  3. Irrigation Controller - Relays not working??
5 Posts 2 Posters 2.3k Views
  • C
    C
    ciscokid
    Hi All
    Background: I have been following the tutorial on the MySensors build section for the "Irrigation Controller"
    I have a Raspberry Pi 2b with Domoticz installed acting as the "Controller". The RaPi2b is powered by a 12v AC Transformer to an inline battery charger with an output of 12v DC and this output is connected to a cigarette/USB (the car charger type) with a 5v output.
    The RaPi2b is connected by a USB cable to an Arduino Uno R3 and this has the Serial Gateway code running on it with the NRF24L01+.
    I have another Arduino Uno R2 with an NRF24L01+ with the IrrigationController sketch running on it. It compiles and uploads fine.
    This Uno has a breadboard and I have connected every thing up as per the tutorial.
    a short video - apologies for the lack of narrative but I sound awful and just hate the sound of my own voice - one of those things :)
    Main Issue : From the video - everything works OK (so it seems) except that the relays don't come on. I have tested the relays with this IDE sketch - (go right to the bottom and look for the 8-channel Solid State Relay Board sketch) and the relays works fine!!
    This is the 8 Relay module (Active Low) with the optocouplers. All I want to see and hear is that the LED on the relay comes on and you can hear the click (just for testing) of the relay.
    I have the relay 1 on pin15 on the shift register and relays 2-8 on pins 1-7. The Gnd and VCC is connected OK
    I checked that the wiring was correct on the shift register as well as for the radio, LCD, push button etc as per the wiring diagram for the Irrigation Controller - all seems OK
    The debug output from the terminal monitor seems OK as well - Is there something on the code that has changed.
    I haven't changed anything on the code except for the LCD display as the tutorial guide used the 1602 (16 characters 2 lines) LCD and I have the 2004A.
    Apart from that change - nothing else.
    I bought another 8 Relay Module to test and exactly the same. When I push the pushbutton for example Zone 1 it counts down and off it goes abut the realy LED does not come on or the "click" sound of the relay activating
    Any ideas - I am really stuck as I must be doing something wrong??
    I have uploaded the video on my dropbox folder
    https://www.dropbox.com/s/2pfwk8hdgrydu7r/video1.mp4?dl=0
    • E
      E
      ericvdb
      Post your exact code, that could help us looking at the problem.
      • C
        C
        ciscokid
        Hi
        I am using the same code from the tutorial
        see below
        MySprinkler for MySensors
        Arduino Multi-Zone Sprinkler Control
        May 31, 2015
        *** Version 2.0
        * LED status indicator
        PARTS LIST:
        * Relays (8 channel)
        * NRF24L01 Radio
        * Arduino (I used a Pro Mini)
        * Capacitors (10uf and .1uf)
        * 3.3v voltage regulator
        * Resistors (270 & 10K)
        * Female Dupont Cables
        * LED
        * Push button
        * Shift Register (SN74HC595)
        * 18 gauge wire (for relay)
        INSTRUCTIONS:
          on the serial monitor.
        #include <Time.h>
        #include <LiquidCrystal.h>
        #define NUMBER_OF_VALVES 8  // Change this to set your valve count up to 16.
        #define RADIO_ID AUTO  // Change this to fix your Radio ID or use Auto
        #define SKETCH_VERSION "2.0"
        #define CHILD_ID_SPRINKLER 0
        #define ACTIVE_LOW // comment out this line if your relays are active high
        #ifdef ACTIVE_LOW
        #define ALL_VALVES_OFF 0xFFFF
        #define ALL_VALVES_OFF 0U
        #ifdef DEBUG_ON
        typedef enum {
        SprinklerStates;
        SprinklerStates lastState;
        byte menuState = 0;
        unsigned long menuTimer;
        byte countDownTime = 10;
        int allZoneTime [NUMBER_OF_VALVES + 1] = {0,20,20,20,20,20,20,20,20};
        int valveSoloTime [NUMBER_OF_VALVES + 1] = {0,20,20,20,20,20,20,20,20};
        int valveNumber;
        int lastValve;
        unsigned long startMillis;
        const int ledPin = 5;
        const int waterButtonPin = 3;
        boolean buttonPushed = false;
        boolean showTime = true;
        boolean clockUpdating = false;
        boolean recentUpdate = true;
        const char *dayOfWeek[] = {
        String valveNickName[17] = {
        time_t lastTimeRun = 0;
        //Setup Shift Register...
        const int latchPin = 8;
        const int clockPin = 4;
        const int dataPin  = 7;
        LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address to 0x27
          SERIAL_START(115200);
          pinMode(latchPin, OUTPUT);
          pinMode(clockPin, OUTPUT);
          pinMode(dataPin, OUTPUT);
          pinMode(ledPin, OUTPUT);
          attachInterrupt(1, PushButton, RISING); //May need to change for your Arduino model
          digitalWrite (ledPin, HIGH);
          updateRelays(ALL_VALVES_OFF);
          //delay(5000);
          lcd.begin(20, 4); //(16 characters and 2 line display)
          lcd.clear();
          lcd.backlight();
          lcd.createChar(0, clock);
          lcd.createChar(1, raindrop);
          delay(500);
          if (gw.loadState(0) == 0xFF); // EEPROM flag
            for (int i = 0; i < 4 ; i++)
              lastTimeRun = lastTimeRun | gw.loadState(i + 1); // assemble 4 bytes into an ussigned long epoch timestamp
          gw.begin(getVariables, RADIO_ID, false); // Change 'false' to 'true' to create a Radio repeating node
            gw.present(i, S_LIGHT);
          digitalWrite (ledPin, LOW);
          DEBUG_PRINTLN(F("Ready..."));
          lcd.setCursor(0, 0);
          lcd.setCursor(15, 0);
          lcd.write(byte(0));
          lcd.setCursor(0, 1);
          int clockCounter = 0;
            gw.requestTime(receiveTime);
            delay(1000);
            lcd.print(".");
            clockCounter++;
            if (clockCounter > 16)
              lcd.clear();
              delay(2000);
          lcd.clear();
            lcd.print(F(" Updating  "));
            lcd.print(i);
            boolean flashIcon = false;
            DEBUG_PRINT(i);
            DEBUG_PRINTLN(F(" Data..."));
            while (gw.process() == false)
              flashIcon = !flashIcon;
              gw.request(i, V_VAR1);
              delay(100);
              gw.request(i, V_VAR2);
              delay(100);
              gw.request(i, V_VAR3);
              delay(100);
          lcd.clear();
          updateClock();
          updateDisplay();
          //goGetValveTimes();
          if (buttonPushed)
            menuTimer = millis();
              state = ZONE_SELECT_MENU;
              menuState = 0;
              menuState++;
                menuState = 0;
            slowToggleLED ();
            if (state != lastState)
                delay(50);
                gw.send(msg1valve.setSensor(i).set(false), false);
              lcd.clear();
              lcd.setCursor(0,0);
              lcd.setCursor(0,1);
              delay(2000);
              lastValve = -1;
            if (lastValve != valveNumber)
                  gw.send(msg1valve.setSensor(i).set(true), false);
            lastValve = valveNumber;
            fastToggleLed();
              valveNumber = 1;
              startMillis = millis();
              valveNumber++;
                state = CYCLE_COMPLETE;
                lastValve = -1;
                lastTimeRun = now();
                DEBUG_PRINT(F("State = "));
                DEBUG_PRINTLN(state);
            fastToggleLed();
              DEBUG_PRINT(F("Zone: "));
              DEBUG_PRINTLN(valveNumber);
              fastToggleLed();
          else if (state = ZONE_SELECT_MENU)
            displayMenu();
          lastState = state;
        void displayMenu(void)
          static int lastSecond;
            lcd.clear();
            lcd.print(F("Starting"));
            lcd.print(F("."));
            Serial.print(".");
          lastSecond = thisSecond;
            if (menuState == 0)
              valveNumber = 1;
              state = RUN_ALL_ZONES;
              valveNumber = menuState;
              state = RUN_SINGLE_ZONE;
          lastMenuState = menuState;
        void updateRelays(int value)
          digitalWrite(latchPin, LOW);
          digitalWrite(latchPin, HIGH);
            buttonPushed = true;
        void fastToggleLed()
            fastLedTimer = millis ();
        void slowToggleLED ()
            slowLedTimer = millis ();
          boolean zoneTimeUpdate = false;
          if (message.isAck())
            if (message.sensor == i)
              if (message.type == V_LIGHT)
                if (switchState == 0)
                  if (i == 0)
                    valveNumber = 1;
                    valveNumber = i;
                    DEBUG_PRINTLN(i);
                DEBUG_PRINT(i);
                DEBUG_PRINT(F(" = "));
                DEBUG_PRINTLN(variable1);
                  allZoneTime[i] = variable1;
                  zoneTimeUpdate = true;
                DEBUG_PRINT(i);
                DEBUG_PRINTLN(variable2);
                  valveSoloTime[i] = variable2;
                if (newMessage.length() == 0)
                  DEBUG_PRINTLN(i);
                if (newMessage.length() > 16)
                  newMessage.substring(0, 16);
                valveNickName[i] = "";
                DEBUG_PRINT(F("Recieved new name for zone "));
                DEBUG_PRINT(i);
                DEBUG_PRINT(F(" and it is now called: "));
          if (zoneTimeUpdate)
              if (i != 0)
                DEBUG_PRINT(F("Zone "));
                DEBUG_PRINT(i);
                DEBUG_PRINTLN(allZoneTime[i]);
            recentUpdate = false;
        void updateDisplay()
          static boolean displayToggle = false;
            switch (state) {
              case STAND_BY_ALL_OFF:
                fastClear();
                if (displayToggle)
                  if (clockUpdating)
                    lcd.write(byte(0));
                  lcd.print(hourFormat12());
                  lcd.print(minute());
                  lcd.print(month());
                  lcd.print(day());
                  lcd.print(F("/"));
                  lcd.print(year() % 100);
                  if (clockUpdating)
                    lcd.write(byte(0));
                  lcd.setCursor(11, 1);
                  lcd.print(day(lastTimeRun));
              case RUN_SINGLE_ZONE:
                fastClear();
                if (displayToggle)
                  lcd.print(F(" Zone:"));
                  lcd.print(valveNumber);
                  lcd.print(F(" Active"));
                    lcd.print("min");
                    lcd.print("sec  ");
              case RUN_ALL_ZONES:
                fastClear();
                if (displayToggle)
                  lcd.print(F(" Active "));
                  lcd.print("min");
                  lcd.print("sec  ");
              case CYCLE_COMPLETE:
                if (displayToggle)
                  int totalTimeRan = 0;
                  lcd.print(totalTimeRan);
                  lcd.print(" Minutes   ");
            lastUpdateTime = millis();
          lastDisplayState = state;
          int lastSecond = second();
          int lastMinute = minute();
          int lastHour = hour();
          setTime(newTime);
            DEBUG_PRINT(hourFormat12());
            DEBUG_PRINT(minute());
            DEBUG_PRINT(month());
            DEBUG_PRINT(F("/"));
            DEBUG_PRINT(day());
            DEBUG_PRINTLN(year());
            showTime = false;
        void fastClear()
        void updateClock()
            lcd.write(byte(0));
            clockUpdating = true;
            lastVeraGetTime = millis();
          if (gw.loadState(0) != 0xFF)
            gw.saveState(0, 0xFF); // EEPROM flag for last date saved stored in EEPROM (location zero)
          for (int i = 1; i < 5; i++)
            gw.saveState(5 - i, byte(theDate >> 8 * (i - 1))); // store epoch datestamp in 4 bytes of EEPROM starting in location one
        void goGetValveTimes()
          static byte valveIndex = 1;
          if (millis() - valveUpdateTime >= 300000UL / NUMBER_OF_VALVES)// update each valve once every 5 mins (distributes the traffic)
            DEBUG_PRINTLN(F("Calling for Valve Data..."));
            lcd.write(byte(1)); //lcd.write(1);
            gw.request(valveIndex, V_VAR1);
            gw.request(valveIndex, V_VAR2);
            gw.request(valveIndex, V_VAR3);
            valveUpdateTime = millis();
            valveIndex++;
            if (valveIndex > NUMBER_OF_VALVES + 1)
              valveIndex = 1;
        I have been through Bulldogs posts and the workarounds for Domoticz with regard to VAR_1 2 and 3 which works but the Relays LED's dont switch on
        http://forum.mysensors.org/topic/153/irrigation-controller-up-to-16-valves-with-shift-registers/91
        Wallis
        • C
          C
          ciscokid
          I am also using this with some of the code commented out to handle the time duration for the zones as per Bulldogs recommendations
          May 31, 2015
          *** Version 2.0
          PARTS LIST:
          * NRF24L01 Radio
          * LED
          * Push button
          INSTRUCTIONS:
          #include <Time.h>
          #ifdef ACTIVE_LOW
          #ifdef DEBUG_ON
          typedef enum {
          SprinklerStates;
          byte menuState = 0;
          int valveNumber;
          int lastValve;
            "All Zones", "5 Sprinkler Front Door", "Zone 2", "Zone 3", "Zone 4", "Zone 5", "Zone 6", "Zone 7", "Zone 8", "Zone 9", "Zone 10", "Zone 11", "Zone 12", "Zone 13", "Zone 14", "Zone 15", "Zone 16"
            //delay(5000);
            lcd.clear();
            lcd.backlight();
            delay(500);
            lcd.write(byte(0));
              delay(1000);
              lcd.print(".");
              clockCounter++;
                lcd.clear();
                delay(2000);
            lcd.clear();
              lcd.print(i);
              DEBUG_PRINT(i);
                delay(100);
                delay(100);
                delay(100);
            lcd.clear();
            updateClock();
            updateDisplay();
           // goGetValveTimes();
            if (buttonPushed)
                menuState = 0;
                menuState++;
                  menuState = 0;
              slowToggleLED ();
                  delay(50);
                lcd.clear();
                lcd.setCursor(0,0);
                lcd.setCursor(0,1);
                delay(2000);
                lastValve = -1;
              fastToggleLed();
                valveNumber = 1;
                valveNumber++;
                  lastValve = -1;
              fastToggleLed();
                fastToggleLed();
              displayMenu();
            lastState = state;
              lcd.clear();
              lcd.print(F("."));
              Serial.print(".");
              if (menuState == 0)
                valveNumber = 1;
                    if (i == 0)
                      valveNumber = 1;
                      valveNumber = i;
                      DEBUG_PRINTLN(i);
                  DEBUG_PRINT(i);
                  DEBUG_PRINT(i);
                    DEBUG_PRINTLN(i);
                  DEBUG_PRINT(i);
            if (zoneTimeUpdate)
                if (i != 0)
                  DEBUG_PRINT(i);
              switch (state) {
                  fastClear();
                  if (displayToggle)
                    if (clockUpdating)
                      lcd.write(byte(0));
                    lcd.print(month());
                    lcd.print(day());
                    lcd.print(F("/"));
                    if (clockUpdating)
                      lcd.write(byte(0));
                  fastClear();
                  if (displayToggle)
                      lcd.print("min");
                      lcd.print("sec  ");
                case RUN_ALL_ZONES:
                  fastClear();
                  if (displayToggle)
                    lcd.print("min");
                    lcd.print("sec  ");
                  if (displayToggle)
            setTime(newTime);
              DEBUG_PRINT(day());
              showTime = false;
          void fastClear()
          void updateClock()
              lcd.write(byte(0));
              valveIndex++;
                valveIndex = 1;
          Wallis
          • C
            C
            ciscokid
            OK:) - Good news I have resolved the issues and thought I would update :)
            As mentioned I used the UNO's as my micro controllers - I decided to use the Pro Minis instead. I set it up on the breadboard and for some reason they worked. I noticed in the code that there was an interrupt command for the Pro Mini and I am not at the coding experience to understand if this might have been the problem when I used the UNO's??
            Anyway the code worked like a charm except now the LCD display kept crashing the system. After MUCH hours trying to figure out why and lots of experiments, I swapped out the Pro Mini for another one and this worked 100%.
            Having a closer look at my soldering on the A4 and A5 pins became clear where the issue was :)
            Anyway - its up and running 100% and am very happy. I can now control all the zones from my Domoticz (Raspberry Pi), notifications through Clikatell (SMS) and e-mail works well and I am very chuffed it works!!
            Thanks to Pete and Bulldog as well as the forum for the help !! You guys rock!!
            My next project is my Gargage door (open/closed) with the ultrasonic sensors - the wife is always leaving it open!!
            Wallis
