  3. MQTTGateway does not seem to start broker
8 Posts 4 Posters 3.0k Views 3 Watching
  • dakkyD
    dakkyD
    dakky
    wrote on last edited by dakky
    Hello
    I sucessfully uploaded the mqtt gateway example. The host is reachable from the network => w5100 seems to work fine.
    $> ping 192.168.111.1
    PING 192.168.111.1 (192.168.111.1) 56(84) bytes of data.
    64 bytes from 192.168.111.1: icmp_seq=1 ttl=128 time=0.092 ms
    64 bytes from 192.168.111.1: icmp_seq=2 ttl=128 time=0.091 ms
    Serial monitor states:
    Ok!
    so everthing seems fine in my eyes. BUT: the mqtt broker seems not to start. nmap/telnet to 192.168.111.1:1883 fails and a mosquitto_pub/sub does time out after a while.
    $> mosquitto_sub -v -t \$SYS/# -h 192.168.111.1
    Error: Connection timed out
    Any idea how to debug this problem?
    EDIT: I used MySigningNone signer; because debug + spi + signing does not fit on an arduino uno :(
    Controller: Raspberry Pi 2 :: Openhab2 :: with @TimO MySensors Binding
    Gateway: Arduino MEGA 2560 R3 :: W5100 :: Ethernet GW
    Software: MySensors 2.0development
      Samuel235
      First of all, could you provide the software guys here with more information to enable them to assist you. Information like; what hardware are you using, what version of MySensors are you using, what sketch is it.
      This will hopefully make the debugging job easier.
      MySensors 2.1.1
      • dakkyD
        dakkyD
        dakky
        hurm you're right ;)
        some facts:
        • arduino uno R3
        • mysensors 1.5 (master)
        • sketch is the example mqtt gateway + custom IP + signing enabled (MySigningNone)
          http://www.mysensors.org/build/mqtt_gateway
        • G
          G
          giova
          I have same problem on arduino one clone-w5100-mysensors 1.5-sketch is the example mqtt gateway.
          Can someone post a simply and working sketch of mqtt gateway??
            Mihai
            I succeed to get a working system using MySensors with MQTT Gateway and Home Assistant, details here: https://github.com/Mihai258/HomeAssistant-MySensors-MQTT, or you may wait for the future release of MySensors who may work with any external mqtt broker, like mosquitto.
            G 2 Replies Last reply
            • M Mihai
              G
              G
              giova
              @Mihai thanks for your reply, I read only today. I will try your sketch and tell you my results.
              • M Mihai
                G
                G
                giova
                @Mihai It works!! Thank you very much.
                Giovanni
                  Mihai
                  You very welcome! I am happy that my work is useful for somebody else, you are the first with a feedback, so I am also happy about this. I hope my examples are simple and clear enough to build any sensor combination you need.
