  3. Can't get RFM69 working
27 Posts 5 Posters 12.1k Views 3 Watching
  • carlierdC
    carlierdC
    carlierd
    Did you set RFM69 parameters in MyConfig.h ?
    Put your gateway and sensor code. Without it's difficult to help you.
    I spent several hours to set mine.
    David
    • SweebeeS
      SweebeeS
      Sweebee
      Gateway:
       * LEDs (OPTIONAL):
      #define NO_PORTB_PINCHANGES
      #include <MySigningNone.h>
      #include <MyTransportRFM69.h>
      #include <MyTransportNRF24.h>
      #include <MyHwATMega328.h>
      #include <MyParserSerial.h>
      #include <stdarg.h>
      #include <PinChangeInt.h>
      #include "GatewayUtil.h"
      //MyTransportNRF24 transport(RF24_CE_PIN, RF24_CS_PIN, RF24_PA_LEVEL_GW);
      MyTransportRFM69 transport;
      //MySigningNone signer;
      //MySigningAtsha204 signer;
      // Hardware profile
      MyHwATMega328 hw;
      #ifdef WITH_LEDS_BLINKING
      MySensor gw(transport, hw /*, signer*/, RADIO_RX_LED_PIN, RADIO_TX_LED_PIN, RADIO_ERROR_LED_PIN);
      char inputString[MAX_RECEIVE_LENGTH] = "";    // A string to hold incoming commands from serial/ethernet interface
      int inputPos = 0;
      boolean commandComplete = false;  // whether the string is complete
      void parseAndSend(char *commandBuffer);
      void output(const char *fmt, ... ) {
         va_list args;
         va_start (args, fmt );
         va_end (args);
         Serial.print(serialBuffer);
        // Add interrupt for inclusion button to pin
        PCintPort::attachInterrupt(pinInclusion, startInclusionInterrupt, RISING);
        // Send startup log message on serial
        serial(PSTR("0;0;%d;0;%d;Gateway startup complete.\n"),  C_INTERNAL, I_GATEWAY_READY);
        checkInclusionFinished();
        if (commandComplete) {
          // A command wass issued from serial interface
          // We will now try to send it to the actuator
          parseAndSend(gw, inputString);
          inputPos = 0;
        SerialEvent occurs whenever a new data comes in the
       hardware serial RX.  This routine is run between each
       time loop() runs, so using delay inside loop can delay
       response.  Multiple bytes of data may be available.
      void serialEvent() {
        while (Serial.available()) {
          // get the new byte:
          char inChar = (char)Serial.read();
          // if the incoming character is a newline, set a flag
          // so the main loop can do something about it:
          if (inputPos<MAX_RECEIVE_LENGTH-1 && !commandComplete) {
            if (inChar == '\n') {
              inputString[inputPos] = 0;
              commandComplete = true;
              // add it to the inputString:
              inputString[inputPos] = inChar;
              inputPos++;
              inputPos = 0;
      Sensor (default binaryswitchsleep):
      #define SKETCH_MAJOR_VER "1"
      #define SKETCH_MINOR_VER "0"
      #define PRIMARY_CHILD_ID 3
      #define SECONDARY_CHILD_ID 4
      MySensor sensor_node;
        sensor_node.begin();
        // Setup the buttons
        // Activate internal pull-ups
        sensor_node.present(PRIMARY_CHILD_ID, S_DOOR);
        sensor_node.present(SECONDARY_CHILD_ID, S_DOOR);
        uint8_t value;
        static uint8_t sentValue=2;
        static uint8_t sentValue2=2;
        sensor_node.sleep(5);
        if (value != sentValue) {
           sentValue = value;
        if (value != sentValue2) {
           sentValue2 = value;
      And i have set the RFM in the config.h to: #define RFM69_FREQUENCY RF69_433MHZ
      • R
        R
        rene_2k2
        What is your hardware configuration ? Looks like the gateway is in a reset loop, no ? Possible power issue ?
        • SweebeeS
          SweebeeS
          Sweebee
          Arduino uno > level shifter > RFM69HW
          the level shifter / RFM is powered by a separate 5 > 3.3v converter.
          • carlierdC
            carlierdC
            carlierd
            hello,
            How did you powered the rfm69 on the uno ? using the 3.3 from the uno or using a voltage regulator ?
            I first used voltage regulator but I encountered some issues with the uno so I finally directly used the 3.3 from the uni board.
            another thing, remove not used include such 'MyTransportNRF24' in your code.
            I will post my gateway and sensor code thus evening as I can't do it from my phone now ...
            • SweebeeS
              SweebeeS
              Sweebee
              The RFM is powered by the regulator. Havent tried to power it from the 3v from the arduino yet.
              • carlierdC
                carlierdC
                carlierd
                The code as promise.
                For the gateway I don't change a lot of thing from the example provided in the lib:
                /* Serial gateway (RFM69 with encryption, soft signing and LEDs).                     */
                /* Version     : 0.1.1        */
                /* Date        : 29/11/2015                                                           */
                /* Modified by : David Carlier                                                        */
                #include <stdarg.h>
                //Construct MySensors library
                MyHwATMega328 hw;
                MySensor gw(transport, hw, signer, RADIO_RX_LED_PIN, RADIO_TX_LED_PIN, RADIO_ERROR_LED_PIN);
                //Variables
                int inputPos = 0;
                   va_list args;
                   va_end (args);
                /* Initialization        */
                  //Start MySensors
                  //Add interrupt for inclusion button to pin
                  //Send startup log message on serial
                /* Main loop        */
                    //A command wass issued from serial interface
                    //We will now try to send it to the actuator
                    inputPos = 0;
                        inputPos++;
                        inputPos = 0;
                For the sensor, there is more difference from the humidity example:
                /* Temperature, humidity and luminosity measurements.                                 */
                /* Version     : 1.1.5        */
                /* Date        : 04/01/2016                                                           */
                /*                            RST |             |  A5                                 */
                /*                            RX  |             |  A4                                 */
                /*                            TX  |   ARDUINO   |  A3                                 */
                /*     RFM69 (DIO0) --------- D2  |     UNO     |  A2                                 */
                /*            DHT22 --------- D3  |             |  A1                                 */
                /*            Power --------- D4  | ATMEGA 328p |  A0 --------- Light dep. resistor   */
                /*              +3v --------- VCC |             | GND --------- GND                   */
                /*              GND --------- GND |  8MHz int.  | REF                                 */
                /*                            OSC |             | VCC --------- +3v                   */
                /*                            OSC |             | D13 --------- RFM69 (SCK)           */
                /*                            D5  |             | D12 --------- RFM69 (MISO)          */
                /*                            D6  |             | D11 --------- RFM69 (MOSI)          */
                /*                            D7  |             | D10 --------- RFM69 (NSS)           */
                /*                            D8  |             |  D9                                 */
                /* Power = Vcc for LDR and DHT22 et SWITCH.                                           */
                /* +3v = 2*AA        */
                #include <dht.h>
                #define CHILD_ID_HUM 0
                #define CHILD_ID_TEMP 1
                #define CHILD_ID_LIGHT 2
                #define CHILD_ID_VOLTAGE 3
                #define POWER_PIN 4
                unsigned long SLEEP_TIME = 275000; // Sleep time between reads (in milliseconds)
                MyHwATMega328 hw;
                MySensor gw(transport, hw, signer);
                dht DHT;
                MyMessage msgLum(CHILD_ID_LIGHT, V_LEVEL);
                MyMessage msgVolt(CHILD_ID_VOLTAGE, V_VOLTAGE);
                  //Get time (for setup duration)
                  #ifdef DEBUG
                    unsigned long startTime = millis();
                  //Start MySensors
                  gw.begin();
                  //Send the Sketch Version Information to the Gateway
                  gw.sendSketchInfo("GHAS sensor", "1.1.5");
                  //Register all sensors to gw (they will be created as child devices)
                  gw.present(CHILD_ID_VOLTAGE, S_MULTIMETER);
                  //Delay for DHT22
                  delay(1500);
                  //Print setup debug
                  #ifdef DEBUG
                    int duration = millis() - startTime;
                    Serial.print("[Setup duration: "); Serial.print(duration, DEC); Serial.println(" ms]");
                /* Main loop        */
                  //Get time (for a complete loop)
                  #ifdef DEBUG
                  //Power on
                  powerOnPeripherals();
                  delay(2000);
                  //Get DHT22 data
                  int dht22Result = DHT.read22(HUMIDITY_SENSOR_DIGITAL_PIN);
                  switch (dht22Result)
                    case DHTLIB_OK:
                                //Serial.println("OK,\t");
                    case DHTLIB_ERROR_CHECKSUM:
                                #ifdef DEBUG
                                  Serial.println("Checksum error,\t");
                    case DHTLIB_ERROR_TIMEOUT:
                                #ifdef DEBUG
                                  Serial.println("Time out error,\t");
                    case DHTLIB_ERROR_CONNECT:
                                #ifdef DEBUG
                                  Serial.println("Connect error,\t");
                    case DHTLIB_ERROR_ACK_L:
                                #ifdef DEBUG
                                  Serial.println("Ack Low error,\t");
                    case DHTLIB_ERROR_ACK_H:
                                #ifdef DEBUG
                                  Serial.println("Ack High error,\t");
                    default:
                                #ifdef DEBUG
                                  Serial.println("Unknown error,\t");
                  //Get temperature and humidity
                  float temperature = 0;
                  float humidity = 0;
                  if (dht22Result == DHTLIB_OK)
                    temperature = DHT.temperature;
                    humidity = DHT.humidity;
                  //Get power before luminosity to use real voltage
                  float realVoltage = getVoltage() / 100.0;
                  int batteryPcnt = realVoltage * 100 / 3.0;
                  if (batteryPcnt > 100) {batteryPcnt = 100;}
                  int lux = computeIlluminance(realVoltage);
                  //Power off
                  powerOffPeripherals();
                  //Send data to gateway
                  gw.send(msgLum.set(lux));
                  gw.send(msgVolt.set(realVoltage, 2));
                  //Print debug
                  #ifdef DEBUG
                    Serial.print(temperature, 1);
                    Serial.print(" degC");
                    Serial.print("   ");
                    Serial.print(humidity, 1);
                    Serial.print(" %");
                    Serial.print("   ");
                    Serial.print(lux);
                    Serial.print(" lx");
                    Serial.print("   ");
                    Serial.print(realVoltage);
                    Serial.print(" v");
                    Serial.print("   ");
                    Serial.print("["); Serial.print(duration, DEC); Serial.println(" ms]");
                    Serial.flush();
                  //Sleep
                  gw.sleep(SLEEP_TIME);
                /* Allows to compute illuminance (in LUX) from LIGHT_SENSOR_ANALOG_PIN.               */
                int computeIlluminance(float realVoltage)
                  //Get luminosity
                  int luminosity = analogRead(LIGHT_SENSOR_ANALOG_PIN);
                  //Calculating the voltage in the input of the ADC
                  double voltage = realVoltage * ((double)luminosity / 1024.0);
                  //Calculating the resistance of the photoresistor in the voltage divider
                  double resistance = (10.0 * realVoltage) / voltage - 10.0;
                  //Calculating the intensity of light in lux and return it
                  int illuminance = 255.84 * pow(resistance, -10/9);
                  return illuminance;
                /* Allows to get the real Vcc (return value * 100).                                   */
                int getVoltage()
                  const long InternalReferenceVoltage = 1056L;
                  ADMUX = (0<<REFS1) | (1<<REFS0) | (0<<ADLAR) | (1<<MUX3) | (1<<MUX2) | (1<<MUX1) | (0<<MUX0);
                  delay(50);  // Let mux settle a little to get a more stable A/D conversion
                  //Start a conversion
                  ADCSRA |= _BV( ADSC );
                  //Wait for it to complete
                  while (((ADCSRA & (1<<ADSC)) != 0));
                  //Scale the value
                  int result = (((InternalReferenceVoltage * 1023L) / ADC) + 5L) / 10L;
                  return result;
                /* Allows to power ON peripherals.                                                    */
                void powerOnPeripherals()
                  //Power-up
                  pinMode (POWER_PIN, OUTPUT);
                  digitalWrite (POWER_PIN, HIGH);
                  delay(1);
                /* Allows to power OFF peripherals.                                                   */
                void powerOffPeripherals()
                  //Power off
                  digitalWrite (HUMIDITY_SENSOR_DIGITAL_PIN, LOW);
                  digitalWrite (POWER_PIN, LOW);
                  pinMode (HUMIDITY_SENSOR_DIGITAL_PIN, INPUT);
                  pinMode (POWER_PIN, INPUT);
                David
                SweebeeS 1 Reply Last reply
                • SweebeeS
                  SweebeeS
                  Sweebee
                  Thanks, will try it :)
                  • L
                    L
                    lafleur
                    How do you change I/O pins define for the RFM69 if using a different platform??
                    will this work under 1.6 development ?
                    • carlierdC carlierd
                      #include <stdarg.h>
                      MyHwATMega328 hw;
                      //Variables
                      int inputPos = 0;
                         va_list args;
                         va_end (args);
                        //Start MySensors
                      /* Main loop        */
                          inputPos = 0;
                              inputPos++;
                              inputPos = 0;
                      /*                            RST |             |  A5                                 */
                      /*                            RX  |             |  A4                                 */
                      /*                            D8  |             |  D9                                 */
                      /* +3v = 2*AA        */
                      #include <dht.h>
                      #define POWER_PIN 4
                      MyHwATMega328 hw;
                      dht DHT;
                        #ifdef DEBUG
                        //Start MySensors
                        gw.begin();
                        //Delay for DHT22
                        delay(1500);
                        //Print setup debug
                        #ifdef DEBUG
                      /* Main loop        */
                        #ifdef DEBUG
                        //Power on
                        delay(2000);
                        //Get DHT22 data
                          case DHTLIB_OK:
                                      #ifdef DEBUG
                                      #ifdef DEBUG
                                      #ifdef DEBUG
                                      #ifdef DEBUG
                                      #ifdef DEBUG
                          default:
                                      #ifdef DEBUG
                        float humidity = 0;
                        //Power off
                        //Print debug
                        #ifdef DEBUG
                          Serial.print("   ");
                          Serial.print(" %");
                          Serial.print("   ");
                          Serial.print(lux);
                          Serial.print("   ");
                          Serial.print(" v");
                          Serial.print("   ");
                          Serial.flush();
                        //Sleep
                        //Get luminosity
                        return illuminance;
                      int getVoltage()
                        //Scale the value
                        return result;
                        //Power-up
                        delay(1);
                        //Power off
                      David
                      SweebeeS
                      SweebeeS
                      Sweebee
                      @carlierd I tried to compile your gateway but i get this error:
                      Arduino: 1.6.5 (Mac OS X), Board:"Arduino Uno"
                      SerialGateway:52: error: no matching function for call to 'MySensor::MySensor(MyTransportRFM69&, MyHwATMega328&, MySigningAtsha204Soft&, int, int, int)'
                      SerialGateway.ino:52:91: note: candidates are:
                      In file included from SerialGateway.ino:37:0:
                      /Users/Wiebe/Documents/Arduino/libraries/MySensors/MySensor.h:158:2: note: MySensor::MySensor(MyTransport&, MyHw&)
                      /Users/Wiebe/Documents/Arduino/libraries/MySensors/MySensor.h:158:2: note:   candidate expects 2 arguments, 6 provided
                      /Users/Wiebe/Documents/Arduino/libraries/MySensors/MySensor.h:149:7: note: MySensor::MySensor(const MySensor&)
                       class MySensor
                      /Users/Wiebe/Documents/Arduino/libraries/MySensors/MySensor.h:149:7: note:   candidate expects 1 argument, 6 provided
                      • carlierdC
                        carlierdC
                        carlierd
                        I am using stable version of MySensors not the dev branch. What version are you using ?
                        David
                          David
                          SweebeeS
                          SweebeeS
                          Sweebee
                          @carlierd 1.5 https://github.com/mysensors/Arduino/tree/master
                          • carlierdC
                            carlierdC
                            carlierd
                            Did you enabled signing feature in MyConfig.h : #define MY_SIGNING_FEATURE ??
                            • SweebeeS
                              SweebeeS
                              Sweebee
                              I think the gateway works now, i removed the separate 5-3.3v converter and used the arduino 3.3v.
                              Now the sensor, i uploaden your sketch, but i get no init message?
                              • carlierdC
                                carlierdC
                                carlierd
                                Did you connect the gateway to a controller ? or to MYSController ? You get the gateway ready message ?
                                For the sensor, you are using the sketch I upload ?
                                Debug mode is enable in MyConfig.h ?
                                You should have some debug messages in the console when connecting to the node.
                                David.
                                • SweebeeS
                                  SweebeeS
                                  Sweebee
                                  wrote on last edited by Sweebee
                                  The problem is on the uno everything seems to work fine.
                                  for the sensor i attached the RFM to a arduino pro mini 3.3v
                                  double checked the wiring, tried 2 different RFM's, tried 2 arduino pro mini's.
                                  uploaden the gateway to it and i get:
                                  but when i try to send something with the pro mini i get nothing back, while on the UNO I get:
                                  0;0;3;0;9;send: 0-0-10-10 s=1,c=1,t=2,pt=0,l=1,sg=0,st=fail:1
                                  So on the pro mini i get the init message, but no message when i try to send something.
                                  • carlierdC
                                    carlierdC
                                    carlierd
                                    RFM69 or RFM69HW ?
                                    For RFM69HW you have to modify MyTransportRFM69.hand enable HW model on line 33.
                                    Replace bool isRFM69HW=falseby bool isRFM69HW=true.
                                    Nothing on the serial output of the pro mini ??
                                    • fetsF
                                      fetsF
                                      fets
                                      Do you use 4.7uF capacitor ?
                                      • SweebeeS
                                        SweebeeS
                                        Sweebee
                                        Yes i have the HW versions, so i replaced bool isRFM69HW=false by bool isRFM69HW=true
                                        added a capacitor.
                                        refreshed and still no feedback after sending.
                                        I get a serial output from the pro mini on start. but no more serial messages when i try to send a message.
                                        • carlierdC
                                          carlierdC
                                          carlierd
                                          Put your arduino pro debug message to see what happens.
                                          You used DHT22 ?
