  3. Array Relay Button Actuator
45 Posts 16 Posters 31.0k Views 16 Watching
    maglo18
    In yours sketch state button should high next low then relay change state. I want to have possibility after button HIGH relay state change button LOW state relay change again
    • J
      J
      jemish
      yes , I have same problem.
      how can we use simple wall switch with relay to ON and OFF the lights.
      • AWIA
        AWIA
        AWI
        For learning purposes: Instead of coding it for you, try the line of thought:
        Now it changes with the toggle, so if "value" (switch) becomes high is changes the state of the relays, send the message to controller and stores it in EEPROM.
        If you use a normal switch, you should change the state if when the "value" changes. So remember the last state of the switch and make it happen ;-)
        btw :you need a variable to store the last button state and the physical position of the switch does not change if you update the relay switch from the controller..
        • jeylitesJ
          jeylitesJ
          jeylites
          Just wondering any of you guys made progress in normal switch?
          • R
            R
            rainair
            Hello this is my first post, but i follow my sensors for about 2 months.
            Excuse my bad english.
            For those how want use a normal in wall switch
            just change the line:
            if (value != Relays[i].oldValue && value == 0){
            to
            if (value != Relays[i].oldValue){
            to
            hope this was a bit helpfully
            • jeylitesJ
              jeylitesJ
              jeylites
              wrote on last edited by jeylites
              #22
              @rainair, I tested it and it works! Thanks!!!
              • G
                G
                gonzalonal
                @jeylites said:
                Relays[i].relayState = gw.loadState(i); // retrieve last values from EEPROM
                digitalWrite(Relays[i].relayPin, Relays[i].relayState? RELAY_ON:RELAY_OFF); // and set relays accordingly
                gw.send(msg[i].set(Relays[i].relayState? true : false)); // make controller aware of last status
                gw.present(i, S_LIGHT); // present sensor to gateway
                delay(250);
                It's my idea, or shouldn't the sensor be presented to the gateway before sending it status?
                Thanks! regards.
                • jeylitesJ
                  jeylitesJ
                  jeylites
                  @gonzalonal
                  I don't think it matters. You could try flip "gw.send & gw.present" and see how it respond to the change.
                  • E
                    E
                    ewgor
                    Wow ! this is what i was looking for ... Could anyone please share with us some Openhab settings for this wonderful Arduino sketch?
                    How can we assign in OH buttons to correspond to the physical buttons on the breadboard ?
                    Looking for any answer.
                    Thanks all!
                    • Cliff KarlssonC
                      Cliff KarlssonC
                      Cliff Karlsson
                      How would I update this to work with 1.6?
                      N 1 Reply Last reply
                        N
                        N
                        niccodemi
                        @Cliff-Karlsson I recently started using 1.6 version, below is converted sketch. It works with momentary (pushbuttons) switches only.
                        Does anyone have sketch for toggle switches?
                        #define MY_REPEATER_FEATURE
                        #define RELAY_ON 0                      // switch around for relay HIGH/LOW state
                        #define RELAY_OFF 1
                        #define noRelays 2                     //2-4
                        const int relayPin[] = {14,15};          //  switch around pins to your desire
                        const int buttonPin[] = {3,4};      //  switch around pins to your desire
                        class Relay             // relay class, store all relevant data (equivalent to struct)
                        public:
                          int buttonPin;                   // physical pin number of button
                          int relayPin;             // physical pin number of relay
                          byte oldValue;                    // last Values for key (debounce)
                          boolean relayState;               // relay status (also stored in EEPROM)
                        Relay Relays[noRelays];
                        Bounce debouncer[noRelays];
                        MyMessage msg[noRelays];
                        void setup(){
                            sendHeartbeat();
                            wait(250);
                            for (int i = 0; i < noRelays; i++){
                            Relays[i].buttonPin = buttonPin[i];              // assign physical pins
                            msg[i].type = V_LIGHT;
                            debouncer[i].interval(5);
                            //digitalWrite(Relays[i].relayPin, RELAY_OFF);
                            wait(250);
                            Relays[i].relayState = loadState(i);                               // retrieve last values from EEPROM
                            wait(250);
                        void presentation()  {
                              sendSketchInfo("MultiRelayButton", "0.9f");
                              wait(250);
                            for (byte i = 0; i < noRelays; i++){
                            debouncer[i].update();
                            byte value = debouncer[i].read();
                            if (value != Relays[i].oldValue && value==0){
                            digitalWrite(Relays[i].relayPin, Relays[i].relayState?RELAY_ON:RELAY_OFF);
                            saveState( i, Relays[i].relayState );}                 // save sensor state in EEPROM (location == sensor number)
                                Relays[i].oldValue = value;
                        // process incoming message
                        void receive(const MyMessage &message){
                           if (message.type == V_LIGHT){
                           if (message.sensor <noRelays){            // check if message is valid for relays..... previous line  [[[ if (message.sensor <=noRelays){ ]]]
                           digitalWrite(Relays[message.sensor].relayPin, Relays[message.sensor].relayState? RELAY_ON:RELAY_OFF); // and set relays accordingly
                           saveState( message.sensor, Relays[message.sensor].relayState ); // save sensor state in EEPROM (location == sensor number)
                        • jeylitesJ
                          jeylitesJ
                          jeylites
                          #28
                          The following sketch has got what you're looking for. Hope that helps.
                          Relay With Actuator Switch Toggle
                          #define RELAY_ON 0                      // switch around for realy HIGH/LOW state
                          #define RELAY_OFF 1
                          #define RADIO_ID 11                    // Radio ID, whatever channel you assigned to
                          #define noRelays 6
                          const int relayPin[] = {A0, A1, A2, A3, A4, A5};
                          const int buttonPin[] = {3, 4, 5, 6, 7, 8};
                          public:
                          void setup(){
                          	gw.begin(incomingMessage, RADIO_ID, true);
                          	delay(250);
                          	gw.sendSketchInfo("MultiRelayButton", "0.9b");
                          	delay(250);
                          	delay(250);
                          //	if (value != Relays[i].oldValue && value == 0){
                          	gw.saveState( i, Relays[i].relayState );}                 // save sensor state in EEPROM (location == sensor number)
                          void incomingMessage(const MyMessage &message){
                                  if (message.sensor <noRelays){ 	 // check if message is valid for relays..... previous line if [[[ (message.sensor <=noRelays){ ]]]
                                  gw.saveState( message.sensor, Relays[message.sensor].relayState ); // save sensor state in EEPROM (location == sensor number)
                          • N
                            N
                            niccodemi
                            @jeylites Thanks, toggle switch works but there is issue when node boots / restarts. On 1st restart relays stay OFF, on 2nd come ON, on 3rd again OFF and so on. It seems that whatever happens during Setup is reversed in Loop. Hopefully someone can point out what should be changed in modified sketch.
                            #define RELAY_OFF 1
                            public:
                            void setup(){
                                sendHeartbeat();
                                wait(250);
                                wait(250);
                                wait(250);
                                  sendSketchInfo("MultiRelayButton", "0.9g");
                                  wait(250);
                            these are screenshots from restarts
                            reboot1
                            reboot2
                            • N niccodemi
                              #define RELAY_OFF 1
                              public:
                              void setup(){
                                  sendHeartbeat();
                                  wait(250);
                                  wait(250);
                                  wait(250);
                                    wait(250);
                              reboot1
                              reboot2
                              martinhjelmareM
                              martinhjelmareM
                              martinhjelmare
                              #30
                              @niccodemi
                              Hi!
                              I think the problem is you're not initializing oldValue to anything. It will then always be different than value in the loop, and state will change.
                              You should set oldValue to the same "state" as the loaded relayState in setup. Even better, only use relayState, and make it an int. You can do the same boolean evaluations anyway. 1 is true and 0 is false.
                              Edit:
                              Sorry, I forgot that this is a pushbutton, right? Then you should just make sure that oldValue and value are the same after setup is complete, ie HIGH.
                              • N
                                N
                                niccodemi
                                @martinhjelmare
                                thanks, I understand what you mean but I don't know how to write it in sketch.
                                I tried inserting
                                Relays[i].oldValue = Relays[i].relayState;
                                at the end of Void Setup section but then sketch wouldn't compile. I get "name lookup of 'i' changed 'for' ISO for scoping [-fpermissive]" error. I get same error if I substitute Relays[i].relayState with loadstate.
                                • N niccodemi
                                  @martinhjelmare
                                  I tried inserting
                                  martinhjelmareM
                                  martinhjelmareM
                                  martinhjelmare
                                  @niccodemi
                                  Put this on a line after pinMode() in setup function.
                                  Relays[i].oldValue = digitalRead(Relays[i].buttonPin);
                                  • N
                                    N
                                    niccodemi
                                    @martinhjelmare
                                    Ok, there is an improvement. Relays now turn to same state as they were before reboot most of the time but not always. Sometimes they inverse - the one which was OFF turns ON and vice-versa. Sometimes (1 in 3) they switch ON and OFF (only for split second) in the loop function. See below screenshots:
                                    reboot3
                                    reboot4
                                    This sketch is used with toggle button, same as on this photo.
                                    martinhjelmareM BartEB 2 Replies Last reply
                                    • N niccodemi
                                      @martinhjelmare
                                      reboot3
                                      reboot4
                                      martinhjelmareM
                                      martinhjelmareM
                                      martinhjelmare
                                      @niccodemi
                                      Could be the toggle is still bouncing at read time. Try increasing the debouncer interval. For example, double it until no more issues. Then decrease it in halves of what the last increase was until you see the issue again. This way you can try to find the smallest debounce time needed.
                                      • N niccodemi
                                        @martinhjelmare
                                        reboot3
                                        reboot4
                                        BartEB
                                        BartEB
                                        BartE
                                        wrote on last edited by BartE
                                        #35
                                        @niccodemi You can forget using the oldValue, because the debounce takes track of it's last status. When update() is called and a debounced pin-change is detect this function will return true otherwise it will send false.
                                        Having a short delay each loop will stabilize the debouncers so your loop() can look like this:
                                            for (byte i = 0; i < noRelays; i++) {
                                                if (debouncer[i].update()) {
                                            wait(10);
                                        • BartEB BartE
                                              wait(10);
                                          martinhjelmareM
                                          martinhjelmareM
                                          martinhjelmare
                                          #36
                                          @BartE
                                          Why do you think it's better to add the wait than to increase debounce interval? Didn't know update returns a boolean, cool.
                                          BartEB 1 Reply Last reply
