  3. Hacking a Neato Robotics BotVac Connected
71 Posts 29 Posters 93.8k Views 25 Watching
  • Daniel ErikssonD Daniel Eriksson
    If we can figure out what's going on between Cloud <-> Neato we can do a version which is in depended on the Cloud-service being online or not - which also means that we can disallow it internet access
    :thumbsup:
    • G
      G
      gardebring
      I recently ventured into writing some custom scripts both for my cloud connected home security system as well as my music streamer at home. It was quite easy to retrieve the commands needed from my android phone using an app I found called "Packet Capture" by the author Grey Shirts. Even https communication could be found. Perhaps this could be a way forward? Following this thread since I am considering getting a Botvac connected but failing to see the point if I would be dependent on a specific app on specific hardware..
        This won't be solved until I see a proper curl call ;)
        • B
          B
          Brutus
          wrote on last edited by Brutus
          #27
          I have installed the Packet Capture app. But this isn't working I think.
          When starting the capture, the app makes a VPN connection. This VPN is blocking some traffic for the Neato App because my bot doesn't come only in the app. When I shut the VPN connection the bot comes online after 3 seconds.
          Going back to the capture I think we miss some vital information because of this block.
          This is what I got so far form the app:
          <--- (TEXT)
          GET /sessions/check HTTP/1.1
          Authorization: Token token=xxxxxxxxxxxxxxx
          Accept: application/vnd.neato.beehive.v1+json
          Content-type: application/json
          X-Agent: android-22|SM-G928F|samsung|1.0.0|134
          User-Agent: Dalvik/2.1.0 (Linux; U; Android 5.1.1; SM-G928F Build/LMY47X)
          Host: beehive.neatocloud.com
          Connection: Keep-Alive
          Accept-Encoding: gzip
          ---> (TEXT)
          HTTP/1.1 200 OK
          Server: Cowboy
          Date: Wed, 30 Dec 2015 00:32:03 GMT
          Connection: keep-alive
          X-Frame-Options: SAMEORIGIN
          X-Xss-Protection: 1; mode=block
          X-Content-Type-Options: nosniff
          Content-Type: application/json; charset=utf-8
          Etag: W/"a3cdd45ce712890397436cafca38e79a"
          Cache-Control: max-age=0, private, must-revalidate
          X-Request-Id: xxxxxxxxxxxxxxxxxxxxxx
          X-Runtime: 0.022752
          Strict-Transport-Security: max-age=31536000
          Content-Length: 39
          Via: 1.1 vegur
          ---> (JSON)
          {"current_time":"2015-12-30T00:32:04Z"}
          <--- (TEXT)
          GET /dashboard HTTP/1.1
          Authorization: Token token=xxxxxxxxxxxxxxxxxxxxxxxx
          ---> (TEXT)
          HTTP/1.1 200 OK
          Server: Cowboy
          Etag: W/"c390b2a69fb7b4a405c8637e86ff321a"
          X-Request-Id: xxxxxxxxxxxxxxxxxxxxxxxxxx
          X-Runtime: 0.014884
          Content-Length: 1337
          Via: 1.1 vegur
          ---> (JSON)
          "email":"xxxxx@xxxxx.nl",
          "first_name":"xxxx",
          "last_name":"xxxxxx",
          "locale":"nl",
          "newsletter":false,
          "created_at":"2014-06-23T16:39:45Z",
          "verified_at":"2015-05-25T13:19:08Z",
          "robots": [
          "serial":"xxxxxxxxxx",
          "prefix":"SN",
          "name":"xxxxxx",
          "model":"BotVacConnected",
          "secret_key":"xxxxxxxxxxxxxxxxxxxxx",
          "purchased_at":"2015-12-22T00:00:00Z",
          "proof_of_purchase_url":"https://neatorobotics.s3.amazonaws.com/proof_of_purchases/xxxxxxxxxx/ProofOfPurchase.jpg",
          "proof_of_purchase_generated_at":"2015-12-23T18:31:21Z",
          "mac_address":"xxxxxxxxx",
          "firmware":"2.0.0",
          "created_at":"2015-11-11T20:10:38Z",
          "linked_at":"2015-12-23T17:23:55Z"
          "recent_firmwares":{}
          xxxxxxxxx = personal data
          • YveauxY
            Have a look here guys. This discussion seems and attempt to control the same vacuum cleaner.
              Hmm.. my german isn't great.. Have they found out something useful?
              • B
                B
                Brutus
                I can read it a little bit but I think there isn't any usable information in that topic. Its more a overall discussion on the Botvac.
                  Not sure ;-)
                  • Daniel ErikssonD
                    Daniel ErikssonD
                    Daniel Eriksson
                    I have gotten stuck now on my venture -
                    Trying to figure out how the Authorization is calculated when it comes to the communication with the Neato. Found a place in the Java-code which mentions the Authorization part but can not figure out where it comes from
                    com/neatorobotics/android/activities/robot/C0645j.java:~142
                    private void m5619R() {
                        if (!NeatoApplication.f2866a) {
                            m5646a();
                            try {
                                URI uri = new URI("ws://" + this.f3263d + ":" + this.f3264e + "/drive");
                                String b = C0764a.m5847b();
                                String str = this.f3262c.toLowerCase() + "\n" + b + "\n";
                                Mac instance = Mac.getInstance("HmacSha256");
                                instance.init(new SecretKeySpec(this.f3265f.getBytes(), "HmacSha256"));
                                str = C0770g.m5880a(instance.doFinal(str.getBytes("UTF-8"))).toLowerCase();
                                Map hashMap = new HashMap();
                                hashMap.put("Date", b);
                                hashMap.put("Authorization", "NEATOAPP " + str);
                                this.al = new C0655t(this, uri, new C0017f(), hashMap, 5000);
                                this.al.m41a();
                                new Thread(new C0661z(this)).start();
                            } catch (Exception e) {
                                C0767d.m5867a("ManualCleaningFragment", "Exception", e);
                    I have also found what String b is
                    com/neatorobotics/android/utils/C0764a.java:89: public static String m5847b() {
                        Calendar instance = Calendar.getInstance();
                        instance.add(12, (int) (((C0742a.m5809b(NeatoApplication.m5360a(), "SERVER_DEVICE_TIME_DELTA_MILLIS", 0) * -1) / 1000) / 60));
                        SimpleDateFormat simpleDateFormat = new SimpleDateFormat("EEE, dd MMM yyyy HH:mm:ss 'GMT'", Locale.US);
                        simpleDateFormat.setTimeZone(TimeZone.getTimeZone("GMT"));
                        return simpleDateFormat.format(instance.getTime());
                    So what we need to figure out is the following variables:
                    this.f3265f.getBytes() < I am pretty sure this is secret_key
                    when we crack these - we get closer to communicating with the central server
                    • B
                      B
                      Brutus
                      #33
                      Maybe I can help because I figured something out. I can get my computer in between the App and the Neato Botvac.
                      I have a Asus motherboard with a Wifi adapter. With the software "Wifi Engine" from Asus I can make a Access point in my computer.
                      So what I have done is disabled my home Wifi Netwerk and configured the Wifi of my computer the same as the home network. Both my phone and the Neato Bot connect to the Wifi point with my computer in between now.
                      I have installed Wireshark so I could capture some date between the app and the Neato.
                      Unfortunately I can't make anything out of the data. It's not like the "Packet Capture" app I installed on my phone you can see in my earlier post.
                      Someone any idea what I could do to help us out?
                      • Daniel ErikssonD
                        Daniel ErikssonD
                        Daniel Eriksson
                        Already sniffed the Web Socket traffic - was the first thing I did. No sensible easy output - needs more analysing and so. Need to start on the end with reversing the control-part of the app to see what it does.
                        • enloE
                          enloE
                          enlo
                          This is the code I found in the app. there is also a selfsigned certificate, which probably matches the robot.
                          So the reason why you can't make out anything useful in the traffic: It's SSL encrypted.
                                      HttpsURLConnection httpsURLConnection3 = (HttpsURLConnection) new URL(str2).openConnection();
                                      try {
                                          if ("neatoProduction".contains("vorwerk")) {
                                              httpsURLConnection3.setSSLSocketFactory(C0751h.m5821a(0));
                                          httpsURLConnection3.setConnectTimeout(60000);
                                          httpsURLConnection3.setReadTimeout(60000);
                                          if (str.equals("GET") || str.equals("DELETE")) {
                                              httpsURLConnection3.setDoOutput(false);
                                              httpsURLConnection3.setDoOutput(true);
                                          httpsURLConnection3.setRequestMethod(str);
                                          String a = C0742a.m5803a(NeatoApplication.m5360a(), "ACCESS_TOKEN");
                                          if (a != null) {
                                              httpsURLConnection3.setRequestProperty("Authorization", "Token token=" + a);
                                          httpsURLConnection3.setRequestProperty("Accept", "application/vnd.neato.beehive.v1+json");
                                          httpsURLConnection3.setRequestProperty("Content-type", "application/json");
                                          httpsURLConnection3.setRequestProperty("X-Agent", C0765b.m5864f());```
                          Daniel ErikssonD 1 Reply Last reply
                          • enloE enlo
                                        try {
                                            if (a != null) {
                            Daniel ErikssonD
                            Daniel ErikssonD
                            Daniel Eriksson
                            @enlo That there isn't the problem - if you read my above post the problem is generating the HMAC correctly. I have already proxied the traffic from the app - since they don't used pinned certifications
                            • kangguruK
                              kangguruK
                              kangguru
                              There's good news guys. I finally figured out how the HMAC signature is calculated and now i'm able to control the neato without the mobile application, which offers all kinds of new integration options.
                              What can be found in com/neatorobotics/android/activities/robot/C0645j.java is just half of the truth and i was looking at this part for way to long, i'm not sure where this part is used. maybe this would be the part where one can communicate with the neato without making use of the cloudservice. who knows ;)
                              The actual fun starts in com/neatorobotics/android/p040c/p042b/C0898b.java the code reveals that there are 3 ingredients making up the HMAC signature
                              • the robot's serial number
                              • the current date (as also found in the Date header)
                              • the http body
                              Together with the robot's secret key we're now able to properly sign the requests.
                              I've packaged this in a small ruby library https://github.com/kangguru/botvac which is
                              quite basic and just covers just a little more than i needed for my usecase
                              but i'm happy to extend this over time.
                              Especially the part to obtain the secret key for the robot just be done via
                              trafic capturing, which is not the most convinent thing i can think of :)
                              I hope this already helps some people to build new things around their robot. I've mixed the
                              stuff with ifttt.com and now can plan the cleaning schedule via a google calendar, which
                              makes it really convinent to skip single days in a given schedule, which ist kinda painful to
                              solve with the mobile app.
                              happy hacking
                              UbiquitousU d96mbeD 2 Replies Last reply
                              • B
                                B
                                Brutus
                                Thats good news Kangguru. Nice job.
                                So maybe a noob question but How can I use this in my domotica program Domoticz running on Windows.
                                I can use LUA, Curl, Batch as far is a know.
                                Thnx for helping.
                                • kangguruK kangguru
                                  • the http body
                                  happy hacking
                                  UbiquitousU
                                  UbiquitousU
                                  Ubiquitous
                                  @kangguru
                                  I also figured it out some time ago. You get the robot secret key and serial number when you log in to beehive.neatocloud.com and request https://beehive.neatocloud.com/dashboard
                                  I've written a powershell module where I exposed the entire api (as implemented in the android and iphone app), complete with login. I've yet to upload it to github but I can send it to you if you're unsure about the beehive part.
                                  B 1 Reply Last reply
                                  • UbiquitousU
                                    UbiquitousU
                                    Ubiquitous
                                    As for replacing the cloud server, I don't think it's possible without rooting the robot. The first thing it does when it's connected to the internet is to start an HTTPS Comet session (long polling). The robot will kill the connection immediately if you try to MiTM it with a selfsigned certificate and there is no way to install new certificates on the robot. If anyone has opened the robot I'd be interested in pictures of the motherboard, especially of any pads labeled JTAG.
                                    RawLiquidR 1 Reply Last reply
                                    • UbiquitousU Ubiquitous
                                      @kangguru
                                      B
                                      B
                                      Brutus
                                      #41
                                      @Ubiquitous
                                      Also nice job! Hope to see a link soon to github so we can experiment with this to.
                                      Thanks for the work.
                                      • kangguruK
                                        kangguruK
                                        kangguru
                                        @Ubiquitous yea, i just was too lazy about the login stuff :) but i added the stuff over the weekend, to make it more "end"-user friendly.
                                          • the http body
                                          happy hacking
                                          d96mbeD
                                          d96mbeD
                                          d96mbe
                                          @kangguru I have not done any ruby before and I'm stuck trying to use the gem. I think I've managed to install Ruby, devkit and Git (and added git.exe to path which is needed to be able to 'bundle install'). I don't see any errors, but I am unable to find any binary named botvac to run. I've run "gem env" and none of the variables seems strange.
                                          Any suggestions? I'm on Windows 10 btw.
                                          BR / M
