  3. 3 in 1 incl battery monitor
60 Posts 11 Posters 37.1k Views 12 Watching
  • icebobI icebob
    @the-cosmic-gate sorry, I'm working a big complex sketch, I can't share my code currently.
    the cosmic gateT
    the cosmic gateT
    the cosmic gate
    Big and complex sounds interesting :)
    Could you maybe share us a sneak peak ;-)
    There's more than meets the eye
    • icebobI
      icebobI
      icebob
      @the-cosmic-gate Nothing special. I made a big sketch, which contains 7-8 sensors (DHT, Si7021, MQ-2/9, PIR, Door magnet, Light, battery) reading code because I would like to upload the same sketch to all nodes and configurate it on controller side, which sensors is on the node and need to read.
      But currently I reached the limit with I2C includes, so I need to think over this solution.
      D 1 Reply Last reply
      • carlierdC
        carlierdC
        carlierd
        @the-cosmic-gate Did you solved your power consumption issue ?
        the cosmic gateT 1 Reply Last reply
        • carlierdC carlierd
          the cosmic gateT
          the cosmic gateT
          the cosmic gate
          Not yet, this because we moved to oneother house and didn't have the time now .
          Also i had to disconnect and reconect all te sensors and domotica in this new house
          • carlierdC
            carlierdC
            carlierd
            I just finished my first motion sensor node and the power consumption in idle is about 75uA. Could be better but not too bad ;)
            The only thing is that the range is a little bit low for good detection. It's between 1 and 3 meters ...
            David.
              David.
              the cosmic gateT
              the cosmic gateT
              the cosmic gate
              David.
              Hello David
              Could you share what and how ? :)
              Thnx
              • D
                Dylano
                And how is this sensor acting?
                This is what i am looking for..
                How lang can this sensor work? [ i wil try this with a 9Volt battery with a nano ]
                What battery do you use?
                Domoticz, with a lot of working hardware, include mysensors :-)
                OpenPLI, RuneAudio, Solarmeter, etc......
                Not a great builder of software and hardware, more a user...
                Only i try to do my best :-(
                • carlierdC
                  carlierdC
                  carlierd
                  This is the code I use but it's not perfect especially with the battery report.
                  The principle is as follow when the sensor start:
                  • node in sleep mode with interrupt enable
                  • if a move is detected, the detection is reported to the gateway
                  • the node then go in sleep mode WITHOUT interrupt for 5 minutes
                  • then the node return to sleep mode with interrupt enable
                  This is to avoid having many report (and power consumption) to the gateway.
                  The code (not perfect ! I have to rework on it but it's ok for the moment):
                  /* Motion sensor.        */
                  /* Version     : 1.1.5        */
                  /* Date        : 30/01/2016                                                           */
                  /* Modified by : David Carlier                                                        */
                  /*                            RST |             |  A5                                 */
                  /*                            RX  |             |  A4                                 */
                  /*                            TX  |   ARDUINO   |  A3                                 */
                  /*     RFM69 (DIO0) --------- D2  |     UNO     |  A2                                 */
                  /*           Motion --------- D3  |             |  A1                                 */
                  /*            Power --------- D4  | ATMEGA 328p |  A0                                 */
                  /*              +3v --------- VCC |             | GND --------- GND                   */
                  /*              GND --------- GND |  8MHz int.  | REF                                 */
                  /*                            OSC |             | VCC --------- +3v                   */
                  /*                            OSC |             | D13 --------- RFM69 (SCK)           */
                  /*                            D5  |             | D12 --------- RFM69 (MISO)          */
                  /*                            D6  |             | D11 --------- RFM69 (MOSI)          */
                  /*                            D7  |             | D10 --------- RFM69 (NSS)           */
                  /*                            D8  |             |  D9                                 */
                  /* +3v = 2*AA        */
                  #include <MyTransportRFM69.h>
                  //Constants
                  #define SKETCH_NAME           "Motion Sensor"
                  #define SKETCH_VERSION        "1.1.5"
                  #define CHILD_ID              0
                  #define CHILD_ID_VOLTAGE      1
                  #define DIGITAL_INPUT_SENSOR  3
                  #define BATTERY_REPORT_CYCLE  4   //Report each hour (4 * 15')
                  //Misc. variables
                  uint8_t switchState = 2;
                  unsigned long SLEEP_TIME = 820000; // Sleep time between reads (in milliseconds) (close to 15')
                  unsigned long SLEEP_TIME2 = 275000; // Sleep time after int. (in milliseconds) (close to 5')
                  uint8_t cycleInProgress = 0;
                  uint8_t firstReportDone = 0;
                  uint8_t firstReportWithZeroDone = 0;
                  //Construct MySensors library
                  MySigningAtsha204Soft signer;
                  MyHwATMega328 hw;
                  MyTransportRFM69 transport;
                  MySensor node(transport, hw, signer);
                  MyMessage msgSwitch(CHILD_ID, V_TRIPPED);
                  MyMessage msgVolt(CHILD_ID_VOLTAGE, V_VOLTAGE);
                  /* Initialization        */
                    //Get time (for setup duration)
                    #ifdef DEBUG
                      unsigned long startTime = millis();
                    //Start MySensors and send the Sketch Version Information to the Gateway
                    node.begin();
                    node.sendSketchInfo(SKETCH_NAME, SKETCH_VERSION);
                    //Setup the button
                    pinMode(DIGITAL_INPUT_SENSOR, INPUT);
                    //Register all sensors
                    node.present(CHILD_ID, S_MOTION);
                    node.present(CHILD_ID_VOLTAGE, S_MULTIMETER);
                    //Print setup debug
                    #ifdef DEBUG
                      int duration = millis() - startTime;
                      Serial.print("[Setup duration: "); Serial.print(duration, DEC); Serial.println(" ms]");
                  /* Main loop        */
                    //Get time (for a complete loop)
                    #ifdef DEBUG
                    //Read digital motion value
                    uint8_t value = digitalRead(DIGITAL_INPUT_SENSOR);
                    //Get voltage for battery capacity report (add 0.1v to the read value)
                    float realVoltage = (getVoltage() / 100.0) + 0.1;
                    int batteryPcnt = realVoltage * 100 / 3.0;
                    if (batteryPcnt > 100) {batteryPcnt = 100;}
                    //Check is state change
                    if (value != switchState)
                      //Report result if not first loop
                      if (firstReportDone != 0)
                        node.send(msgSwitch.set(value==HIGH ? 1 : 0));
                      //Store result
                      switchState = value;
                    //Report data to the gateway each hour
                    if (cycleInProgress >= BATTERY_REPORT_CYCLE || firstReportDone == 0)
                      node.send(msgVolt.set(realVoltage, 2));
                      node.sendBatteryLevel(batteryPcnt);
                      firstReportDone = 1;
                    //Change cycle number
                    cycleInProgress++;
                    //Print debug
                    #ifdef DEBUG
                      Serial.print("Value is ");
                      Serial.print(value, 1);
                      Serial.print("   ");
                      Serial.print("Cycle is ");
                      Serial.print(cycleInProgress, 1);
                      Serial.print("   ");
                      Serial.print(realVoltage);
                      Serial.print(" v");
                      Serial.print("   ");
                      Serial.print("["); Serial.print(duration, DEC); Serial.println(" ms]");
                      Serial.flush();
                    //Check if the motion was triggered and if it's not the first report
                    if (switchState == 0 && firstReportWithZeroDone == 1)
                      //Sleep 5' without interrupt
                      node.sleep(SLEEP_TIME2);
                    //Check if it's the first loop
                    if (switchState == 0 && firstReportWithZeroDone == 0)
                      firstReportWithZeroDone = 1;
                    //Sleep until something happens with the sensor
                    node.sleep(DIGITAL_INPUT_SENSOR-2, CHANGE, SLEEP_TIME);
                  /* Allows to get the real Vcc (return value * 100).                                   */
                  int getVoltage()
                    const long InternalReferenceVoltage = 1056L;
                    ADMUX = (0<<REFS1) | (1<<REFS0) | (0<<ADLAR) | (1<<MUX3) | (1<<MUX2) | (1<<MUX1) | (0<<MUX0);
                    delay(50);  // Let mux settle a little to get a more stable A/D conversion
                    //Start a conversion
                    ADCSRA |= _BV( ADSC );
                    //Wait for it to complete
                    while (((ADCSRA & (1<<ADSC)) != 0));
                    //Scale the value
                    int result = (((InternalReferenceVoltage * 1023L) / ADC) + 5L) / 10L;
                    return result;
                  On one sensor I tweak the PIR (remove regulator and diode) but on a second one, I just plug the 3 v to the H pin (see other topic on the forum).
                  Working correctly for the moment (one month) but it depends on the presence in the house.
                  David.
                  • D
                    Dylano
                    wrote on last edited by Dylano
                    #46
                    @ Carlied,
                    What code is better that one of you or the one from cosmi gate?
                    What are the different thing? Is your code check'the battery status?
                    And i get a error:
                    no matching function for call to 'MySensor::MySensor(MyTransportRFM69&, MyHwATMega328&, MySigningAtsha204Soft&)'
                    • carlierdC
                      carlierdC
                      carlierd
                      The error is because I enable the signing function !
                      Remove the following line:
                      And replace
                      by
                      MySensor node(transport, hw);
                      I don't know who had the best sketch.
                      I measure internal battery status using the 1.1 reference.
                      David.
                      • D
                        Dylano
                        When i put this sketch in to a nano..
                        With a 9volt battery....
                        How long do think this working?
                        Or how long is this acting on your 3 volt battery's?
                        • carlierdC
                          carlierdC
                          carlierd
                          It depends on the activity close to the sensor so not possible to say but some people reach several month without problem.
                          In my house it's very fresh so I have not a lot of feedback to give.
                          David.
                          • D
                            Dylano
                            #50
                            5 days....:-1: on a 9volt block
                            The sketch on a nano
                            On my toilet.... so not a very busy room
                            Is there some one that live longer, with this sketch......?
                            • icebobI icebob
                              Dylano
                              Dear..
                              Did you finish your big code....
                              • carlierdC
                                carlierdC
                                carlierd
                                9v means that you are using a voltage regulator which probably consumes a lot of power.
                                Why not using AA or AAA battery directly connected to Vcc ?
                                David
                                  David
                                  Dylano
                                  David
                                  Motion and DHT needed 5volt i wash thinking..?
                                  So 9 @ the vcc should be strong enough i was thinking.
                                  And i do have @ the same time 3.5 for the radio
                                  Are the extern step up better than the step down on a nano?
                                  • carlierdC
                                    carlierdC
                                    carlierd
                                    The motion can be adapt to run on 3v easily (connect the Vcc to the H pad if available. You can find information on the forum). The DHT could also run on 3v. I have several nodes like that. No problem.
                                    Can't reply for the step-up because I don't use it.
                                    David.
                                      David.
                                      Dylano
                                      David.
                                      @ David
                                      How long is the 3v battery running whit this option?
                                      • carlierdC
                                        carlierdC
                                        carlierd
                                        @Dylano : My nodes are really new so difficult to say exactly but for the moment the oldest node was started one month ago (04/02) and battery still at 3.32v.
                                        David.
                                        • the cosmic gateT
                                          the cosmic gateT
                                          the cosmic gate
                                          i'am back in business after the "big move" and going to try again to get this 4:1 sensor working for a long time uning 2 x AA batteries.
                                          If someone has some new input, please let me know :) and feel free to change the sketch
                                          carlierdC 1 Reply Last reply
