  3. Home Assistant
  4. Home Assistant - How to recognize MySensors nodes
home assistant
64 Posts 7 Posters 55.1k Views 3 Watching
  • D
    drock1985
    Hey @martinhjelmare , I see HA was updated today; did your commits get added?
    My Projects
    2 Door Chime Sensor
    Washing Machine Monitor
    • D drock1985
      martinhjelmareM
      martinhjelmareM
      martinhjelmare
      @drock1985
      Hi!
      No, I've submitted a pull request, but I need to fix some things, and maybe change some of it. But hopefully it wont take too long.
      • MufasaM
        MufasaM
        Mufasa
        I have been trying to set up a switch in home assistant but I have had no luck in getting it to show up in the dashboard. I am using @martinhjelmare mysensors-component-switch branch of home assistant and the following sketch. Does anyone have any idea why this is happening? ```
         * Version 1.0 - Henrik Ekblad
         * Example sketch showing how to control physical relays.
         * This example will remember relay state after power failure.
         * http://www.mysensors.org/build/relay
        #include <MySigningNone.h>
        #include <MyTransportNRF24.h>
        #include <MyTransportRFM69.h>
        #include <MyHwATMega328.h>
        MyTransportNRF24 radio(RF24_CE_PIN, RF24_CS_PIN, RF24_PA_LEVEL_GW);
        //MyTransportRFM69 radio;
        // Message signing driver (none default)
        //MySigningNone signer;
        // Select AtMega328 hardware profile
        MyHwATMega328 hw;
        MySensor gw(radio, hw);
        MyMessage lightMsg(RELAY_1, S_LIGHT);
          gw.sendSketchInfo("Relay", "1.0");
          // Fetch relay status
            gw.present(sensor, S_LIGHT);
            pinMode(pin, OUTPUT);
            digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
          gw.send(lightMsg.set("0"));
          if (message.type==V_LIGHT) {
             // Change relay state
             // Store state in eeprom
        • MufasaM Mufasa
          MyHwATMega328 hw;
          martinhjelmareM
          martinhjelmareM
          martinhjelmare
          @Mufasa
          Hi!
          First of all my branch is still under development, and right now I think there is a bug, which could make it unable to install. I'll have more time to fix things next week.
          How does your home assistant config for mysensors look like?
          Have you looked at the logs of home assistant after start?
          • MufasaM
            MufasaM
            Mufasa
            @martinhjelmare
            Hey Martin, this is my config for the mysensors component
            mysensors:
              gateways:
                port: '/dev/ttyUSB0'
                persistance_file: '/home/pi/.homeassistant/mysensors.json'
              debug: true
              persistance: true
              version: '1.5'
            sensor:
              platform: mysensors
            switch:
              platform: mysensors
            Here is the log after start
            (hass-test)pi@raspberrypi:~/.homeassistant $ hass
            Config directory: /home/pi/.homeassistant
            WARNING:homeassistant.bootstrap:Colorlog package not found, console coloring disabled
            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=turn_off, domain=homea
            ssistant>
            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=turn_on, domain=homeas
            sistant>
            INFO:homeassistant.bootstrap:Home Assistant core initialized
            INFO:homeassistant.loader:Loaded switch from homeassistant.components.switch
            INFO:homeassistant.loader:Loaded discovery from homeassistant.components.discovery
            INFO:homeassistant.loader:Loaded conversation from homeassistant.components.conversation
            INFO:homeassistant.loader:Loaded sensor from homeassistant.components.sensor
            INFO:homeassistant.loader:Loaded history from homeassistant.components.history
            INFO:homeassistant.loader:Loaded recorder from homeassistant.components.recorder
            INFO:homeassistant.loader:Loaded http from homeassistant.components.http
            INFO:homeassistant.loader:Loaded logbook from homeassistant.components.logbook
            INFO:homeassistant.loader:Loaded sun from homeassistant.components.sun
            INFO:homeassistant.loader:Loaded mysensors from homeassistant.components.mysensors
            INFO:homeassistant.loader:Loaded frontend from homeassistant.components.frontend
            INFO:homeassistant.loader:Loaded api from homeassistant.components.api
            INFO:homeassistant.loader:Loaded updater from homeassistant.components.updater
            INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=recorder>
            INFO:homeassistant.loader:Loaded switch.mysensors from homeassistant.components.switch.mysensors
            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=turn_off, domain=switc
            h>
            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=turn_on, domain=switch
            INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=switch>
            INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=discovery>
            /home/pi/.homeassistant/lib/fuzzywuzzy/fuzz.py:33: UserWarning: Using slow pure-python SequenceMa
            tcher. Install python-Levenshtein to remove this warning
              warnings.warn('Using slow pure-python SequenceMatcher. Install python-Levenshtein to remove thi
            s warning')
            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=process, domain=conver
            sation>
            INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=conversation>
            INFO:homeassistant.loader:Loaded sensor.mysensors from homeassistant.components.sensor.mysensors
            INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=sensor>
            INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=http>
            INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=history>
            INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=logbook>
            INFO:urllib3.connectionpool:Starting new HTTP connection (1): maps.googleapis.com
            INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sun.sun=above_hori
            zon; friendly_name=Sun, next_rising=03:32:34 08-01-2016, next_setting=15:36:03 07-01-2016, elevat
            ion=47.84 @ 14:58:04 07-01-2016>, entity_id=sun.sun>
            INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=sun>
            INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=mysensors.sensors, di
            scovered=>
            INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=mysensors.switches, d
            iscovered=>
            INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=mysensors>
            INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=api>
            INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=frontend>
            INFO:urllib3.connectionpool:Starting new HTTPS connection (1): pypi.python.org
            INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state updater.updater=0.
            10.1; friendly_name=Update Available @ 14:58:06 07-01-2016>, entity_id=updater.updater>
            INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=updater>
            INFO:homeassistant.core:Starting Home Assistant (15 threads)
            INFO:homeassistant.core:Bus:Handling <Event homeassistant_start[L]>
            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=stop, domain=homeassis
            tant>
            INFO:mysensors.mysensors:Trying to connect to /dev/ttyUSB0
            INFO:homeassistant.core:Timer:starting
            INFO:homeassistant.components.mysensors:update persistence: node 1
            INFO:homeassistant.components.http:Starting web interface at http://0.0.0.0:8123
            INFO:netdisco.service:Scanning
            INFO:mysensors.mysensors:/dev/ttyUSB0 is open...
            INFO:mysensors.mysensors:Connected to /dev/ttyUSB0
            INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:gateway started, id=0, parent=0, distance=0
            INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=0,t=18,pt=0,l=5,sg=0:1.5.1
            INFO:homeassistant.components.mysensors:update sensor_update: node 1
            INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
            INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:send: 0-0-1-1 s=255,c=3,t=6,pt=0,l=1,sg=0,st=ok:M
            INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=3,t=11,pt=0,l=5,sg=0:Relay
            INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
            INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=1,c=0,t=3,pt=0,l=0,sg=0:
            INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=3,c=1,t=3,pt=0,l=1,sg=0:0
            INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.1.1
            ion=47.76 @ 14:58:04 07-01-2016>, old_state=<state sun.sun=above_horizon; friendly_name=Sun, next
            _rising=03:32:34 08-01-2016, next_setting=15:36:03 07-01-2016, elevation=47.84 @ 14:58:04 07-01-2
            martinhjelmareM 2 Replies Last reply
            • MufasaM Mufasa
              @martinhjelmare
              mysensors:
                gateways:
                debug: true
                persistance: true
                version: '1.5'
              sensor:
                platform: mysensors
              switch:
                platform: mysensors
              ssistant>
              sistant>
              h>
              s warning')
              sation>
              scovered=>
              iscovered=>
              tant>
              martinhjelmareM
              martinhjelmareM
              martinhjelmare
              #57
              @Mufasa
              The error is in your sketch. When you declare your message you should use child sensor id as first argument. Now you're using the pin number. So then you're sending the value from a child which hasn't been presented to home assistant.
              MyMessage msg(child-sensor-id, variable-type);
              • MufasaM Mufasa
                @martinhjelmare
                mysensors:
                  gateways:
                  debug: true
                  persistance: true
                  version: '1.5'
                sensor:
                  platform: mysensors
                switch:
                  platform: mysensors
                ssistant>
                sistant>
                h>
                s warning')
                sation>
                scovered=>
                iscovered=>
                tant>
                martinhjelmareM
                martinhjelmareM
                martinhjelmare
                @Mufasa
                Btw, you can remove sensor/switch platform mysensors in your config, if using the latest version of my branch.
                Everything else looks good in the config and the log, what I can tell.
                • MufasaM
                  MufasaM
                  Mufasa
                  @martinhjelmare
                  OK I have tried this but I'm am still having no luck, thank you for the quick replies.
                    gw.begin(incomingMessage, 1, true);
                      MyMessage lightMsg(sensor, S_LIGHT);
                  • MufasaM
                    MufasaM
                    Mufasa
                    @martinhjelmare
                    Here is the part of the log
                    INFO:urllib3.connectionpool:Starting new HTTPS connection (1): 192.168.1.29
                    INFO:homeassistant.components.mysensors:No sketch_name: node 1
                    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=1,c=1,t=2,pt=0,l=1,sg=0:0
                    • MufasaM
                      MufasaM
                      Mufasa
                      wrote on last edited by Mufasa
                      #61
                      @martinhjelmare
                      Just ran it again and it seams to have worked, Thanks a lot for the help!!
                      • MufasaM Mufasa
                        @martinhjelmare
                        martinhjelmareM
                        martinhjelmareM
                        martinhjelmare
                        @Mufasa
                        If you declare your variable lightMsg in the for loop, it will be overwritten if you have more than one relay. I think you can use an array the same length as number of relays and store the msg variable in the slots of the array. Then use the array where you need your msg variables.
                        • MufasaM
                          MufasaM
                          Mufasa
                          @martinhjelmare
                          Ok cool just sorted that out! Is there any way to change the names of the individual child sensors and the switch? For example to have a room name and the names of the lights in that room as each child.
                          • MufasaM Mufasa
                            @martinhjelmare
                            martinhjelmareM
                            martinhjelmareM
                            martinhjelmare
                            @Mufasa
                            Yes, you can make custom names and groups of your devices.
                            https://home-assistant.io/getting-started/devices/
                            Also read the blog post on customizing icons from version 0.8.
                            12.5k
