  3. Air Quality Sensor
Air Quality Sensor
calibrationaqigas sensorhchoair quality
270 Posts 46 Posters 452.6k Views 35 Watching
  • epierreE
    epierreE
    epierre
    and now eveyone through aceton:
    MQ2    :LPG   :25ppm   CO    :0ppm    SMOKE :48ppm
    MQ6    :LPG   :19677ppm    CH4   :3010ppm
    MQ131  :CL2   :71ppm    O3    :51ppm
    TGS2600:H2    :8448ppm C2H5OH:15007ppm C4H10 :28738ppm
    MQ135  :CO2   :840ppm    CO    :0ppm     CH3   :400ppm    NH4    :1474ppm
    Dust   :raw   : 728    Voltage: 3.55 - Dust Density: 504.30
    remark that dust sensor goes up ! and TGS2600 goes down afterward:
    MQ2    :LPG   :8ppm   CO    :0ppm    SMOKE :11ppm
    MQ6    :LPG   :1264ppm    CH4   :1194ppm
    MQ131  :CL2   :27ppm    O3    :24ppm
    TGS2600:H2    :4966ppm C2H5OH:8407ppm C4H10 :16227ppm
    Dust   :raw   : 165    Voltage: 0.81 - Dust Density: 36.96
    • epierreE
      epierreE
      epierre
      #23
      @hek I now have the netatmo CO2 xml and json, they are based on the generic sensor.
      But I don't have mysensors running on my vera...
      I would need from you:
      • the device and variable type
      • an icon, but maybe I can reuse the other one
      maybe
      CO2 = {22, "urn:schemas-micasaverde-com:device:CO2Sensor:1", "D_CO2Sensor.xml", "CO2 "}
      CO2 = {36, "urn:micasaverde-com:serviceId:CO2Sensor", "Concentration", "396" },
      S_CO2Sensor.json D_CO2Sensor.xml D_CO2Sensor.json
      P.S. there's the icon from Nest plugin too: http://cocu.la/vera/nest/nest_co.png
      • epierreE
        epierreE
        epierre
        About initial calibration, just a warning from this graph:
        you can see high levels around july 21 then dropping in august... the sensor has been restarted... that is what the call clean air...
        this automatic reading at the start should be stored in the sketch and not reclaculated at each reboot or you would loose all reference on your data...
        • epierreE
          epierreE
          epierre
          • epierreE
            epierreE
            epierre
            • epierreE epierre
              [[topic:post-is-deleted]]
              @epierre did you just post the same reply 3 times or is the forum software showing yet another bug?
              epierreE 1 Reply Last reply
              • YveauxY Yveaux
                epierreE
                epierreE
                epierre
                @Yveaux don't know, I did post once...
                • korttomaK
                  korttomaK
                  korttoma
                  I wanted to get acquainted with the MQ2 AirQuality Sensor so I took a look at the sketch from github.
                  One thing I noticed was that there is some sleep-time defined, is this just to make the sensor report the value every 30 seconds?
                  I guess it is not for saving power so you can run it on batteries because my understanding is that it needs to be hot in order to function correctly and that will drain the battery fast.
                  Does not look like the calibration during setup takes in account the preheating time either, maybe it is a good idea to add a delay before the calibration so the sensor gets hot enough.
                  Please correct me if I'm wrong.
                  • Tomas
                  • epierreE
                    epierreE
                    epierre
                    #30
                    @hek Here is a first list from the most commons:
                    • Carbon Monoxide – CO
                    • Carbon Dioxide – CO2
                    • Oxygen – O2
                    • Methane – CH4
                    • Hydrogen – H2
                    • Ammonia – NH3
                    • Isobutane – C4H10
                    • Ethanol – CH3CH2OH (aka C2H5OH or C2H60)
                    • Toluene – C6H5CH3
                    • Hydrogen Sulfide – H2S
                    • Nitrogen Dioxide – NO2
                    • Ozone – O3
                    • Hydrocarbons – VOC
                    • Chlorine CL2
                    • Ammonium NH4
                    • Ethanol CO2H50H
                    • Methyl CH3
                    • Acetone CH3_2CO
                    • LPG (both C3H8 C4H10)
                    • korttomaK korttoma
                      epierreE
                      epierreE
                      epierre
                      #31
                      I see your point, but from experience I don't see a difference on heating... I should have a closer look. This one does not need a special pre-heating as some other (MQ-7).
                      Clearly this cannot run on battery on MQ/TGS/MICS series, so surely removing the sleep and adding a wait would do the trick the same way.
                      If you want to play and see something, the MQ135 is much better for it reacts to CO2, so having someone in a room or not you could see it easily changing.
                      A current weakness on the sketches is to take into accound humidity and temperature to correct the value, that will come too.
                      • epierreE
                        epierreE
                        epierre
                        I was looking for some other gas sensor, but these have no shield ready to connect to arduino :
                        Sensor	     Operating Voltage  	Heater Power
                        MiCS-2710 (NO2)	  2.5 V	           43 mW
                        MiCS-5525 (CO)	   5.0 V	           76 mW
                        do I need a dedicated 2.5 V linear regulator such as Microchip TC1071VCT713 ?
                        • epierreE
                          epierreE
                          epierre
                          • epierreE
                            epierreE
                            epierre
                            • epierreE
                              epierreE
                              epierre
                              @hek about initial calibration, how would I do check if there is a value in the eeprom or not, and if not run an initial calibration ?
                              hekH 1 Reply Last reply
                              • epierreE epierre
                                @epierre
                                Unwritten eeprom has the value 0xff.
                                • O
                                  O
                                  Omemanti
                                  First of al I'm a novice in all of this. I can read some code but the whole arduino thing is new to me.
                                  I tried to get the MQ135 working on my uno with tearing apart the : https://github.com/empierre/arduino/blob/master/1.3/MQ135dgi.ino.
                                  I tried to pull out the bits and parts to get a accurate reading on my serial monitor.
                                  It sometimes read 1 or 2, but most of the time it is 0.
                                  Can it have something to do with it being mounted on its own PCB? (I ordered the one suggested in the store..)
                                  Can someone help me out?
                                  Groetjes Mark
                                  • O Omemanti
                                    Groetjes Mark
                                    epierreE
                                    epierreE
                                    epierre
                                    #38
                                    @Omemanti hello have you plugged it on the right pins, this is an analogic sensor to be plugged on A0, with 5V and GND pins. Don't wire the digital one, useless...
                                    My minimal value is 53.. so not 0 or 1 hwich looks more like the digital output ;-)
                                    • O
                                      O
                                      Omemanti
                                      should be alright right?
                                      • O Omemanti
                                        epierreE
                                        epierreE
                                        epierre
                                        @Omemanti cabling is correct
                                        • korttomaK
                                          korttomaK
                                          korttoma
                                          #41
                                          Where can I find AirQuality1.xml?? (or all files related to this device if there are others then the .xml)
                                          01 09/03/14 13:46:53.685 ctrl_chr[31;1mDevice_LuaUPnP::LoadDeviceDoc can't load /etc/cmh-lu//D_AirQuality1.xmlctrl_chr[0m <0x2acc9000>
                                          02 09/03/14 13:46:53.686 ctrl_chr[33;1mJobHandler_LuaUPnP::m_sMissingFile_set /etc/cmh-lu//D_AirQuality1.xmlctrl_chr[0m <0x2acc9000>
                                          Seems like if this file is missing it brakes the whole MySensors plugin.
                                          All devices related to MySensors plugin are blank and nothing seems to update.
                                          Deleting the device that use AirQuality.xml will make the rest work again.
                                          Help!!
                                          • Tomas
