  2. Feature Requests
  3. Please add a guide for how to connect use the RFM69(H)W
Scheduled Pinned Locked Moved Feature Requests
16 Posts 5 Posters 8.9k Views 7 Watching
  • Cliff KarlssonC Offline
    Cliff Karlsson
    I have been trying to understand how to connect/configure the arduino+RFM69W for over a week now without success. You have to modify Mysensors.h, Myconfig.h, serialgateway sketch and more. I am missing something and can't get it to work and would love a complete guide of everything I need to alter to get it to work.
    • carlierdC Offline
      carlierdC Offline
      carlierd
      Hello Cliff, did you found information on how to use/connect the RFM69 ? I will start soon but it seems a little bit difficult to find information for using MySensor and RFM69 ... Thanks !
      hekH 1 Reply Last reply
      • carlierdC carlierd
        hekH Offline
        hekH Offline
        @carlierd
        I added a guide on the main site a few weeks ago:
        http://www.mysensors.org/build/connect_radio#wiring-the-rfm69-radio
        • carlierdC Offline
          carlierdC Offline
          carlierd
          Thanks Hek !! Do you also add procedure for modification of librairie to use RFM69 ? I understood that something needs to be done ?
          L 1 Reply Last reply
            L Offline
            L Offline
            lafleur
            wrote on last edited by lafleur
            @carlierd
            Yes, it would be very helpful to have a guide that shows what needed in software to add the RFM69 radio, how to change its I/O pins, change its power out, setup for HW variant... in 1.5 and 1.6
            A guide for using Moteino and Moteino-Mega with these radios would be helpful.
            • carlierdC Offline
              carlierdC Offline
              carlierd
              I think I can do it but not before end of February ...
              David.
              • hekH Offline
                hekH Offline
                wrote on last edited by hek
                Moteino should work out of the box with the dev-branch. Think it defaults to its pin-wiring.
                Not sure about the Moteino-mega though. Haven't got that one.
                alexsh1A 1 Reply Last reply
                • L Offline
                  L Offline
                  lafleur
                  The fix for the long term, is radio abstraction...
                  ie: radio = rfm69c, or radio = rfm69w, or radio = rfm69hw, or radio = nRF24 or radio = xyz
                  with some layer of abstraction for radio options like the ones below...
                  radio.set_freq= 912650000 ( this could imply the band also)
                  radio.set_band= 915MHZ
                  radio.set_channel = 72
                  #define MY_RFM69HW true
                  #define MY_RFM69_FREQUENCY RF69_915MHZ
                  #define RFM69_FREQUENCY 912650000
                  #define RFM69_NETWORKID 120
                  #define RF69_SPI_CS 10
                  #define RF69_IRQ_PIN 2
                  #define RF69_IRQ_NUM 0
                  all items like this should be abstracted to the radio level...
                  for now, it would be nice to have a guide for using each type of radio, with documentation on all known options...
                  (By the way, MY_RFM69_FREQUENCY should be MY_RFM69_BAND, as it selects the freq band the radio is in, not its exact frequency)
                  Thanks... my two bits...
                  • hekH Offline
                    hekH Offline
                    @lafleur
                    PRs against dev-branch is welcome.
                      alexsh1A Offline
                      alexsh1A Offline
                      alexsh1
                      @hek the pins on Moteino-Mega do not correspond:
                      D2 - DIO0
                      D4 - NSS
                      D5 - MOSI
                      D6 - MISO
                      D7 - SCK
                      Where do I change the softSPI settings please for RFM69(H)W? It is not in MyConfig.h for rfm69?
                      • L Offline
                        L Offline
                        lafleur
                        The SPI connections are hardware SPI in the chip, not a softSPI.. (may work, but I have not tested)
                        If you look at the data sheet and schematics for the Mega, you see that the SPI pins are very well documented.....
                        http://lowpowerlab.com/blog/2014/08/09/moteinomega-available-now/
                        https://github.com/LowPowerLab/Moteino/blob/master/MEGA/MoteinoMEGA_Schematic.pdf
                        Pins 7-6--5-4 are the four standard SPI pins, SCK, MISO, MOSI, SS, pin D2 is use as the interrupt from DIO0 on the radio... Look at the schematic and you see the correct pin-out from the radio to the processor... You will note the swap in MISO and MOSI pins. In on the CPU is out on the radio.. ect...
                        CPU RFM69
                        4 NSS
                        5 MOSI
                        6 MISO
                        7 SCK
                        2 DIO0
                        In my main code I use these defines... not in the config.h file... ( you could put them there also)
                        I'm using ver 2.0 code base, NOT 1.4 or 1.5
                        #ifdef __AVR_ATmega1284P__        // use for Moteino Mega Note: LED on Mega are 1 = on, 0 = off
                        // MoteinoMEGA
                        #define MY_RF69_SPI_CS            4
                        #define MY_RF69_IRQ_PIN           2
                        #define MY_RF69_IRQ_NUM           2
                        #define MY_DEFAULT_TX_LED_PIN     15   // the PCB, on board LED
                        #define MY_DEFAULT_ERR_LED_PIN    7
                        #define MY_DEFAULT_RX_LED_PIN     6
                        // Moteino
                        #define MY_RF69_SPI_CS            10
                        #define MY_RF69_IRQ_NUM           0
                        #define MY_DEFAULT_TX_LED_PIN     9   // 4 on sensor 2a PCB as LED3 (9 == on Moteino)
                        #define MY_DEFAULT_ERR_LED_PIN    6   // 6 on sensor 2a PCB as Err
                        #define MY_DEFAULT_RX_LED_PIN     7   // 7 on sensor 2a PCB as Rx
                        • L lafleur
                          CPU RFM69
                          4 NSS
                          5 MOSI
                          6 MISO
                          7 SCK
                          2 DIO0
                          // MoteinoMEGA
                          // Moteino
                          alexsh1A Offline
                          alexsh1A Offline
                          alexsh1
                          @lafleur Thanks. Yes I did look at the schematics of Mega.
                          Looking at your post above, where do you define MISO, MOSI and SCK please? I can see you defined MY_RF69_SPI_CS, MY_RF69_IRQ_PIN MY_RF69_IRQ_NUM only
                          • L Offline
                            L Offline
                            lafleur
                            The pins for the SPI device is supplied by the SPI support library for the CPU device that you are using in the Arduino IDE library
                            • L lafleur
                              alexsh1A Offline
                              alexsh1A Offline
                              alexsh1
                              @lafleur OK, but there is no such thing as soft SPI for this module?
                              • L Offline
                                L Offline
                                lafleur
                                There might be, do a search for: "arduino software spi"
                                Almost all chip supported by the Arduino IDE have one or more hardware SPI channels, each can be shared with multiple SPI devices connected to it with proper selection of the device CS line...
                                So the need for a software SPI is rare...
                                Good Luck...
                                • alexsh1A Offline
                                  alexsh1A Offline
                                  alexsh1
                                  @hek I can confirm that Moteino Mega USB (and I think Moteino Mega as well) works out of the box:
                                  Starting sensor (RRNNA-, 2.0.0-beta)
                                  Radio init successful.
                                  find parent
                                  send: 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
                                  find parent
                                  Init complete, id=255, parent=255, distance=255
                                  find parent
                                  11.8k
                                  113.2k
