  3. ESP8266 Gateway - loosing messages ?
8 Posts 3 Posters 3.1k Views 1 Watching
  • K Offline
    K Offline
    kr0815
    After trying many versions, compiling errors,... i finally installed a portable Version of Arduino IDE 1.6.6
    I installed ESP Core 2.0.0 and copied the Dev branch of MySensors.
    Now it looks like the Gateway is loosing / not receiving messages from the sensors, i guess about 50 percent
    DId anybodo successfully instal the ESP8266-Gateway from Developer Branch ?
    I know Developer means not stable, but any hints where to look for my problem ?
    THe other versions, as said, i always got compiling errors
    • R Offline
      R Offline
      robosensor
      Yes, loosing messages due to slow esp8266 network code.
      http://forum.mysensors.org/topic/1870/esp8266-wifi-gateway-port-for-mysensors/224
      http://forum.mysensors.org/topic/2637/why-mysensors-isn-t-using-interrupts-for-nrf24
      • Y Offline
        Y Offline
        @kr0815 said:
        ESP Core 2.0.0
        I wasn't even aware they already reached 2.0 for the Core!
        You could give 1.6.5 a try (http://arduino.esp8266.com/versions/1.6.5-947-g39819f0/package_esp8266com_index.json) and see if things improve.
        This is the version (in combination with Arduino 1.6.5) which I used to develop ESP8266 support.
        @robosensor Let's not jump to conclusions!
        • K Offline
          K Offline
          kr0815
          Hello Yveaux,
          thanks for your fast response.
          I don´t thiink the esp is to slow, watched it on my workbench, if a sensor is sending each 30 seconds, i get every second message, very strange...
          I will try to go back to 1.6.5, had 2.0.0 only because of also playing with the espeasy project.
          But the developer code here should be working ?
          Another strange thing now, i tried it now with an ESP8266-201, uploading is ok, but after boot i get
          0;0;3;0;9;Radio init successful.
          and the dots go on and on, what does the code expect ? finding the wifi now ?
          • K Offline
            K Offline
            kr0815
            So i went back to the 1.6.5, did another portable installation of arduino IDE, downloaded everything exactly as described in the "buld"-Section
            Gateway is running now, but as soon as i try to connect in FHEM, i get
            Exception (28):
            epc1=0x4000bf80 epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
            ctx: cont
            sp: 3ffeaca0 end: 3ffeaf20 offset: 01a0
            >>>stack>>>
            3ffeae40:  3fffdab0 00080000 3ffe97c7 40203ac0
            3ffeae50:  3ffeaf80 00000001 3ffe8fc9 4020b73c
            3ffeae60:  3ffeaf80 00000009 3ffe98bd 00000000
            3ffeae70:  00000003 00000000 3ffe98a8 4020ae11
            3ffeae80:  00000001 3ffe98b4 3ffeaf80 4020ae11
            3ffeae90:  3ffe98b4 3ffe98b4 3ffeaf80 3ffeaf80
            3ffeaea0:  3ffe98b4 3ffe97c0 3ffe97c7 402024b4
            3ffeaeb0:  3ffe9ab8 3ffe98b4 00000000 40202784
            3ffeaec0:  3ffe8e48 00000000 000003e8 3ffe9c4c
            3ffeaed0:  00000000 3fff4c88 3fff4c18 3ffeaf4c
            3ffeaee0:  00000000 0000000a 00000000 00000000
            3ffeaef0:  40201c35 4db2a8c0 00000000 3ffeaf4c
            3ffeaf00:  3fffdc20 00000000 3ffeaf44 40201c92
            3ffeaf10:  00000000 00000000 3ffe9f00 40100378
            <<<stack<<<
             ets Jan  8 2013,rst cause:2, boot mode:(3,0)
            tail 0
            chksum 0x42
            csum 0x42
            ~ld
            ESP8266 MySensors Gateway
            Connecting to Power-LAN
            .....Connected!
            IP: 192.168.178.77
            0;0;3;0;9;read: 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0:
            255;255;3;0;3;
            255;255;3;0;3;
            • K Offline
              K Offline
              kr0815
              wrote on last edited by kr0815
              I investigated further - the developer version still only gets some messages, seems like radio reception is partly not working ?
              The old / stable version crashes not when going to inclusion mode, but after initiating inclusion mode, then when the first node sends something.
              I tried to use different power sources - didn´t change anything :-(
              Tried even the MQTT Gateway - can´t get in into iclusion mode ?
              (i uncommented the inclusion part, connected a switch , should there be any debug message when hitting that switch ? )
              THE ESP is node a NodeMCU, but another chinese developer Board, but it runs fine with EasyESP, so i don´t think that is the cause
              I have other gateways running and at the moment, all are at the same channel, but i can´t think this is the cause for a reset of the ESP ?
              • Y Offline
                Y Offline
                Do they also use the same MySensors base ID? There shall be only one gateway for each base ID/channel combination!
                Other people reported crashes on ESP8266 vanished when switching nRF24 radios. Did you give that a try?
                • K Offline
                  K Offline
                  kr0815
                  At the moment they use same Channel and base ID, as it´s, i have to confess, very complicated to change them each time in the file and to recompile everything.
                  But i will try tomorrow to give them different ID´s / Channels.
                  WHat confuses me even more, and i don´t expect to get help here, but as i use FHEM, i saw, that ID´s i deleted in the past were reasigned to new sensors, with some values from the old / deleted ones, maybe that´s already where the problems start....
                  I think the easiest for me would be to Switch either to the developer Version- as said it´s ot receiving all Messages, or use the MQTT Gateway, but how to get it in inclusion mode ? Do i understand it right that the MQTT ESP Gateway will handle the allowed childs by itself and broadcast the Messages of only These childs to the MQTT Broker ?
