice to have one codebase as the RPi code has diverged from Arduino quite a bit since it was created.
      A configure/autoconf is also something I'd need help with.
      • T
        tbully
        Great write-up! Should we consider instructions on how to create an init.d start/stop script so it can run as a daemon? I've done this, however, I'm having a hard time getting the output to log to syslog. (would be nice for monitoring/diagnostics purposes) The logging doesn't happen until I stop/kill the service.
        pi@homeauto01 ~ $ cat /etc/init.d/PiGatewaySerial
        #! /bin/sh
        # /etc/init.d/PiGatewaySerial
        ### BEGIN INIT INFO
        # Provides: PiGatewaySerial
        # Required-Start: $all
        # Required-Stop:
        # Should-Start:
        # Should-Stop:
        # Default-Start: 2 3 4 5
        # Default-Stop: 0 1 6
        # Short-Description: Start and stop PiGatewaySerial
        # Description: PiGatewaySerial
        ### END INIT INFO
        # The following part carries out specific functions depending on arguments.
        case "$1" in
          start)
            echo "Starting PiGatewaySerial"
            /root/Raspberry/PiGatewaySerial 2>&1 | logger &
          stop)
            echo "Stopping PiGatewaySerial"
            killall PiGatewaySerial
            echo "Usage: /etc/init.d/PiGatewaySerial {start|stop}"
            exit 1
        esac
        exit 0
        • martinhjelmareM
          martinhjelmareM
          martinhjelmare
          Doesn't the provided init script in the library already have logging? I didn't get around to testing this setup after my initial attempt failed, so I might be wrong.
          https://github.com/mysensors/Raspberry/blob/master/initscripts/PiGatewaySerial
          • GertSandersG
            GertSandersG
            GertSanders
            Excellent writeup, double plus plus good !!!
            • DidiD
              DidiD
              Didi
              @mfalkvidd
              :+1: :clap:
              • J
                J
                jkandasa
                @mfalkvidd I used direct NRF24l01+ with RPI long ago and I felt slow data transfer compare to USB-to-Serial(ttl)<-->MySensors Gateway connection. especially on OTA firmware update.
                • J jkandasa
                  Thanks. Let's add that under the other notes section.
                    Myna
                    This is a very good work !
                    Is there anything in place for RFM69 ? Would it be difficult to port the code from arduino to rpi ? (I have never coded on RPI).
                    Also, do you think any performance difference is involved in managing the radio directly from the RPI, compared to having a dedicated atmega/arduino ? Especially if a controller solution is already running on it?
                    • GertSandersG
                      GertSandersG
                      GertSanders
                      My experience: the Raspberry 2 indicates usually less then 1% processor, with very occasional maximum peaks to 15%. So I would say, Raspberry 2: no worries. My setup is Domoticz + NRF24based gateway on the same Raspi.
                      • mfalkviddM
                        My experience is on the same level as @GertSanders's - very low cpu usage.
                        I don't use RFM69 so unfortunately I have no knowledge about the feasibility to connect it directly to the Raspberry Pi.
                          tbully
                          Ugh! Correct. Also, @mfalkvidd did cover this with his "MAKE THE GATEWAY AUTOSTART" section.....If I only could read! I will test this soon to see how the logging works.
                          Finally, by enabling ser2net and adding something like this to /etc/ser2net.conf:
                          5003:raw:600/dev/ttyMySensorsGateway
                          ....you have yourself an Ethernet Gateway! Great stuff! Thanks again!
                          • M Myna
                            martinhjelmareM
                            martinhjelmareM
                            martinhjelmare
                            I've got no experience myself with rfm69 yet, but I've been thinking about it and searching the web says it should work, connecting the rfm69 to the raspberry pi, for example here:
                            https://github.com/abouillot/HomeAutomation/tree/master/piGateway
                            There are also custom pcbs for simplicity, don't know if it's tested though:
                            https://oshpark.com/profiles/thinkpeace
                            • sowardS
                              sowardS
                              soward
                              Perhaps re-word the last note from:
                              A user experienced data transfer compare to USB-to-Serial(ttl)<-->MySensors Gateway connection. especially on OTA firmware update. If you think this will cause a problem for you, an ethernet gateway might be a better alternative.
                              to:
                              A user notes that data transfer speeds are comparable to that of a USB-to-Serial(ttl)<-->MySensors Gateway connections. If you think this may be an issue for your application (e.g. OTA firmware updates), an ethernet gateway might be a better alternative.
                              thanx,
                              JpS
                              • mfalkviddM
                                @soward that wasn't quite the feedback I got, but what I wrote didn't make much sense either so I have corrected it now. Thanks!
                                  minscof
                                  wrote on last edited by minscof
                                  I have a trouble with CPU utilization when I start the gateway : 100% all the time. I use Jessie and not Wheezy on a RPI 2. Does someone can help me to troubleshoot this problem ? I have not add a decoupling capacitor , can it be the reason ?
                                  Solved : see this post
                                  C 1 Reply Last reply
                                  • M minscof
                                    C
                                    C
                                    christian
                                    This happened to me as well, I mixed up the boards I had at home and discover later it was a B+ and not a RPI2 :-) Maybe you've made the same mistake?
                                    • mfalkviddM
                                      #21
                                      @minscof got an answer in this thread: http://forum.mysensors.org/topic/2367/pigatewayserial-using-interrupts/3
                                      The high cpu usage will go away as soon as you start your controller (or something else that reads from the tty the gateway creates).
                                      • E
                                        E
                                        Eawo
                                        Is it possible to use NRF24L01+PA+LNA Antenna version or is it to power hungry? Do i have to change something in the code?
                                        • G
                                          G
                                          georgep56
                                          @Eawo If you look at the excellent original post from @mfalkvidd above:
                                          The 3.3V power on the Raspberry Pi is rated for a maximum of 50mA. A regular NRF24L01+ only needs 15mA, but if you are using a power amplified version you might exceed what the Raspberry Pi can output. In that case, an external power supply might be required.
                                          I don't believe that you will need to make any changes to code.
