  3. Air Quality Sensor
Air Quality Sensor
calibrationaqigas sensorhchoair quality
270 Posts 46 Posters 452.5k Views 35 Watching
  • epierreE
    epierreE
    epierre
    #112
    @Rasenheizung if you base yourself on my template here https://github.com/empierre/arduino/blob/master/AirQuality-Multiple_Gas_Sensor1_4.ino
    H2
    1.3 50
    0.8 100
    0.28 400
    0.16 1000
    0.05 4000
    y = 73.59123879 x-1.355617483
    Residual Sum of Squares: rss = 87393.44418
    H2Curve[3] = {73.5912, -1.355617};
    CO
    1.6 50
    1 100
    0.39 400
    0.21 1000
    0.09 4000
    y = 99.27731641 x-1.513643469
    Residual Sum of Squares: rss = 43168.87424
    COCurve[3] = {99.27731, -1.51364};
    CO is a dangerous gas, the MQ7 is very sensitive to many things and no calibration too... for a serious work please think about using the MICS-6814 that is calibrated, includes 3 gases out of the box, and is very low consumption (can run on battery !)
    https://github.com/empierre/arduino/blob/master/AirQuality-CO-NO2-NH3.ino
    z-wave - Vera -> Domoticz
    • B
      B
      bhavika
      What is the pre-heating time for TGS2442???
      epierreE 1 Reply Last reply
      • B bhavika
        epierreE
        epierreE
        epierre
        #114
        from datasheet: "the sensor’s resistance reaches to 90% of its final value in less than one minute"
        • B
          B
          bhavika
          So what is the conditioning period for testing in it??? It is two days.. What does it mean??
          • B bhavika
            epierreE
            epierreE
            epierre
            #116
            on this kind maybe to have it powered for a full two days to burn out the production "dusts" that may remain in.
            those sensors are not good science, see the correlation of gases they are reported for in the datasheet
            • epierreE
              epierreE
              epierre
              a very sensitive HCHO module you can see a demo here: http://www.seeedstudio.com/recipe/379-a-handheld-hcho-detector.html?utm_source=EDM&utm_medium=EDM&utm_campaign=EDM20150930
              https://github.com/empierre/arduino/blob/master/AirQuality-HCHO.ino
              • paqorP
                paqorP
                paqor
                I have a question for the MQ135. Do not always be above 500 ppm, the measured values? I also get values of 0. I suspect that it is due to the conversion. The values vary greatly. Is that normal? I get the values with an ordinary power supply. mq135 werte.PNG
                • paqorP
                  paqorP
                  paqor
                  wrote on last edited by paqor
                  #119
                  • HeinzH
                    HeinzH
                    Heinz
                    Looks strange, could you supply your code?
                    Btw the sensor draws a lot of current, the power supply should be able to deliver 1A. Did you burn in the sensor for 12-24 hours?
                    • paqorP
                      paqorP
                      paqor
                      I have used the code from epiere. Baking I have not done. I use different power supplies (USB, Samsung and a large controllable power supply). I sometimes feel that contacts do not function properly. But the sensor draws but only about 100 mA = 0.1 A? Then it seems to be on branding. I have three new sensors. Mostly we read that it is only an attempt here is to measure the CO2 content. When I check the values with a measuring instrument with which agree the details here https://olimex.wordpress.com/2015/05/26/experimenting-with-gas-sensors-and-arduino/ Branding should work outdoors? Can you show me a chart or values?
                      • paqorP
                        paqorP
                        paqor
                        • HeinzH
                          HeinzH
                          Heinz
                          I used this library:
                          https://github.com/GeorgK/MQ135
                          Together with this description:
                          https://hackaday.io/project/3475-sniffing-trinket/log/12363-mq135-arduino-library
                          Simple to use and very good explanations.
                          • paqorP
                            paqorP
                            paqor
                            I've read about. It sounds interesting.
                            I stand a little hard with the development. Is there a skit for MQ135.h and MYSENSORS?
                            I will test this afternoon.
                            • HeinzH
                              HeinzH
                              Heinz
                              Hi @paqor,
                              I wrote a little sketch which you could use as a start, it uses the MQ135 library.
                              I also used a timer library, but this could be replaced by a simple sleep, too.
                              RZERO should be changed when calibrating the sensor, this can be done at compile-time or during runtime by sending the value to the sensor via the gateway.
                              Unfortunately I could not test the sketch yet, but it should help you getting started.
                              If you have a second sensor which provides humidity and temperature then you can also get the corrected ppm from the library,...
                              good luck!
                              MQ135 MySensor
                              A0      white
                              D0      black
                              GND     brown
                              5V      red
                              #include <MQ135.h>
                              #include "Timer.h"
                              Timer timer;
                              // 30 seconds
                              #define TEMP_UPDATE_INTERVAL 30000
                              // MQ135
                              #define CHILD_ID_CO2 0
                              #define CHILD_ID_R0 1
                              #define CO2_SENSOR_ANALOG_PIN 0
                              /// Calibration resistance at atmospheric CO2 level
                              #define RZERO 300.0
                              #define EEPROM_R0 0
                              MQ135 gasSensor = MQ135(CO2_SENSOR_ANALOG_PIN, RZERO);
                              int lastC02;
                              float lastR0;
                              // MySensor
                              MyMessage msgCO2(CHILD_ID_CO2, V_VAR1);
                              MyMessage msgR0(CHILD_ID_R0, V_VAR1);
                                  gw.sendSketchInfo("MQ135 Sensor", "1.0");
                                  gw.present(CHILD_ID_CO2, S_AIR_QUALITY);
                                  gw.present(CHILD_ID_R0, S_CUSTOM);
                                  uint8_t R02 = gw.loadState(EEPROM_R0);
                                  // get R0 from EEPROM
                                  float R0 = R02 * 2;
                              	// do a plausibility check
                                  if (R0 > 1.0 && R0 < 400.0)
                                      Serial.print(F("Setting R0 from EEPROM: "));
                                      Serial.print(F("Setting default R0: "));
                                      R0 = RZERO;
                                  Serial.print(R0);
                                  Serial.println(F(""));
                                  gasSensor.setR0(R0);
                                  timer.every(TEMP_UPDATE_INTERVAL, timerHandler);
                              bool MQ135Changed()
                                  bool changed = false;
                                  lastR0 = gasSensor.getRZero();
                                  Serial.print(F("R0: "));
                                  Serial.println(lastR0);
                                      float ppm = gasSensor.getPPM();
                                      Serial.print(F("CO2 ppm: "));
                                      Serial.print(ppm);
                                      int roundedPpm = (int)ppm;
                                      Serial.print(F(" --> "));
                                      Serial.println(roundedPpm);
                                      if (roundedPpm != lastC02)
                                          lastC02 = roundedPpm;
                                          changed = true;
                                  return changed;
                              void timerHandler()
                                  bool airQualityChanged = MQ135Changed();
                                  if (airQualityChanged)
                                      gw.send(msgCO2.set(lastC02));
                                      gw.send(msgR0.set(lastR0, 2));
                                  timer.update();
                              // Gets the R0 value from the gw passes ot to the lib and stores it into the EEPROM.
                              void incomingMessage(const MyMessage& message)
                                  Serial.println(F("Incoming Message:"));
                                  if (message.isAck())
                                  uint8_t sensor = message.sensor;
                                  if (sensor == CHILD_ID_R0)
                                      float R0 = message.getFloat();
                                      Serial.print(F("Incoming R0: "));
                                      Serial.print(R0);
                                      gw.saveState(EEPROM_R0, (uint8_t)(R0/2));
                                      gw.send(msgR0.set(R0, 2));
                              • paqorP
                                paqorP
                                paqor
                                #126
                                I have compiled from various sources themselves something. The result is https://gleisnetze.de/2015/12/25/das-erste-kleine-programm/ described herein. The most plausible values I received with the MQ135.h library. For that I have then added the transfer after MySensors / FHEM.
                                • B
                                  B
                                  bhavika
                                  Hello
                                  In MiCS 2614 or in any gas sensor. what should be the value of R0... Because in datasheet they mentioned that value is measured in ambient condition. Any default value for that??
                                  • B bhavika
                                    Hello
                                    epierreE
                                    epierreE
                                    epierre
                                    @bhavika said:
                                    Hello
                                    The datasheed propose the "clean air calibration": "Sensing resistance in air R0 is measured under controlled ambient conditions, i.e. synthetic air at 23 ±5°C and 50 ± 10% RH. Sampling test."
                                    so you should go outside and mesure the defautl R0 value in your environment.
                                    • HeinzH
                                      HeinzH
                                      Heinz
                                      MQ-135 with 10k results in a R0 of around 360 in my environment. So you could start experimenting with values around 300-500. I had to use a voltage regulator to get reliable values from the sensor.
                                      • epierreE
                                        epierreE
                                        epierre
                                        #130
                                        a little update on the MICS-6814:
                                        NO2: sensible
                                        CO: flat
                                        NH3 flat
                                        For the HCHO:
                                        sorry for the flat part, some arduino issues at this time
                                        • mfalkviddM
                                          Welcome @betthorn, great to have you here.
