  3. Relay_Actuator add second relay?
9 Posts 5 Posters 3.4k Views 6 Watching
  • Cliff KarlssonC Offline
    Cliff Karlsson
    I have just got the 110v-230v AC to Mysensors PCB board working but I want to add another raley to PIN 5, how do I do that?
     * Version 1.0 - Henrik Ekblad
     * Example sketch for a "light switch" where you can control light or something
     * else from both HA controller and a local physical button
     * (connected between digital pin 3 and GND).
     * This node also works as a repeader for other nodes
     * http://www.mysensors.org/build/relay
    #define MY_REPEATER_FEATURE
    #define RELAY_PIN  3  // Arduino Digital I/O pin number for relay
    #define BUTTON_PIN  4  // Arduino Digital I/O pin number for button
    #define RELAY_ON 1
    #define RELAY_OFF 0
    Bounce debouncer = Bounce();
    int oldValue=0;
    bool state;
      // Setup the button
      pinMode(BUTTON_PIN,INPUT);
      // Activate internal pull-up
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
      pinMode(RELAY_PIN, OUTPUT);
      state = loadState(CHILD_ID);
    void presentation()  {
      present(CHILD_ID, S_LIGHT);
    *  Example on how to asynchronously check for new messages from gw
      debouncer.update();
      // Get the update value
      int value = debouncer.read();
      if (value != oldValue && value==0) {
          send(msg.set(state?false:true), true); // Send new state and request ack back
      oldValue = value;
      if (message.isAck()) {
         // Change relay state
         state = message.getBool();
         // Store state in eeprom
         saveState(CHILD_ID, state);
      Cliff Karlsson
      wrote on last edited by Cliff Karlsson
      I Started experementing with:
      #define RELAY1_PIN  4  // Arduino Digital I/O pin number for relay
      #define RELAY2_PIN  5  // Arduino Digital I/O pin number for relay
      #define BUTTON_PIN  3  // Arduino Digital I/O pin number for button
      #define CHILD1_ID 1   // Id of the sensor child
      #define CHILD2_ID 2
      #define RELAY1_ON 1
      #define RELAY1_OFF 0
      #define RELAY2_ON 1
      #define RELAY2_OFF 0
      int oldValue=0;
      bool state;
      MyMessage msg(CHILD1_ID,V_LIGHT);
      MyMessage msg(CHILD2_ID,V_LIGHT);
        // Setup the button
        digitalWrite(RELAY1_PIN, RELAY1_OFF);
        pinMode(RELAY1_PIN, OUTPUT);
        digitalWrite(RELAY2_PIN, RELAY2_OFF);
        pinMode(RELAY2_PIN, OUTPUT);
        state = loadState(CHILD1_ID);
        digitalWrite(RELAY1_PIN, state?RELAY1_ON:RELAY1_OFF);
         state = loadState(CHILD2_ID);
        digitalWrite(RELAY2_PIN, state?RELAY2_ON:RELAY2_OFF);
        sendSketchInfo("Relays & Button", "1.0");
        present(CHILD1_ID, S_LIGHT);
        present(CHILD2_ID, S_LIGHT);
        debouncer.update();
        oldValue = value;
      But first of all I dont know what do do with the button, I want to be able to control one of the relays with the button. Second is this part at the end:
      How would I adapt that to the usage of two relays?
      • N Offline
        N Offline
        niccodemi
        Check this thread
        • Michel - ItM Offline
          Michel - It
          wrote on last edited by Michel - It
          Optimus Prime Solution
          //#include "Bounce2.h"
          #define RELAY_ON 0                      // switch around for realy HIGH/LOW state
          #define RELAY_OFF 1
          #define RADIO_ID 13           // radio Id, whatever channel you assigned to
          #define noRelays 2
          const int relayPin[] = {4,5};          //  switch around pins to your desire
          const int buttonPin[] = {6,7};      //  switch around pins to your desire
          class Relay   // relay class, store all relevant data (equivalent to struct)
          public:
            int buttonPin;                   // physical pin number of button
            int relayPin;             // physical pin number of relay
            byte oldValue;                    // last Values for key (debounce)
            boolean relayState;               // relay status (also stored in EEPROM)
          Relay Relays[noRelays];
          Bounce debouncer[noRelays];
          MyMessage msg[noRelays];
          void setup(){
              gw.begin(incomingMessage, RADIO_ID, true);
              delay(250);
              gw.sendSketchInfo("Multy-Relay&Pulsanti", "0.");
              delay(250);
              for (int i = 0; i < noRelays; i++){
              Relays[i].buttonPin = buttonPin[i];              // assign physical pins
              msg[i].sensor = i;                          // initialize messages
              msg[i].type = V_LIGHT;
              debouncer[i].interval(5);
              Relays[i].relayState = gw.loadState(i);                                   // retrieve last values from EEPROM
              digitalWrite(Relays[i].relayPin, Relays[i].relayState? RELAY_ON:RELAY_OFF);   // and set relays accordingly
              gw.send(msg[i].set(Relays[i].relayState? true : false));                  // make controller aware of last status
              gw.present(i, S_LIGHT);    // present sensor to gateway
              delay(250);
              for (byte i = 0; i < noRelays; i++){
              debouncer[i].update();
              byte value = debouncer[i].read();
              if (value != Relays[i].oldValue && value == 0){
              digitalWrite(Relays[i].relayPin, Relays[i].relayState?RELAY_ON:RELAY_OFF);
              gw.saveState( i, Relays[i].relayState );}                 // save sensor state in EEPROM (location == sensor number)
                  Relays[i].oldValue = value;
          // process incoming message
          void incomingMessage(const MyMessage &message){
                  if (message.type == V_LIGHT){
                  if (message.sensor <noRelays){            // check if message is valid for relays..... previous line  [[[ if (message.sensor <=noRelays){ ]]]
                  digitalWrite(Relays[message.sensor].relayPin, Relays[message.sensor].relayState? RELAY_ON:RELAY_OFF); // and set relays accordingly
                  gw.saveState( message.sensor, Relays[message.sensor].relayState ); // save sensor state in EEPROM (location == sensor number)
          • rchampR Offline
            rchampR Offline
            rchamp
            @Michel--
            Many Kudos.
            i tried your code modified for my single relay and button pushes successfully trigger the relay! I'm also reading status correctly in Vera. :)
            I am having some trouble controlling the relay from Vera. It appears as if the msgs from Vera aren't a) being received by the node, b ) not interpreting the node
            I'm new to programming and not too sure of where to look.
            Any Suggestions?
            #define RELAY_PIN  4  // Arduino Digital I/O pin number for relay
            #define RELAY_ON 0
            #define RELAY_OFF 1
            int oldValue=0;
            bool state;
              gw.begin();
              gw.sendSketchInfo("Relay & Button", "1.0");
             // Setup the button
              gw.present(CHILD_ID, S_LIGHT);
              state = gw.loadState(CHILD_ID);
              debouncer.update();
                  gw.send(msg.set(state?false:true), true); // Send new state and request ack back
              oldValue = value;
                 gw.saveState(CHILD_ID, state);
            • rchampR Offline
              rchampR Offline
              rchamp
              I wanted to clarify that i got it working.
              I was browsing through the MySensors API and came across the Processing incomming messages section.
              What I interpreted out of the explanation there is that a node acting as a relay actuator NEEDS to be configured as a repeater node in order to run the code needed to interpret incoming messages.
              I kept removing the parameters in gw.begin() to make the node a non repeater because i have such a short range between my gateway and the node. Once i updated my sketch to configure the node as a repeater... BOOM! we're up and running!
              I did notice when configuring this node in Vera, that i needed to cycle the sensor 3 times to be fully operational. My steps were as follows:
              1. Delete node and light objects from vera. then Reload Vera.
              2. Run inclusion on gateway
              3. turn on node
              4. power cycle node to auto configure light object in vera to display on/off buttons and get sketch name and node details.
              5. power cycle node one more time. this seemed to get the sensor and Vera to sync up and report state properly back to UI5. after this everything was working wicked smooth.
              Now i need to work on adding in my DIY soil sensor in.
              I hope my resolution may help any other newbies in the world of this wonderful MySensors journey!
              • rchampR rchamp
                3. turn on node
                martinhjelmareM Offline
                martinhjelmare
                @rchamp
                Calling gw.process in the loop and not sleeping should be sufficient for a relay. It shouldn't have to be configured as a repeater.
                rchampR 1 Reply Last reply
                  @rchamp
                  rchampR Offline
                  rchampR Offline
                  rchamp
                  @martinhjelmare
                  thank you. i corrected my code to not enable as a repeater
                    Michel - It
                    solution vera
                    http://forum.mysensors.org/topic/799/my-relay-module
                    12.1k
