  3. 3 in 1 incl battery monitor
60 Posts 11 Posters 37.1k Views 12 Watching
  • carlierdC
    carlierdC
    carlierd
    @icebob: It's true that as I used signing feature, transmission is longer ! and in order to increase a little bit more I send every measure even if they not changed. I will probably upgrade my sketch to add a one-hour message at minimum and do not transfer mesure without change !
    • carlierdC carlierd
      Did you measured the current of your circuit ?
      What motion sensor are you using ? This component may consume a lot of current. Did you check this post ?
      If you wake-up the arduino every 30 seconds for measurement it's a problem. Every 5 minutes is the minimum I think. I have connected the Vcc pin of the DHT sensors and the Vcc of the LDR to a digital pin of the arduino and when a measurement is done I set the PIN to the HIGH state.
      First measurement of my sensor gives an IDLE current consumption close to 5uA which is really correct according to elements connected to the arduino (RFM69HW, DHT22 and LDR).
      David.
      the cosmic gateT
      the cosmic gateT
      the cosmic gate
      wrote on last edited by the cosmic gate
      #29
      David.
      Hello David,
      I tried to meassure , but didn't have the right stuff to do this good enough.
      The parts i use for this "project": DHT-22 (connected to D4), HC-SR501 (connected to D3)and connected to the 3.3V pin post , the VVC is connected to the VVC of the arduino pro mini 8 Mhz /3.3 V .
      And use the sketch as above:
      #define CHILD_ID_HUM 0
      #define CHILD_ID_TEMP 1
      #define CHILD_ID_MOT 2   // Id of the sensor child
      unsigned long SLEEP_TIME = 30000UL; // Sleep time between reads (in milliseconds)
      int oldBatteryPcnt = 0;
      DHT dht;
      float lastTemp = 0 ;
      float lastHum = 0 ;
      boolean lastTripped = false ;
      boolean metric = true;
      MyMessage msgMot(CHILD_ID_MOT, V_TRIPPED);
         analogReference(INTERNAL1V1);
         analogReference(INTERNAL);
        gw.begin();
        gw.sendSketchInfo("Humidity/Motion", "1.0");
        gw.present(CHILD_ID_MOT, S_MOTION);
        // get the battery Voltage
         #ifdef DEBUG
         Serial.println(sensorValue);
         #ifdef DEBUG
         Serial.print(batteryV);
         Serial.println(" V");
         Serial.print(batteryPcnt);
         Serial.println(" %");
           // Power up radio after sleep
           oldBatteryPcnt = batteryPcnt;
        // Read digital motion value
        if (tripped != lastTripped ) {
          Serial.println(tripped);
          gw.send(msgMot.set(tripped?"1":"0"));  // Send tripped value to gw
        if (isnan(temperature)) {
          lastTemp = temperature;
          if (!metric) {
          Serial.print("T: ");
        if (isnan(humidity)) {
            lastHum = humidity;
            Serial.print("H: ");
            Serial.println(humidity);
        gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
      So how do you connect the DHT / SR501 to the digital pin, and what's the sketch you're using ?
      There's more than meets the eye
      • carlierdC
        carlierdC
        carlierd
        You need to power the motion sensor all time as you want to detect any mouvement and not only every 2 minutes.
        Caution, in your sketch, the battery level is sent at the beginning and at the end.
        Did you tweak the motion sensor ?? Not tested yet but it seems that modification could (must ?) be done to reduce power consumption (LINK).
        Why do you wake-up the arduino every 30 seconds ? For temperature, every 5 or 15 minutes is enough.
        the cosmic gateT 1 Reply Last reply
        • carlierdC
          carlierdC
          carlierd
          @icebob: is you motion sensor often triggered ? I mean, is the sensor placed somewhere where there is a lot of mouvement ? I tried to do such sensor some months ago but my sensors was very often triggered on finally the time is sleep was small and my battery decreased very quickly !
          • icebobI
            icebobI
            icebob
            Currently I'm developing my boards, so there is no live device/sensor in my home. But in the future I plan to make a custom controller, and it will turn on/off the PIR sensors on the nodes, depending on the house is armed or not. So if I'm at home, PIR sensor won't watching. (It's just a plan for the present)
            • H
              H
              Heizelmann
              I am new in this forum so may be what I will tell here is posted already somewhere else.
              Firstly I would measure the battery voltage at the end after sending some values to see the voltage after some stress. Often it is the case for a nearly empty battery that it shows a relaxed high voltage after a long sleep and the break down on some stress. I think it is better to measure the lower level.
              Secondly for a motion sensor I would implement a wakeup on a pin change interrupt. As a stand-alone sensor this would be optimal for battery life time. In combination the other components you can use a large cycle time for getting temperature humidity and so on and for the motion sensor you get an intermediate interrupt on demand. If those event are too often for your desire, you can check it against time or count of last event and go back to sleep without sending.
                the cosmic gateT
                the cosmic gateT
                the cosmic gate
                Sure i modded the motion sensor as shown in the hyperlink , modded it this way :
                I don't know why i wake-up this arduino every 30 seconds, the sketch was fabricated by combine 2 or 3 other sketches to this one ( with help from @AWI )
                So if there are some tweaking thing to do, do not hesitate and change the sketch as you think it must be
                @icebob what's the sketch you using /testing ?
                AWIA 1 Reply Last reply
                • the cosmic gateT the cosmic gate
                  AWIA
                  AWIA
                  AWI
                  #35
                  @the-cosmic-gate No specific reason to have a 30 second interval. You can just change the SLEEP_TIME to whatever eg. 5 minutes == 300000UL. The pin change interrupt is present in the code..
                  • the cosmic gateT
                    the cosmic gateT
                    the cosmic gate
                    @icebob could you share us you're code ?
                    • icebobI
                      icebobI
                      icebob
                      @the-cosmic-gate sorry, I'm working a big complex sketch, I can't share my code currently.
                      • icebobI icebob
                        the cosmic gateT
                        the cosmic gateT
                        the cosmic gate
                        Big and complex sounds interesting :)
                        Could you maybe share us a sneak peak ;-)
                        • icebobI
                          icebobI
                          icebob
                          @the-cosmic-gate Nothing special. I made a big sketch, which contains 7-8 sensors (DHT, Si7021, MQ-2/9, PIR, Door magnet, Light, battery) reading code because I would like to upload the same sketch to all nodes and configurate it on controller side, which sensors is on the node and need to read.
                          But currently I reached the limit with I2C includes, so I need to think over this solution.
                          D 1 Reply Last reply
                          • carlierdC
                            carlierdC
                            carlierd
                            @the-cosmic-gate Did you solved your power consumption issue ?
                              the cosmic gateT
                              the cosmic gateT
                              the cosmic gate
                              Not yet, this because we moved to oneother house and didn't have the time now .
                              Also i had to disconnect and reconect all te sensors and domotica in this new house
                              • carlierdC
                                carlierdC
                                carlierd
                                I just finished my first motion sensor node and the power consumption in idle is about 75uA. Could be better but not too bad ;)
                                The only thing is that the range is a little bit low for good detection. It's between 1 and 3 meters ...
                                David.
                                  David.
                                  the cosmic gateT
                                  the cosmic gateT
                                  the cosmic gate
                                  David.
                                  Hello David
                                  Could you share what and how ? :)
                                  Thnx
                                  • D
                                    Dylano
                                    And how is this sensor acting?
                                    This is what i am looking for..
                                    How lang can this sensor work? [ i wil try this with a 9Volt battery with a nano ]
                                    What battery do you use?
                                    Domoticz, with a lot of working hardware, include mysensors :-)
                                    OpenPLI, RuneAudio, Solarmeter, etc......
                                    Not a great builder of software and hardware, more a user...
                                    Only i try to do my best :-(
                                    • carlierdC
                                      carlierdC
                                      carlierd
                                      This is the code I use but it's not perfect especially with the battery report.
                                      The principle is as follow when the sensor start:
                                      • node in sleep mode with interrupt enable
                                      • if a move is detected, the detection is reported to the gateway
                                      • the node then go in sleep mode WITHOUT interrupt for 5 minutes
                                      • then the node return to sleep mode with interrupt enable
                                      This is to avoid having many report (and power consumption) to the gateway.
                                      The code (not perfect ! I have to rework on it but it's ok for the moment):
                                      /* Motion sensor.        */
                                      /* Version     : 1.1.5        */
                                      /* Date        : 30/01/2016                                                           */
                                      /* Modified by : David Carlier                                                        */
                                      /*                            RST |             |  A5                                 */
                                      /*                            RX  |             |  A4                                 */
                                      /*                            TX  |   ARDUINO   |  A3                                 */
                                      /*     RFM69 (DIO0) --------- D2  |     UNO     |  A2                                 */
                                      /*           Motion --------- D3  |             |  A1                                 */
                                      /*            Power --------- D4  | ATMEGA 328p |  A0                                 */
                                      /*              +3v --------- VCC |             | GND --------- GND                   */
                                      /*              GND --------- GND |  8MHz int.  | REF                                 */
                                      /*                            OSC |             | VCC --------- +3v                   */
                                      /*                            OSC |             | D13 --------- RFM69 (SCK)           */
                                      /*                            D5  |             | D12 --------- RFM69 (MISO)          */
                                      /*                            D6  |             | D11 --------- RFM69 (MOSI)          */
                                      /*                            D7  |             | D10 --------- RFM69 (NSS)           */
                                      /*                            D8  |             |  D9                                 */
                                      /* +3v = 2*AA        */
                                      #include <MyTransportRFM69.h>
                                      //Constants
                                      #define SKETCH_NAME           "Motion Sensor"
                                      #define SKETCH_VERSION        "1.1.5"
                                      #define CHILD_ID              0
                                      #define CHILD_ID_VOLTAGE      1
                                      #define BATTERY_REPORT_CYCLE  4   //Report each hour (4 * 15')
                                      //Misc. variables
                                      uint8_t switchState = 2;
                                      unsigned long SLEEP_TIME = 820000; // Sleep time between reads (in milliseconds) (close to 15')
                                      unsigned long SLEEP_TIME2 = 275000; // Sleep time after int. (in milliseconds) (close to 5')
                                      uint8_t cycleInProgress = 0;
                                      uint8_t firstReportDone = 0;
                                      uint8_t firstReportWithZeroDone = 0;
                                      //Construct MySensors library
                                      MySigningAtsha204Soft signer;
                                      MyHwATMega328 hw;
                                      MyTransportRFM69 transport;
                                      MySensor node(transport, hw, signer);
                                      MyMessage msgSwitch(CHILD_ID, V_TRIPPED);
                                      MyMessage msgVolt(CHILD_ID_VOLTAGE, V_VOLTAGE);
                                      /* Initialization        */
                                        //Get time (for setup duration)
                                        #ifdef DEBUG
                                          unsigned long startTime = millis();
                                        //Start MySensors and send the Sketch Version Information to the Gateway
                                        node.begin();
                                        node.sendSketchInfo(SKETCH_NAME, SKETCH_VERSION);
                                        //Setup the button
                                        //Register all sensors
                                        node.present(CHILD_ID, S_MOTION);
                                        node.present(CHILD_ID_VOLTAGE, S_MULTIMETER);
                                        //Print setup debug
                                        #ifdef DEBUG
                                          int duration = millis() - startTime;
                                          Serial.print("[Setup duration: "); Serial.print(duration, DEC); Serial.println(" ms]");
                                      /* Main loop        */
                                        //Get time (for a complete loop)
                                        #ifdef DEBUG
                                        //Read digital motion value
                                        uint8_t value = digitalRead(DIGITAL_INPUT_SENSOR);
                                        //Get voltage for battery capacity report (add 0.1v to the read value)
                                        float realVoltage = (getVoltage() / 100.0) + 0.1;
                                        int batteryPcnt = realVoltage * 100 / 3.0;
                                        if (batteryPcnt > 100) {batteryPcnt = 100;}
                                        //Check is state change
                                        if (value != switchState)
                                          //Report result if not first loop
                                          if (firstReportDone != 0)
                                            node.send(msgSwitch.set(value==HIGH ? 1 : 0));
                                          //Store result
                                          switchState = value;
                                        //Report data to the gateway each hour
                                        if (cycleInProgress >= BATTERY_REPORT_CYCLE || firstReportDone == 0)
                                          node.send(msgVolt.set(realVoltage, 2));
                                          node.sendBatteryLevel(batteryPcnt);
                                          firstReportDone = 1;
                                        //Change cycle number
                                        cycleInProgress++;
                                        //Print debug
                                        #ifdef DEBUG
                                          Serial.print("Value is ");
                                          Serial.print(value, 1);
                                          Serial.print("   ");
                                          Serial.print("Cycle is ");
                                          Serial.print(cycleInProgress, 1);
                                          Serial.print("   ");
                                          Serial.print(realVoltage);
                                          Serial.print(" v");
                                          Serial.print("   ");
                                          Serial.print("["); Serial.print(duration, DEC); Serial.println(" ms]");
                                          Serial.flush();
                                        //Check if the motion was triggered and if it's not the first report
                                        if (switchState == 0 && firstReportWithZeroDone == 1)
                                          //Sleep 5' without interrupt
                                          node.sleep(SLEEP_TIME2);
                                        //Check if it's the first loop
                                        if (switchState == 0 && firstReportWithZeroDone == 0)
                                          firstReportWithZeroDone = 1;
                                        //Sleep until something happens with the sensor
                                        node.sleep(DIGITAL_INPUT_SENSOR-2, CHANGE, SLEEP_TIME);
                                      /* Allows to get the real Vcc (return value * 100).                                   */
                                      int getVoltage()
                                        const long InternalReferenceVoltage = 1056L;
                                        ADMUX = (0<<REFS1) | (1<<REFS0) | (0<<ADLAR) | (1<<MUX3) | (1<<MUX2) | (1<<MUX1) | (0<<MUX0);
                                        delay(50);  // Let mux settle a little to get a more stable A/D conversion
                                        //Start a conversion
                                        ADCSRA |= _BV( ADSC );
                                        //Wait for it to complete
                                        while (((ADCSRA & (1<<ADSC)) != 0));
                                        //Scale the value
                                        int result = (((InternalReferenceVoltage * 1023L) / ADC) + 5L) / 10L;
                                        return result;
                                      On one sensor I tweak the PIR (remove regulator and diode) but on a second one, I just plug the 3 v to the H pin (see other topic on the forum).
                                      Working correctly for the moment (one month) but it depends on the presence in the house.
                                      David.
                                      • D
                                        Dylano
                                        wrote on last edited by Dylano
                                        #46
                                        @ Carlied,
                                        What code is better that one of you or the one from cosmi gate?
                                        What are the different thing? Is your code check'the battery status?
                                        And i get a error:
                                        no matching function for call to 'MySensor::MySensor(MyTransportRFM69&, MyHwATMega328&, MySigningAtsha204Soft&)'
                                        • carlierdC
                                          carlierdC
                                          carlierd
                                          The error is because I enable the signing function !
                                          Remove the following line:
                                          And replace
                                          by
                                          MySensor node(transport, hw);
                                          I don't know who had the best sketch.
                                          I measure internal battery status using the 1.1 reference.
                                          David.
