  3. 3 in 1 incl battery monitor
60 Posts 11 Posters 37.1k Views 12 Watching
  • bjacobseB
    bjacobseB
    bjacobse
    Yes as Carlierd writes, it's important that the Arduino are controlling the voltage to the external components, like DHT.
    I might have overlooked, but which component are you using for motion sensing? maybe this component is also power-hungry
    • icebobI
      icebobI
      icebob
      @the-cosmic-gate Now I measured my dev circuit (Arduino Nano from China (cutted power led and desoldered regulator) + DHT22 + PIR + Battery measure resistor divider) and in gw.sleep (with 1 interrupt for PIR) the power comsumption is ~90uA.
      It wakes up every minutes, measuring and sending (~100ms and 5 - 20mA).
      So 100ms with 20mA and 59900ms with 0.09mA. The average current is 120uA and with 2 AA battery it is about 2 years.
      • E
        E
        ericvdb
        @icebob,
        whats that app you are using to do the battery calculations?
        • carlierdC
          carlierdC
          carlierd
          @icebob
          100ms for measurement and transmission seems very small ! I am at approximately 1500ms.
          Give me your secret now !! ;)
          • icebobI
            icebobI
            icebob
            @ericvdb http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=2680&dDocName=en545243. It's specified for PIC, but I select SLEEP mode in every cycle, so I can use for any uC.
            @carlierd: I have no extra secret. If I measure 3-4 sensor and every values is changed, the loop time is 100ms. Best case is 10-20ms (if every sensors is unchanged). I'm not using delay in the loop.
            • carlierdC
              carlierdC
              carlierd
              @icebob: It's true that as I used signing feature, transmission is longer ! and in order to increase a little bit more I send every measure even if they not changed. I will probably upgrade my sketch to add a one-hour message at minimum and do not transfer mesure without change !
              • carlierdC carlierd
                Did you measured the current of your circuit ?
                What motion sensor are you using ? This component may consume a lot of current. Did you check this post ?
                If you wake-up the arduino every 30 seconds for measurement it's a problem. Every 5 minutes is the minimum I think. I have connected the Vcc pin of the DHT sensors and the Vcc of the LDR to a digital pin of the arduino and when a measurement is done I set the PIN to the HIGH state.
                First measurement of my sensor gives an IDLE current consumption close to 5uA which is really correct according to elements connected to the arduino (RFM69HW, DHT22 and LDR).
                David.
                the cosmic gateT
                the cosmic gateT
                the cosmic gate
                wrote on last edited by the cosmic gate
                #29
                David.
                Hello David,
                I tried to meassure , but didn't have the right stuff to do this good enough.
                The parts i use for this "project": DHT-22 (connected to D4), HC-SR501 (connected to D3)and connected to the 3.3V pin post , the VVC is connected to the VVC of the arduino pro mini 8 Mhz /3.3 V .
                And use the sketch as above:
                #define CHILD_ID_HUM 0
                #define CHILD_ID_TEMP 1
                #define CHILD_ID_MOT 2   // Id of the sensor child
                unsigned long SLEEP_TIME = 30000UL; // Sleep time between reads (in milliseconds)
                int oldBatteryPcnt = 0;
                DHT dht;
                float lastTemp = 0 ;
                float lastHum = 0 ;
                boolean lastTripped = false ;
                boolean metric = true;
                MyMessage msgMot(CHILD_ID_MOT, V_TRIPPED);
                   analogReference(INTERNAL1V1);
                   analogReference(INTERNAL);
                  gw.begin();
                  gw.sendSketchInfo("Humidity/Motion", "1.0");
                  gw.present(CHILD_ID_MOT, S_MOTION);
                  // get the battery Voltage
                   #ifdef DEBUG
                   Serial.println(sensorValue);
                   #ifdef DEBUG
                   Serial.print(batteryV);
                   Serial.println(" V");
                   Serial.print(batteryPcnt);
                   Serial.println(" %");
                     // Power up radio after sleep
                     oldBatteryPcnt = batteryPcnt;
                  // Read digital motion value
                  if (tripped != lastTripped ) {
                    Serial.println(tripped);
                    gw.send(msgMot.set(tripped?"1":"0"));  // Send tripped value to gw
                  if (isnan(temperature)) {
                    lastTemp = temperature;
                    if (!metric) {
                    Serial.print("T: ");
                  if (isnan(humidity)) {
                      lastHum = humidity;
                      Serial.print("H: ");
                      Serial.println(humidity);
                  gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
                So how do you connect the DHT / SR501 to the digital pin, and what's the sketch you're using ?
                There's more than meets the eye
                • carlierdC
                  carlierdC
                  carlierd
                  You need to power the motion sensor all time as you want to detect any mouvement and not only every 2 minutes.
                  Caution, in your sketch, the battery level is sent at the beginning and at the end.
                  Did you tweak the motion sensor ?? Not tested yet but it seems that modification could (must ?) be done to reduce power consumption (LINK).
                  Why do you wake-up the arduino every 30 seconds ? For temperature, every 5 or 15 minutes is enough.
                  the cosmic gateT 1 Reply Last reply
                  • carlierdC
                    carlierdC
                    carlierd
                    @icebob: is you motion sensor often triggered ? I mean, is the sensor placed somewhere where there is a lot of mouvement ? I tried to do such sensor some months ago but my sensors was very often triggered on finally the time is sleep was small and my battery decreased very quickly !
                    • icebobI
                      icebobI
                      icebob
                      Currently I'm developing my boards, so there is no live device/sensor in my home. But in the future I plan to make a custom controller, and it will turn on/off the PIR sensors on the nodes, depending on the house is armed or not. So if I'm at home, PIR sensor won't watching. (It's just a plan for the present)
                      • H
                        H
                        Heizelmann
                        I am new in this forum so may be what I will tell here is posted already somewhere else.
                        Firstly I would measure the battery voltage at the end after sending some values to see the voltage after some stress. Often it is the case for a nearly empty battery that it shows a relaxed high voltage after a long sleep and the break down on some stress. I think it is better to measure the lower level.
                        Secondly for a motion sensor I would implement a wakeup on a pin change interrupt. As a stand-alone sensor this would be optimal for battery life time. In combination the other components you can use a large cycle time for getting temperature humidity and so on and for the motion sensor you get an intermediate interrupt on demand. If those event are too often for your desire, you can check it against time or count of last event and go back to sleep without sending.
                          the cosmic gateT
                          the cosmic gateT
                          the cosmic gate
                          Sure i modded the motion sensor as shown in the hyperlink , modded it this way :
                          I don't know why i wake-up this arduino every 30 seconds, the sketch was fabricated by combine 2 or 3 other sketches to this one ( with help from @AWI )
                          So if there are some tweaking thing to do, do not hesitate and change the sketch as you think it must be
                          @icebob what's the sketch you using /testing ?
                          AWIA 1 Reply Last reply
                          • the cosmic gateT the cosmic gate
                            AWIA
                            AWIA
                            AWI
                            #35
                            @the-cosmic-gate No specific reason to have a 30 second interval. You can just change the SLEEP_TIME to whatever eg. 5 minutes == 300000UL. The pin change interrupt is present in the code..
                            • the cosmic gateT
                              the cosmic gateT
                              the cosmic gate
                              @icebob could you share us you're code ?
                              • icebobI
                                icebobI
                                icebob
                                @the-cosmic-gate sorry, I'm working a big complex sketch, I can't share my code currently.
                                • icebobI icebob
                                  the cosmic gateT
                                  the cosmic gateT
                                  the cosmic gate
                                  Big and complex sounds interesting :)
                                  Could you maybe share us a sneak peak ;-)
                                  • icebobI
                                    icebobI
                                    icebob
                                    @the-cosmic-gate Nothing special. I made a big sketch, which contains 7-8 sensors (DHT, Si7021, MQ-2/9, PIR, Door magnet, Light, battery) reading code because I would like to upload the same sketch to all nodes and configurate it on controller side, which sensors is on the node and need to read.
                                    But currently I reached the limit with I2C includes, so I need to think over this solution.
                                    D 1 Reply Last reply
                                    • carlierdC
                                      carlierdC
                                      carlierd
                                      @the-cosmic-gate Did you solved your power consumption issue ?
                                        the cosmic gateT
                                        the cosmic gateT
                                        the cosmic gate
                                        Not yet, this because we moved to oneother house and didn't have the time now .
                                        Also i had to disconnect and reconect all te sensors and domotica in this new house
                                        • carlierdC
                                          carlierdC
                                          carlierd
                                          I just finished my first motion sensor node and the power consumption in idle is about 75uA. Could be better but not too bad ;)
                                          The only thing is that the range is a little bit low for good detection. It's between 1 and 3 meters ...
                                          David.
