  3. In wall - PCB, (AC to DC 5v)
pcbinwall
89 Posts 14 Posters 78.3k Views 24 Watching
  • sundberg84S
    sundberg84S
    Yea. Mine is about d =6,5 mm as well. Reminds of yours.
    • sundberg84S
      sundberg84S
      I ended up re-thinking this - and I think this is better.
      Now all components are located to 1 pcb, with an empty shield.
      This makes it possible to have a standard PCB and just create the shield or make one from a empty board.
      @m26872 and everyone else - my biggest consern is the distanse between the high power and rest - what do you think? Im no expert.
        Samuel235
        #22
        The issue that i personally have at the moment with locating this style of sensor behind a switch is that the slimline boxes in UK have around 15mm of room (depth) inside once the switch itself is fitted. There is slightly more room around the sides but the middle section is around 15mm. I'm now wondering how hard it would be to maybe create a slimmer version or slightly longer, say 70/75mm in length?
        MySensors 2.1.1
        • sundberg84S
          sundberg84S
          #23
          @samuel235 That is out of my leauge! 10-15mm is pretty much a PCB with the arduino on it. Adding the HLK transformer its like 20-25mm.
          Even if i would fit everything on one side the PCB and the HLK transformer should be hard to fit i think.
            Samuel235
            This is where we create stable ones for your socket boxes, then i'll attempt to lay something out in terms of design if possible for a UK version. Lets get a working and stable version of yours going first and we could take it from there i guess.
            MySensors 2.1.1
              @sundberg84: I'm not expert too, I don't know if it can help you. I hope..
              • why not move hilink a little bit on the left...is it what you are talking about? clearance between hilink and nrf? - or about fuse...maybe for fuse...pads could be a little bit smaller. it won't drain too much current so..
                if you dont move hilink, maybe increase space between thermal fuse and hilink and the route between them less straight, add a little upper angle, miter/round it a little if you want. but not too near dallastemp of course you know.I guess you want to keep your ac connector middle centered too.
              • If you want to move hilink, you can maybe change few route like this. there are better ways, sure. I have not looked longtime I hope I don't say dumb things lol, I'm not a pcb expert too. sometimes I can't get the route like I want, and the day after, hop, I see it! :laughing:
                If you have some problems sometimes to get gnd, do you use gnd plane. useful too, but not on ac lol..I think you maybe already know it.
                Will you have some holes? how do you plan to fix it inside?
                Samuel235
                #26
                So, this is what i have to contend with. Inside the socket i need to fit an arduino, nano or mini and some form of power supply (cell battery looks the only way) an nRF24L01 and then connect it to the rear of the switch. I may have to create my own board and arduino to reduce the footprint of my design to enable it to fit. Idealy i want to keep those current wires in the box but terminated, simply so if we move house all we need to do would be to remove the terminals and rewire into the switch.
                MySensors 2.1.1
                • martinhjelmareM
                  martinhjelmareM
                  martinhjelmare
                  #27
                  I've been thinking about installing a PCB with transformer in the wall myself. I like this project, but how do you feel about leaving exposed high voltage circuitry in the wall box. Normally the wires in the box should have at least one layer of insulation and splicing should be done inside insulated caps. Don't know all the correct terms in English, so I hope you understand what I mean.
                  Ideally I'd want a box for the PCB inside the wall box, but that will probably never fit. Right now my plan is to put a new box on the outside of the wall next to the coupling box up under the ceiling vertically ~ 120 cm from the wall box with the buttons for the lamps etc. But in my basement there are no coupling boxes under the ceiling, so there I'm forced to put everything inside the wall box, if I want it to look good.
                  Any other ideas?
                  S m26872M 2 Replies Last reply
                    Any other ideas?
                    Samuel235
                    @martinhjelmare In your case it would be high voltage open circuitry as you plan on running it on the existing power lines that are there currently. If i understand what you're saying anyway, am i correct? However, in my case, i plan on terminating the existing wires in a terminal block or taping them off if possible to save space, then have my sensor node running off of a custom PCB holding a custom made Arduino to save even more space and then run the whole board off of a cell coin battery.
                    MySensors 2.1.1
                    • S Samuel235
                      martinhjelmareM
                      martinhjelmareM
                      martinhjelmare
                      @samuel235
                      My worry, when having exposed high voltage circuitry inside a standard wall box, with otherwise insulated wires, is that someone else than me, for example an electrician, might poke around unknowingly in the box and get electrocuted. If you have the PCB inside a separate box with warning label, the risk is at least slightly lower.
                      S 1 Reply Last reply
                        @samuel235
                        Samuel235
                        @martinhjelmare I would agree, with your situation, and like that proposed on this PCB design (@sundberg84, please correct me if i'm wrong), like i said in my previous post. You should either conceal them or avoid using them. That is what i would advise (using UK/British rules and regulations).
                        MySensors 2.1.1
                        • sundberg84S
                          sundberg84S
                          #31
                          Maybe someone could open a own thread discussing this with a battery operated in wall node.
                          For example, someone needs to put a circiut diagram for how to operera that relay with power only from the battery.
                            Any other ideas?
                            m26872M
                            m26872M
                            m26872
                            I agree with @martinhjelmare I just assumed there would be some other insulation and it would be the second step of the design. Good you cleared this out early.
                            I think it is almost possible, but really hard, to copy the size and shape of commercial in-wall devices and still fit in all we want. Small customized PSUs may be necessary.
                            Personally I'd prefer external boxes. They could be in wall as well, as long as there's space for safe (diy) designs or even future projects.
                            • martinhjelmareM
                              martinhjelmareM
                              martinhjelmare
                              I'm thinking I'd like to try and design a custom box for 3d printing that could fit this project by @sundberg84 and also fit inside the wall box. Has this been done already and do you think it's worthwhile, i.e. is it possible?
                              • sundberg84S
                                sundberg84S
                                #34
                                What I know of, this has not been done before... not the PCB or the 3d printing.
                                Good points taken above! We need to consider this and this might not be the optimal design.
                                Maybe thought was that this design can break some ground and maybe it can lead to better and even smaller designs.
                                I like my designs easy :) Pro Minis with ready bootloaders so everyone can be inluded, but this might not be possible...
                                I will still finish my design and see how it looks.
                                • Y
                                  Y
                                  yancym
                                  Hey everyone. Been following this as I'm very interested in having this functionality with the Arduino's. I'm a newbie and have very limited knowledge with anything electrical, so forgive my ignorance. How is this problem any different than what the X10/ZWave/etc. solutions have already overcome years ago? I have an X10 wall socket that does very similar switching on/off of one socket. All the components are built inside the socket, putting the control components and the high voltage very close together. The wall switches are another example. They always have some current running thru them even when the light is switched off, to detect the signal. Again, forgive my lack of understanding how all this works, but it seems like this may not be as big of an issue as I'm reading here. Thanks.
                                    Samuel235
                                    Some awesome input here for @sundberg84's project! I would love to see your designs completed whether or not they suit other people's situations dude. Once you have completed yours then we can build from your base to create another product that would suit others. Note i said build ANOTHER product, not upgrade yours. Your's would be widely used by others, just not the ones that need it inside of a UK Sized box maybe. So, most importantly, lets help develop yours and help test it if needed.
                                    I'm going to be doing some basic designs on getting a battery powered one installed into a UK socket as my next major development in my network, so we might have a starting point by the time yours is nearing completion.
                                    If you need any input/help/testing just give us a shout ;)
                                    MySensors 2.1.1
                                    • martinhjelmareM
                                      martinhjelmareM
                                      martinhjelmare
                                      I started a new thread for my attempt at a custom box design.
                                      http://forum.mysensors.org/topic/2509/box-for-in-wall-pcb
                                        Samuel235
                                        I have also started my own thread to save me clogging your development thread up @sundberg84. I'm hoping that we can gather seperate ideas and then discuss to develop products that are a creation of many of opinions/improvements.
                                        MySensors 2.1.1
                                        • sundberg84S
                                          sundberg84S
                                          I recieved my PCB today - Yea!
                                          The good news is - its working, and it fits inside my wall socket.
                                          The bad news is that as always i will need another revision - the hole for the fuses are to close to each other.
                                          Some pictures:
                                          Anyone with any input on this?
