  3. Air Quality Sensor
Air Quality Sensor
calibrationaqigas sensorhchoair quality
270 Posts 46 Posters 456.4k Views 35 Watching
  • B
    B
    bhavika
    So what is the conditioning period for testing in it??? It is two days.. What does it mean??
    epierreE 1 Reply Last reply
    • B bhavika
      epierreE
      epierreE
      epierre
      #116
      on this kind maybe to have it powered for a full two days to burn out the production "dusts" that may remain in.
      those sensors are not good science, see the correlation of gases they are reported for in the datasheet
      z-wave - Vera -> Domoticz
      • epierreE
        epierreE
        epierre
        a very sensitive HCHO module you can see a demo here: http://www.seeedstudio.com/recipe/379-a-handheld-hcho-detector.html?utm_source=EDM&utm_medium=EDM&utm_campaign=EDM20150930
        https://github.com/empierre/arduino/blob/master/AirQuality-HCHO.ino
        • paqorP
          paqorP
          paqor
          I have a question for the MQ135. Do not always be above 500 ppm, the measured values? I also get values of 0. I suspect that it is due to the conversion. The values vary greatly. Is that normal? I get the values with an ordinary power supply. mq135 werte.PNG
          • paqorP
            paqorP
            paqor
            wrote on last edited by paqor
            #119
            • HeinzH
              HeinzH
              Heinz
              Looks strange, could you supply your code?
              Btw the sensor draws a lot of current, the power supply should be able to deliver 1A. Did you burn in the sensor for 12-24 hours?
              • paqorP
                paqorP
                paqor
                I have used the code from epiere. Baking I have not done. I use different power supplies (USB, Samsung and a large controllable power supply). I sometimes feel that contacts do not function properly. But the sensor draws but only about 100 mA = 0.1 A? Then it seems to be on branding. I have three new sensors. Mostly we read that it is only an attempt here is to measure the CO2 content. When I check the values with a measuring instrument with which agree the details here https://olimex.wordpress.com/2015/05/26/experimenting-with-gas-sensors-and-arduino/ Branding should work outdoors? Can you show me a chart or values?
                • paqorP
                  paqorP
                  paqor
                  • HeinzH
                    HeinzH
                    Heinz
                    I used this library:
                    https://github.com/GeorgK/MQ135
                    Together with this description:
                    https://hackaday.io/project/3475-sniffing-trinket/log/12363-mq135-arduino-library
                    Simple to use and very good explanations.
                    • paqorP
                      paqorP
                      paqor
                      I've read about. It sounds interesting.
                      I stand a little hard with the development. Is there a skit for MQ135.h and MYSENSORS?
                      I will test this afternoon.
                      • HeinzH
                        HeinzH
                        Heinz
                        Hi @paqor,
                        I wrote a little sketch which you could use as a start, it uses the MQ135 library.
                        I also used a timer library, but this could be replaced by a simple sleep, too.
                        RZERO should be changed when calibrating the sensor, this can be done at compile-time or during runtime by sending the value to the sensor via the gateway.
                        Unfortunately I could not test the sketch yet, but it should help you getting started.
                        If you have a second sensor which provides humidity and temperature then you can also get the corrected ppm from the library,...
                        good luck!
                        MQ135 MySensor
                        A0      white
                        D0      black
                        GND     brown
                        5V      red
                        #include <MQ135.h>
                        #include "Timer.h"
                        Timer timer;
                        // 30 seconds
                        #define TEMP_UPDATE_INTERVAL 30000
                        // MQ135
                        #define CHILD_ID_CO2 0
                        #define CHILD_ID_R0 1
                        #define CO2_SENSOR_ANALOG_PIN 0
                        /// Calibration resistance at atmospheric CO2 level
                        #define RZERO 300.0
                        #define EEPROM_R0 0
                        MQ135 gasSensor = MQ135(CO2_SENSOR_ANALOG_PIN, RZERO);
                        int lastC02;
                        float lastR0;
                        // MySensor
                        MyMessage msgCO2(CHILD_ID_CO2, V_VAR1);
                        MyMessage msgR0(CHILD_ID_R0, V_VAR1);
                            gw.sendSketchInfo("MQ135 Sensor", "1.0");
                            gw.present(CHILD_ID_CO2, S_AIR_QUALITY);
                            gw.present(CHILD_ID_R0, S_CUSTOM);
                            uint8_t R02 = gw.loadState(EEPROM_R0);
                            // get R0 from EEPROM
                            float R0 = R02 * 2;
                        	// do a plausibility check
                            if (R0 > 1.0 && R0 < 400.0)
                                Serial.print(F("Setting R0 from EEPROM: "));
                                Serial.print(F("Setting default R0: "));
                                R0 = RZERO;
                            Serial.print(R0);
                            Serial.println(F(""));
                            gasSensor.setR0(R0);
                            timer.every(TEMP_UPDATE_INTERVAL, timerHandler);
                        bool MQ135Changed()
                            bool changed = false;
                            lastR0 = gasSensor.getRZero();
                            Serial.print(F("R0: "));
                            Serial.println(lastR0);
                                float ppm = gasSensor.getPPM();
                                Serial.print(F("CO2 ppm: "));
                                Serial.print(ppm);
                                int roundedPpm = (int)ppm;
                                Serial.print(F(" --> "));
                                Serial.println(roundedPpm);
                                if (roundedPpm != lastC02)
                                    lastC02 = roundedPpm;
                                    changed = true;
                            return changed;
                        void timerHandler()
                            bool airQualityChanged = MQ135Changed();
                            if (airQualityChanged)
                                gw.send(msgCO2.set(lastC02));
                                gw.send(msgR0.set(lastR0, 2));
                            timer.update();
                        // Gets the R0 value from the gw passes ot to the lib and stores it into the EEPROM.
                        void incomingMessage(const MyMessage& message)
                            Serial.println(F("Incoming Message:"));
                            if (message.isAck())
                            uint8_t sensor = message.sensor;
                            if (sensor == CHILD_ID_R0)
                                float R0 = message.getFloat();
                                Serial.print(F("Incoming R0: "));
                                Serial.print(R0);
                                gw.saveState(EEPROM_R0, (uint8_t)(R0/2));
                                gw.send(msgR0.set(R0, 2));
                        • paqorP
                          paqorP
                          paqor
                          #126
                          I have compiled from various sources themselves something. The result is https://gleisnetze.de/2015/12/25/das-erste-kleine-programm/ described herein. The most plausible values I received with the MQ135.h library. For that I have then added the transfer after MySensors / FHEM.
                          • B
                            B
                            bhavika
                            Hello
                            In MiCS 2614 or in any gas sensor. what should be the value of R0... Because in datasheet they mentioned that value is measured in ambient condition. Any default value for that??
                            • B bhavika
                              Hello
                              epierreE
                              epierreE
                              epierre
                              @bhavika said:
                              Hello
                              The datasheed propose the "clean air calibration": "Sensing resistance in air R0 is measured under controlled ambient conditions, i.e. synthetic air at 23 ±5°C and 50 ± 10% RH. Sampling test."
                              so you should go outside and mesure the defautl R0 value in your environment.
                              • HeinzH
                                HeinzH
                                Heinz
                                MQ-135 with 10k results in a R0 of around 360 in my environment. So you could start experimenting with values around 300-500. I had to use a voltage regulator to get reliable values from the sensor.
                                • epierreE
                                  epierreE
                                  epierre
                                  #130
                                  a little update on the MICS-6814:
                                  NO2: sensible
                                  CO: flat
                                  NH3 flat
                                  For the HCHO:
                                  sorry for the flat part, some arduino issues at this time
                                  • mfalkviddM
                                    Welcome @betthorn, great to have you here.
                                    • epierreE
                                      epierreE
                                      epierre
                                      I have had some questions about converting from mg/m3 to ppm gases, here are the weight values and a proposed method:
                                      NH3 17.03 g/mol
                                      CO2 44.01
                                      CO 28.01
                                      H2S 34.08
                                      NO2 46.01
                                      NO 30.01
                                      O3 48.00
                                      C6H6 78.11
                                      C7H8 92.14
                                      you have:
                                      NO2 50 μg/m3 gives 26,5868821 ppm
                                      O3 27 μg/m3 = 0.027 mg/m3 -> (8,31441298,15)/(48101,325)*27=13,7617025 ppm
                                      correct me if I'm wrong
                                      • epierreE
                                        epierreE
                                        epierre
                                        2016 is where IoT for gas sensors are moving to more maturity, Cooking Hacks / Libellium proposed so far Fibaro sensors, but are now proposing more pricey one that are calibrated.
                                        See https://www.cooking-hacks.com/shop/sensors/gas
                                        • epierreE
                                          epierreE
                                          epierre
                                          CO2 with MH-Z14
                                          NO2 MICS-6814
                                          HCHO sensor
                                          12.5k
