  3. Rechargeable Lithium Ion Sensor Custom PCB
71 Posts 12 Posters 37.6k Views 8 Watching
  • H Heizelmann
    @HenryWhite said:
    Did you made measurements to compare the range of the nRF when mounted onto the board and mounted sticking out?
    No. With shield PCB I meant the ground fill. In your pictures I can not see if you leave this region out for filling. At least it is prophylactic.
    What I tested is only this antenna modification. For me it really helps. May be this can be taken into account for the layout.
    HenryWhiteH
    HenryWhiteH
    HenryWhite
    wrote on last edited by HenryWhite
    I plan to use this mod too. I'm curious if the additional wire(s) has/have to be straight or if you can twist it/them. If you use a single straight wire, it should already be compatible with the layout, the wire would be above the arduino.
    • F
      F
      flopp
      I have some thoughts about voltage.
      A LiPo is 4.2 volt when it is 100% charged or when you have charged it for a few minutes, power will come from charger TP4056.
      Do you use the regulator on Arduino board?
      Can I use your files and modify it?
      HenryWhiteH 1 Reply Last reply
      • F flopp
        HenryWhiteH
        HenryWhiteH
        HenryWhite
        Yes, absolutely.
        But I don't think you need a voltage regulator. At least on the arduino I ordered there's already an onboard regulator which is rated for up to 12V DC input.
        • akumarA
          akumarA
          akumar
          I'm thinking of building the same kind of board for protyping sensors, also powered by Li-Ion or LiPo cells as I have plenty lying around :)
          The TP4056 board will protect the cell if voltage drops bellow 2.8v. The arduino and nrf24 module should be fine at those values. This might not be the case for all sensors...
          However when charging or at 4.2V the nrf24 module will exceed its 3.6V max input power. Did you manage to get your board working ?
          • akumarA akumar
            HenryWhiteH
            HenryWhiteH
            HenryWhite
            That's right, but for this case (which will only happen once a year or less (depending on configuration and used lipo battery) you have the battery measurement supported through mysensors onboard, which can tell you if the voltage drops below a certain level.
            Also make sure to get the new tp4056 because the old and common one does not have a battery protection circuit!
            No, the nRF24 is hooked up to VCC of the arduino, which has an internal voltage regulator. So the VCC output of the arduino should always be max. 3.3V, as long as the input is below 12V.
            • akumarA
              akumarA
              akumar
              If the arduino is outputing 3.3v that means that you are powering the arduino with the RAW pin, isn't it ?
              If so make sure the linear voltage regulator on the arduino will be able to provide the 3.3v if battery voltage drops below 3.3v (so from 3.3v to 2.8v). I don't think they can boost the voltage from 2.8v back to 3.3v :(
              • akumarA akumar
                HenryWhiteH
                HenryWhiteH
                HenryWhite
                #21
                That's not necessary - for this case you have the battery measurement circuit as mentioned in my previous post.
                mfalkviddM 2 Replies Last reply
                • HenryWhiteH HenryWhite
                  #22
                  @HenryWhite said:
                  That's not correct. You are mixing up something. The RAW pin is for unregulated power input. With this you can bypass the internal voltage regulator. When you use the normal VCC input, the voltage will be regulated to 3.3V, if the input is (depending on arduino model) between 3.3V and 12V.
                  It is actually the other way around. From https://www.arduino.cc/en/Main/ArduinoBoardProMin :
                  If you're supplying unregulated power to the board, be sure to connect to the "RAW" pin on not VCC.
                  Power on RAW pin results in the regulator being in use.
                  Power on Vcc bypasses the regulator.
                      HenryWhiteH
                      HenryWhiteH
                      HenryWhite
                      #24
                      indeed. seems like I mixed up something there :D
                      I will update the eagle files when i have time to.
                      • mfalkviddM
                        I did the same mistake in the beginning. not sure why it is so confusing :-)
                        • akumarA
                          akumarA
                          akumar
                          So if I sum up, powering this node with a single Lipo cell will work by connecting the Lipo to the raw pin on the arduino. This will work from 4.2v to 3.4v. This is not that good for the battery life.
                          Using 2*AA batteries with a boost converter seems a lot easier...
                          I'm almost giving up on this idea : I liked the flat form factor of the lipos and they were solar pannel friendly. Is there a way to use a voltage regulator from 4.2v to 3.4v and then switch the circuit to a boost converter from 3.3v to 2.8v ?
                          HenryWhiteH F 3 Replies Last reply
                          • akumarA akumar
                            HenryWhiteH
                            HenryWhiteH
                            HenryWhite
                            #27
                            @akumar It's the same problem as with all lipos. But you have to consider that it will take a really long time until the battery hits 3.4V or less. There are even smartphone batteries with 3000+ mAh which are very small.
                            Also it seems to be good for battery lifetime when the voltage does not drop that much compared to using a step-up converter below 3.4V.
                            • akumarA akumar
                              F
                              F
                              flopp
                              @akumar
                              You shall not go below 3,0v on a Lipo, it will/can get damage
                              • akumarA
                                akumarA
                                akumar
                                Looking at discharge curves I can see that I should be able to squeeze 75% of the battery capacity if I charge it back when it reaches 3.3v. On a low power node this could work.
                                @flopp The reason I was mentionning 2.8v is because the battery protection module will kick in at this voltage. But you're right, no reason to go this far.
                                Thanks !
                                F 1 Reply Last reply
                                • akumarA akumar
                                  Thanks !
                                  F
                                  F
                                  flopp
                                  @akumar
                                  That battery protection is built-in on battery, but must take it with care. There as some cheap LiPo that doesn't have that feature.
                                  I don't think the TP4056 have protection or does it?
                                  • akumarA
                                    akumarA
                                    akumar
                                    Sure ! The newer ones have a battery protection chip. I've tested it and it kicks in at 2.8v.
                                    http://www.aliexpress.com/item/Free-Shipping-10pcs-lot-1a-lithium-battery-charging-18650-with-protection-one-plate-protec-2-in/1876166772.html
                                    • F
                                      F
                                      flopp
                                      Now I see, there are pads for battery and pads for out. Looks good
                                      • F flopp
                                        HenryWhiteH
                                        HenryWhiteH
                                        HenryWhite
                                        #33
                                        Correct. The old Tp4056 modules do not have the OUT terminals (and therefore won't fit on the pcb I designed in this thread)
                                        Why should it only work on a low power node?
                                          #34
                                          hi.
                                          "Why should it only work on a low power node?"
                                          with time we will have more and more things to charge every week/day (phone, watch, iot...), so I would say : for less maintenance ? lol
                                          more seriously, it is a nice project I will follow it ;) I have one board to order (not ordered yet) with a li charger but mine is definitely not diy (too small chip so it is for stencil use).
                                          Mobile phone batt is a very nice idea :smiley: I am a more confident than cheap lipo..and I have some old cheap galaxy s2 batt..How do you plan to hook the battery to your board?
