  3. Air Quality Sensor
Air Quality Sensor
calibrationaqigas sensorhchoair quality
270 Posts 46 Posters 452.6k Views 35 Watching
  • epierreE epierre
    @Yveaux in fact it is a correlation, if you have a value from the analog, then from the curve you can guess it is one of the group, not one individually... it is the way they are designed...
    @epierre That's exactly my point!
    epierreE 1 Reply Last reply
    • YveauxY Yveaux
      epierreE
      epierreE
      epierre
      @Yveaux and there's worse : if you don't have the environment to calibrate it with real gas, it is just an indication... that is maybe why some projects that may have taken such sensor may hae a production process issue at the moment... In fact despite my researches, I've never found someone that said it made it to mesure correctly with gas sensors, mostly theory or just analog reading only...
      An example: my MQ135 was silencious, I put its nose in the Aceton bottle:
      Before:
      Q2 :LPG :11ppm CO :0ppm SMOKE :18ppm
      MQ6 :LPG :3ppm CH4 :36ppm
      MQ131 :CL2 :2ppm O3 :3ppm
      TGS2600:H2 :7602ppm C2H5OH:13706ppm C4H10 :26350ppm
      MQ135 :CO2 :0ppm CO :0ppm CH3 :0ppm NH4 :0ppm
      Dust :raw : 18 Voltage: 0.09 - Dust Density: -85.06
      After:
      MQ2 :LPG :208ppm CO :0ppm SMOKE :832ppm
      MQ6 :LPG :44ppm CH4 :172ppm
      MQ131 :CL2 :16ppm O3 :17ppm
      TGS2600:H2 :7774ppm C2H5OH:13818ppm C4H10 :27274ppm
      MQ135 :CO2 :999ppm CO :0ppm CH3 :484ppm NH4 :1904ppm
      Dust :raw : 58 Voltage: 0.28 - Dust Density: -51.86
      The MQ135 has reacted, but all others around...
      • epierreE epierre
        Before:
        After:
        epierreE
        epierreE
        epierre
        doing the same on my basic sketch here what I have:
        2014-08-03 11:29:57 3 0 1 24 -28393
        looks like my old sketch needs some update...
        • epierreE
          epierreE
          epierre
          Doing the same on the basic sketch :
           Vrl / Rs / ratio:4.21 3731.17 0
           CO ppm :inf
          Then:
          CO ppm :inf
          • epierreE
            epierreE
            epierre
            and now ethanol/isopropylène (bike chain cleaning product):
            MQ2    :LPG   :247ppm   CO    :0ppm    SMOKE :1053ppm
            MQ6    :LPG   :3527ppm    CH4   :2160ppm
            MQ131  :CL2   :10ppm    O3    :12ppm
            TGS2600:H2    :7891ppm C2H5OH:14279ppm C4H10 :27751ppm
            Dust   :raw   : 206    Voltage: 1.01 - Dust Density: 71.00
            • epierreE
              epierreE
              epierre
              and now eveyone through aceton:
              MQ2    :LPG   :25ppm   CO    :0ppm    SMOKE :48ppm
              MQ6    :LPG   :19677ppm    CH4   :3010ppm
              MQ131  :CL2   :71ppm    O3    :51ppm
              TGS2600:H2    :8448ppm C2H5OH:15007ppm C4H10 :28738ppm
              MQ135  :CO2   :840ppm    CO    :0ppm     CH3   :400ppm    NH4    :1474ppm
              Dust   :raw   : 728    Voltage: 3.55 - Dust Density: 504.30
              remark that dust sensor goes up ! and TGS2600 goes down afterward:
              MQ2    :LPG   :8ppm   CO    :0ppm    SMOKE :11ppm
              MQ6    :LPG   :1264ppm    CH4   :1194ppm
              MQ131  :CL2   :27ppm    O3    :24ppm
              TGS2600:H2    :4966ppm C2H5OH:8407ppm C4H10 :16227ppm
              Dust   :raw   : 165    Voltage: 0.81 - Dust Density: 36.96
              • epierreE
                epierreE
                epierre
                #23
                @hek I now have the netatmo CO2 xml and json, they are based on the generic sensor.
                But I don't have mysensors running on my vera...
                I would need from you:
                • the device and variable type
                • an icon, but maybe I can reuse the other one
                maybe
                CO2 = {22, "urn:schemas-micasaverde-com:device:CO2Sensor:1", "D_CO2Sensor.xml", "CO2 "}
                CO2 = {36, "urn:micasaverde-com:serviceId:CO2Sensor", "Concentration", "396" },
                S_CO2Sensor.json D_CO2Sensor.xml D_CO2Sensor.json
                P.S. there's the icon from Nest plugin too: http://cocu.la/vera/nest/nest_co.png
                • epierreE
                  epierreE
                  epierre
                  About initial calibration, just a warning from this graph:
                  you can see high levels around july 21 then dropping in august... the sensor has been restarted... that is what the call clean air...
                  this automatic reading at the start should be stored in the sketch and not reclaculated at each reboot or you would loose all reference on your data...
                  • epierreE
                    epierreE
                    epierre
                    • epierreE
                      epierreE
                      epierre
                      • epierreE epierre
                        [[topic:post-is-deleted]]
                        @epierre did you just post the same reply 3 times or is the forum software showing yet another bug?
                        • YveauxY Yveaux
                          epierreE
                          epierreE
                          epierre
                          @Yveaux don't know, I did post once...
                          • korttomaK
                            korttomaK
                            korttoma
                            I wanted to get acquainted with the MQ2 AirQuality Sensor so I took a look at the sketch from github.
                            One thing I noticed was that there is some sleep-time defined, is this just to make the sensor report the value every 30 seconds?
                            I guess it is not for saving power so you can run it on batteries because my understanding is that it needs to be hot in order to function correctly and that will drain the battery fast.
                            Does not look like the calibration during setup takes in account the preheating time either, maybe it is a good idea to add a delay before the calibration so the sensor gets hot enough.
                            Please correct me if I'm wrong.
                            • Tomas
                            • epierreE
                              epierreE
                              epierre
                              #30
                              @hek Here is a first list from the most commons:
                              • Carbon Monoxide – CO
                              • Carbon Dioxide – CO2
                              • Oxygen – O2
                              • Methane – CH4
                              • Hydrogen – H2
                              • Ammonia – NH3
                              • Isobutane – C4H10
                              • Ethanol – CH3CH2OH (aka C2H5OH or C2H60)
                              • Toluene – C6H5CH3
                              • Hydrogen Sulfide – H2S
                              • Nitrogen Dioxide – NO2
                              • Ozone – O3
                              • Hydrocarbons – VOC
                              • Chlorine CL2
                              • Ammonium NH4
                              • Ethanol CO2H50H
                              • Methyl CH3
                              • Acetone CH3_2CO
                              • LPG (both C3H8 C4H10)
                              • korttomaK korttoma
                                epierreE
                                epierreE
                                epierre
                                #31
                                I see your point, but from experience I don't see a difference on heating... I should have a closer look. This one does not need a special pre-heating as some other (MQ-7).
                                Clearly this cannot run on battery on MQ/TGS/MICS series, so surely removing the sleep and adding a wait would do the trick the same way.
                                If you want to play and see something, the MQ135 is much better for it reacts to CO2, so having someone in a room or not you could see it easily changing.
                                A current weakness on the sketches is to take into accound humidity and temperature to correct the value, that will come too.
                                • epierreE
                                  epierreE
                                  epierre
                                  I was looking for some other gas sensor, but these have no shield ready to connect to arduino :
                                  Sensor	     Operating Voltage  	Heater Power
                                  MiCS-2710 (NO2)	  2.5 V	           43 mW
                                  MiCS-5525 (CO)	   5.0 V	           76 mW
                                  do I need a dedicated 2.5 V linear regulator such as Microchip TC1071VCT713 ?
                                  • epierreE
                                    epierreE
                                    epierre
                                    • epierreE
                                      epierreE
                                      epierre
                                      • epierreE
                                        epierreE
                                        epierre
                                        @hek about initial calibration, how would I do check if there is a value in the eeprom or not, and if not run an initial calibration ?
                                        hekH 1 Reply Last reply
                                        • epierreE epierre
                                          @epierre
                                          Unwritten eeprom has the value 0xff.
