  3. Wifi gateway : NodeMCU & NRF24L01 - Radio does not work
4 Posts 2 Posters 3.6k Views
  • M Offline
    M Offline
    miclane
    Sorry for my English.
    I try to run the wifi gateway with a NodeMCU ESP12-E and a NRF24L01 (not 24L01+).
    Arduino ide is 1.6.7.
    Library sensors is Arduino-development. I tried before with the master library.
    radio power is independent of nodemcu.
    The wires are checked and connected as on documentation.
    First : in the sketch esp8266, i declare ssid, password, static ip address, everything works well.
    Second : I enable #define MY_RADIO_NRF24 and #define MY_RF24_DATARATE RF24_1MBPS. Then I get DHCP address (not static like above) and debug give :
    tail 0
    chksum 0x42
    csum 0x42
    0;0;3;0;9;Starting gateway (RNNGE-, 1.6.0-beta)
    write_register(0x04,0x5F)
    write_register(0x06,0x27)
    write_register(0x06,0x07)
    write_register(0x00,0x0E)
    write_register(0x07,0scandone
    x70)
    write_register(0x05,0x4C)
    STATUS		0x0E RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
    RX_ADDR_P2-5	0xC3 C4 C5 C6
    TX_ADDR		0x0E0E0E0E0E
    EN_AA		0x3Fstate: 0 -> 2 (b0)
    tate: 2 -> 0 (0)
    f 0, scandone
    state: 0 -> 2 (b0)
    state: 2 -> 3 (0)
    state: 3 -> 5 (10)
    add 0
    aid 1
    cnt
    Have you an idea of the problem?
    Thanks for your help.
    M Y 2 Replies Last reply
    • M miclane
      tail 0
      chksum 0x42
      csum 0x42
      x70)
      tate: 2 -> 0 (0)
      f 0, scandone
      state: 0 -> 2 (b0)
      state: 2 -> 3 (0)
      state: 3 -> 5 (10)
      add 0
      aid 1
      cnt
      M Offline
      M Offline
      miclane
      radio power is independent of nodemcu and grounds are interconnected.
      I also changed several radio components.
      First : in the sketch esp8266, i declare ssid, password, static ip address, everything works well. I can successfully ping the ip address.
      Second : Now, I enable #define MY_RADIO_NRF24 and #define MY_RF24_DATARATE RF24_1MBPS in addition to the sketch. Then I get DHCP address - and not static like above - and debug give :
      Radio init failed - Check wiring.
      The radio connection is not working and disrupts the wifi connection.
      Have you an idea of the problem ?
      • M miclane
        tail 0
        chksum 0x42
        csum 0x42
        x70)
        tate: 2 -> 0 (0)
        f 0, scandone
        state: 0 -> 2 (b0)
        state: 2 -> 3 (0)
        state: 3 -> 5 (10)
        add 0
        aid 1
        cnt
        Y Offline
        Y Offline
        @miclane said:
        NRF24L01
        This chip is not supported by MySensors, sorry.
        • M Offline
          M Offline
          miclane
          Thank you for your answer. I read a post indicating to change the speed of 1MB for L01 .
          I'll order L01 + .
          Congratulations on your achievement .
