  3. Start using IV in AES encryption?
31 Posts 5 Posters 13.2k Views 4 Watching
  • AnticimexA
    AnticimexA
    Anticimex
    Hm. Wonder how rf69 solves that. By always including IV in the payload?
    • mfalkviddM
      I think so. I don't see any other reason why they are limiting the message size when using AES (compared to sending without encryption).
      • AnticimexA
        AnticimexA
        Anticimex
        Well, I was not even aware that message size decresed for rf69 in that case. But is it still >=32B? Else things would probably break for signing as it claims all area up to MAX_MESSAGE_LENGTH (unless that value also adapts)
        • mfalkviddM
          From the rfm69 datasheet section 5.5.2. Packet Format:
          The length of the payload is limited to 255 bytes if AES is not enabled else the message is limited to 64 bytes
          • AnticimexA
            AnticimexA
            Anticimex
            Ok, good. I wonder if they just randomize the IV then and send it as part of the message. I don't see that improves security by much since anyone can listen in and obtain the same IV.
            It also makes the solution stateless, but I think there should be a handshaking anyway then. But I don't really know how it should be handled without causing too much trouble.
            • mfalkviddM
              It does provide security. Since the IV is XORed with the plaintext before encryption, two different IVs applied to the same plaintext message will result in very different ciphertext. One bit change in the IV should flip half the bits in the ciphertext, on average. Since the attacker doesn't know the plaintext, knowing the IV is useless. That's why the IV is designed to be be sent in the clear.
              • AnticimexA
                AnticimexA
                Anticimex
                Yes and no. Yes, it does add security. But plaintext can be predictable. Especially during node startup. So an attacker can figure out both IV and plaintext. It is the AES key that is secret and it takes some work to derive it.
                • mfalkviddM
                  The attacker doesn't need to figure out the IV, it is always available in plaintext in the radio message.
                  Yes, timing analysis at startup and other sidechannel attacks can help the attacker figure out what the plaintext is anyway. That's one of the reasons I don't care that much about encryption.
                  • AnticimexA
                    AnticimexA
                    Anticimex
                    Same here. The only usable use for encryption I see is audio/video streams, and the mysensors protocol is suitable for neither.
                    • mfalkviddM
                      I suggest that, unless someone else chips in in this discussion, we'll just note that the encryption has a (/one more) weakness. I might pick this up later on (it is definitely an interesting exercise), but I have projects that are more fun and useful that I prefer spending time on at the moment.
                      • AnticimexA
                        AnticimexA
                        Anticimex
                        I share your view.
                        • mfalkviddM
                          Oh, and thanks a lot for the feedback @Anticimex :star:
                          Having someone asking the right questions makes a big difference.
                          • AnticimexA
                            AnticimexA
                            Anticimex
                            #24
                            Well thanks for identifying the issue and a good explanation on why it is an issue.
                            Having read through your initial posts once more, however, I think I found a minor detail that you may have gotten wrong.
                            The message header also contain sender, so although you would be able to recognize ON command from a particular bode, you would not automatically know the command from other nodes as the header would differ.
                            • mfalkviddM
                              Oh. I thought the sender was part of the unencrypted header.
                              • AnticimexA
                                AnticimexA
                                Anticimex
                                I believe the entire message is encrypted. As far as I know the physical parts of both radio are multicast, and all data transfered, that is visible in the MySensors library, is MySensors specific and used for MySensors specific routing and such.
                                • mfalkviddM
                                  Alright. Then the zero IV becomes even less of a problem yes.
                                  • ahmedadelhosniA
                                    ahmedadelhosniA
                                    ahmedadelhosni
                                    I am not an expert in encryption but I really like your discussion.
                                    I believe as you have said, signing is the most critical issue to focus on now, and also we can't neglect encryption in the future.
                                    Thanks for your effort.
                                    AnticimexA 1 Reply Last reply
                                    • sundberg84S
                                      sundberg84S
                                      #29
                                      No knowledge in this but i appreciate you guys (which know more) are having this discussion.
                                      Not Mysensors, but it could be i guess - yesterday my RFLink (433mhz) told me it found a new device, a code for a on command. A quick search on the internet revealed it belong to a home alarm manufacturer which has 2 items sending 433mhz, their wireless motion detectors and a on/off remote for the alarm...
                                      I guess I could do some damage with this...
                                      • sundberg84S sundberg84
                                        AnticimexA
                                        AnticimexA
                                        Anticimex
                                        @sundberg84 yet another example of the incompetence of security providers for private homes. They are useless.
                                          AnticimexA
                                          AnticimexA
                                          Anticimex
                                          #31
                                          @ahmedadelhosni signing just underwent a major overhaul recently on development branch. We are also looking into a node locking mechanism when the node suspects it is under attack from someone trying to brute force a signed message or trying to predict nonces calculated from a bad rng implementation. So security is very much being looked at. And even with missing IV, AES encryption would add some obfuscation to the messages and will in combination with signing still deter a lot of potential attackers.
