  3. Nano vs uno
Nano vs uno
6 Posts 5 Posters 2.7k Views 3 Watching
  • T
    Terence Faul
    Screen Shot 2015-12-19 at 13.46.46.png Screen Shot 2015-12-19 at 13.39.07.png
    Please help. I have been working with the relay sketch and uploaded to the nano and had no problem. That is the first image.
    Then uploaded to the uno and could not get it to work. The second image is the serial output.
    Domotiz detects the sensor perfect on the nano, but not the uno. Am I missing something
    • sundberg84S
      sundberg84S
      In the second the sensors does not recieve a nodeID from your controller.
      Maybe you can watch the gw during this discover process and see if its the radiotraffic not getting to the gw.
      Many times its a power problem if the radio fails... might be different power ratings from your uno/nano and thats why its not working,
      • martinhjelmareM
        martinhjelmareM
        martinhjelmare
        It's trying to find a parent, request for nodeID comes after that, I think. But seems like a radio comm issue, all the same. There are three failed sends even for the Nano in the first image.
        Try adding a capacitor to the radio.
        Try a different radio.
        Try a different power source for the radio.
        I guess the problem could be on either end also, or can we rule that out somehow?
        • H
          H
          HarryDutch
          You could try to enter the node id in your sketch instead of asking the controller for a node id. Maybe clearing you EEPROM first will help too.
          gw.begin(NULL,190)
          (190 is just an example of an id)
          • martinhjelmareM
            martinhjelmareM
            martinhjelmare
            It's not requesting node id. It's looking for its parent, internal message type 7. Node id request is type 3.
            • HeinzH
              HeinzH
              Heinz
              Sometimes clearing the EEPROM helps:
              http://www.mysensors.org/build/debug
