  3. In wall light switch node - Custom PCB
custompcbinwallnodelight switchswitch
245 Posts 15 Posters 183.6k Views 23 Watching
  • m26872M m26872
    Looks proper. I think those two 47uF caps don't necessarily have to be two and can be placed anywhere between vcc and gnd, provided short low resistance traces etc.
    Samuel235
    @m26872 - Do you feel it would be perfectly fine to remove the Capacitor thats directly on the battery then?
    MySensors 2.1.1
    • m26872M
      m26872M
      m26872
      wrote on last edited by m26872
      #26
      Either you breadboard your design first or make it a flexible pcb design.
      Add footprint and make room for bigger or more caps just in case they'll be needed. The physical place shouldn't matter.
      Edit: Since someone will object to that last sentence if I don't clarify it .... Physical place of that 47uF near nRF could matter, but if so - it should be fixed with some small low ESR cap near it instead.
      S 1 Reply Last reply
      • m26872M m26872
        Samuel235
        @m26872 So just to clarify, do i understand correctly that you're suggesting to remove the battery capacitor, keep the nRF cap in there and just allow a few VCC -> Capacitor -> GND dotted around the board to allow me to add more caps if needed?
        MySensors 2.1.1
        • m26872M
          m26872M
          m26872
          Ok. Leave the 47u near nRF as it is. Make the footprint for the other 47u one, but make it fit even a 100uF if there's room for it. Only populate if needed. And yes open footprints for 0.1uF caps dotted around is not bad either.
            Samuel235
            Awesome! I have that all sketched out now. For the passive components i have gone with a size of 0603 SMD. Would this be the cheapest? Or would 0805 be for its popularity? Cost of pense isn't really an issue for me however i would like to have a really cheap source price for this board as another positive point for it, but again its not vital.
            MySensors 2.1.1
              #30
              @samuel235: cool.
              • I think you need to learn some basic electronics basics guide, it could help you in future to understand because if you want to draw schem, it would be useful, positive feedback ;)
                I started to learn elec and uc stuff some years ago(10+), so when I say I am not electronician, it is a small lie :) I am not graduated in this field ;) but my dad, elec engineer, teached me a lot. I am lucky. Now you can have lot infos at sparkfun, adafruit, arduino ....and you are choosing the fun/interesting way, learning learning and learning.
              • like @m26872 said, it is better, and I like it too when I can, to have footprints.
              • for the batt cap, I told you this because of the cr2032 comment..it can prevent the coin cell to discharge too fast. coin cell don't like spikes, this is one of the reason for people choosing alkaline. but you can do lot of stuff with coin cell too. the cap is optional of course.
              • If you can have avrspi, better, but if no space. like you said upload bootloader, and then...if you have to reupload it later, just unsolder nrf, not big thing.
              • for 0805 or 0603, this is not a question about component cost here...it is much more a question of your soldering skills and available space of course.
                I have no problem with 0603, I handsolder some vqfn sensors (very hard stuff...), but what I would advice for noob, a step by step curve. Try 0805 first, then move harder stuff. You will see that you must be careful when soldering atmel tqfp. If all ok, then...pcb are cheap now ;) I hope you have good iron solder, thin wire....
              • m26872M
                m26872M
                m26872
                ... and flux.
                • scalzS scalz
                  @samuel235: cool.
                  Samuel235
                  @scalz - This is partially why i'm choosing to do all of this myself, I'm learning electronics while i go. Honestly, its why i have created this topic/thread so i can learn and other can tune in to learn a thing or two as well. I have that Cap wired into the battery if i need it, i will more than likely just put it in anyway to be on the safe side. I think I'm going straight into 0603 SMD tbh, I have a pretty steady hand and have some decent soldering experience. I may need to get myself a expensive/quality soldering iron, i have a cheap(ish) temperature regulated one at the moment. I'm getting some thin solder on order with the parts when i finally order it all.
                  MySensors 2.1.1
                    #33
                    cool. so, for soldering, from my own experience, but I will start to use reflow oven, what I can advise you is:
                    • find a 0.2mm tip for your iron solder. I have a great old weller. but I know someone who have bought a ts100 recently and he is very happy with it! you have large choice to power it, and we can imagine to use lipo with it for ponctual mobile soldering, far better than butane gaz iron solder!. crazy price, quality I don't know but I am very tempted to buy one...
                      http://www.banggood.com/fr/TS100-Digital-OLED-Programable-Interface-DC-5525-Soldering-Iron-Station-Built-in-STM32-Chip-p-984214.html
                    • a magnifier is a minimum I think. a cheap one is a good start. maybe a 3rd hand..
                    • thin solder. I use 0.3 but 0.5mm can work I think. Choose good quality for thin solder. some aliexpress thin solder are very bad.
                    • flux of course. very helpful. I prefer gel or liquid. I don't like aliexpress pen.
                    • desolder wick. very helpful too.
                    • tweezers like this for instance:
                      http://fr.aliexpress.com/item/6pcs-Set-VETUS-Tweezers-Anti-static-ESD-10-15-Tweezers-Set-for-Soldering-Welding-Station/32265054449.html?spm=2114.06010108.3.112.yI04vt&ws_ab_test=searchweb201556_7_79_78_77_82_80_62,searchweb201644_0,searchweb201560_4
                    • I use isopropil alcool (rubbing alcool I think) to clean my board after soldering..
                    • solder paste, optional, but helpful sometimes and funny to try
                    • lots of soldering howto on youtube
                    • scalzS scalz
                      Samuel235
                      @scalz Pretty cool list of things there! I'm going to use the soldering iron i have at the moment and see how that stands up to the task. I will be ordering a magnifier, some thin solder, a few tweezers, desolder wick and some alcohol too. I have been doing some pretty basic soldering jobs where i didn't need to pay close attention as much as this in terms of little things like cleaning up the board etc etc. I have soldered and replaced laptop motherboard power connectors and such, completed the PCB Board kits for little projects but nothing as serious as this before. So now is the time my soldering skills are going to be put to the test, and i honestly can't wait! I'm working on my board layout as we speak and i will get this uploaded soon as i am done for a update to the project.
                      MySensors 2.1.1
                        Samuel235
                        #35
                        I'm very tempted to have some jumper headers or even a dip switch on the board to allow for sketch uploads with the nRF intact. I'm hoping to get some sizings done tomorrow and if i have the room i may have the RF module on a header/socket so i can remove it while uploading a swetch. If not i will have to go with the idea of jumpers or try to rearrange the board to allow a SPI header. I shall see what i can do, upload to this build log and see what you guys think. Again, with shared input we could possibly create a much better suited board then.
                        Whats your opinions to the jumper pins across the SPI connection on the nRF module to effectivly disconnect the RF while we upload the sketch upgrades?
                        MySensors 2.1.1
                        • GertSandersG
                          GertSandersG
                          GertSanders
                          C6 should be in parallel to the battery. In the schematic you show, the C6 would disconnect the battery from Vcc (from DC point of view). If you have Vcc - C6 - battery- GND, then no DC current will flow from Vcc to GND. Is should be:
                          Vcc -+- battery -+- GND
                          Vcc -+- C6 -+- GND
                          • GertSandersG GertSanders
                            Vcc -+- C6 -+- GND
                            Samuel235
                            @GertSanders I should remove C6 from the battery to make VCC - BATT - GND. Then put it like i have done with C5, as VCC - C6 - GND. Have i understood you correctly?
                            MySensors 2.1.1
                              C6 // Batt
                              one side of C6 to VCC/Vbat
                              other side of C6 to GND
                              • scalzS scalz
                                C6 // Batt
                                Samuel235
                                #39
                                @scalz said:
                                C6 // Batt
                                Thank you for confirming that Scalz, i'll get that updated tonight :)
                                MySensors 2.1.1
                                • GertSandersG
                                  GertSandersG
                                  GertSanders
                                  @samuel235 you understand correctly :-)
                                    Samuel235
                                    I have added a ISP header, 100uF cap through-hole footpads, i may remove one of the two 47uF caps, don't feel i will need two 47's and a 100, i'll keep the pads there for it but wont add it just yet.
                                    I'm now just playing around with the layout of the board, at the moment i have it down to around 1.2inches by 2.8inches. It would be alot slimmer if i didn't have a 24mm batt onboard. However i don't want to be changing the battery every month, so i opted for the bigger size of the batteries. Once i have the layout, i'll do some drawings and models of this to enable me to see if it will fit my application.
                                    The RF module is adding to the overall size because i'm trying not to have it mounted over the top of anything as adviced to reduce chance of interference.
                                    I will get some images up tomorrow for an update to this build log.
                                    MySensors 2.1.1
                                      Samuel235
                                      Current situation:
                                      I'm really struggling with the composition of the board to enable me to fit this into the slim socket back box, I'm now giving it a thought to mount the radio over the board. However this is still coming VERY tight to fitting, mainly because of the size of the switch i have chosen, it extrudes quite a way back into the box (as shown in the Sketchup model in the original post, at the top of this page). I only have 11mm behind the middle of the box, the battery mounted plus the board and plus 5mm mounted capacitor (applicable in the first image shown below where the radio is overhanging the edge of the board) would equal around 12mm, so even at an angle i don't think this board would fit in there.
                                      So that is why i looked at the idea of moving the cap out of the way to the other side of the board, putting the radio down onto the bottom of the board but keeping its orientation. I think this may reduce the thickness of the overall package slightly, will still be very tight (within 1mm i think), but a possibility it would fit (maybe). Shown in the design layout below. I think if i could remove the black plastic standoffs on the header for the radio and mount it practically touching the board itself then i may have a chance to get it in.
                                      First of all, do you think that there would be any issues with the layout i have placed in the second design? As far as I can see i have done the main things like keeping the caps next to what they are intending to protect, kept under the radio board clean, have 1 x 100uF cap for spikes on radio and 2 47uF cap's for additional large spikes, 0.1uF caps are dotted around the bottom to reduce small spikes, managed to get a SPI and FTDI header included with all the resistors and caps needed.
                                      The last few days I'm sitting at the stage of just rearranging the design to fit into my environment, I may have to change the backbox if needed but i would prefer to manufacture the board to fit into the smaller space if possible. but if physical limitations are there that is impossible to work around it would leave this as the only resort.
                                      MySensors 2.1.1
                                        Samuel235
                                        As the night draws to a close, it would appear i have found the physical sizing issue solution! Now, just for the routing to be done. Another stage, another day! As this project gets closer to a completed board, the more I get excited about the manufacturing of my first ever useful custom made PCB. After all, this is what a community built project is all about, experienced users helping armatures become experienced to help armatures, isn't it? I'd like to just take this post to thank everyone that assisted me so far with this project!
                                        The remaining steps:
                                        • Add MySensors' logo/branding to the board.
                                        • Complete the routing of the board.
                                        MySensors 2.1.1
                                          Samuel235
                                          Good morning guys, just to keep the topic updated with the latest info on this project;
                                          I'm still currently designing the board, trying to move parts around and route the traces. Because of everything being so cramped I'm having a real hard time getting this done. I'm having a couple of issues here where i can't get traces from certain points (top left corner) out and around the through-hole components so i will need to be moving some things around again, but I'm constantly pushed on a cramped space to physically get this into the light switch. One of the biggest issues i have is the terminal block, I may remove this and just end up soldering the switch cable directly to the board. The other issue i have is a software issue with eagle and ITead manufacturer, I'm creating routes with >8mil thickness (the website says that 6mil is minimum), then using their checking DRC file, and its throwing back errors relating to the trace width, however if i create the traces in 10mil its fine. However, there is just no way at all i can get away with 10mil :(
                                          Today's agenda:
                                          • Remove screw terminals.
                                          • Relocate the micro controller under the nRF board, not under the antenna section though.
                                          • Relocate some of the components around the top of the board to allow traces through.
                                          If i could get some feedback from you guys on the following, it would be appreciated.
                                          • Do you think I might be able to route/trace on the bottom layer under the antenna section (Antenna will be sitting about 2-5mm above the top layer) without receiving interference.
                                          • What do you think about my DRC Check errors? ITead say >6mil but i get errors on 8.5/9mil.
                                          MySensors 2.1.1
