  3. Transformers
Transformers
transformer
9 Posts 5 Posters 3.7k Views 1 Watching
  • RJ_MakeR Offline
    RJ_MakeR Offline
    RJ_Make
    Looking for very small 220vac to 3.3vdc transformer module. I have a project that involves controlling 2 220V water heaters. The project box is fairly small, so the smaller the better.
    RJ_Make
    DammeD 1 Reply Last reply
    • M Offline
      M Offline
      Mrlynx
      something like this?
      http://www.ebay.com/itm/AC-DC-Power-Supply-Isolation-module-Input-AC-90-240V-Output-DC-3-3V-500mA-/251365063335?pt=LH_DefaultDomain_0&hash=item3a86867aa7
      http://www.sa2avr.se
      RJ_MakeR 1 Reply Last reply
      • jendrushJ Offline
        jendrushJ Offline
        jendrush
        Maybe small usb wall charger for 1,4$, and regulator from 5V to 3.3V for 0,1$ would be good solution?
        RJ_MakeR Z 2 Replies Last reply
        • M Mrlynx
          RJ_MakeR Offline
          RJ_MakeR Offline
          RJ_Make
          @Mrlynx That looks like it might work.. Thank you!
          RJ_Make
          • jendrushJ jendrush
            RJ_MakeR Offline
            RJ_MakeR Offline
            RJ_Make
            @jendrush I think it would be to large, and I've not seen a 220v version before.
            RJ_Make
            • RJ_MakeR RJ_Make
              DammeD Offline
              DammeD Offline
              Damme
              Code Contributor
              @ServiceXp I've been looking at things like this http://www.digikey.com/product-highlights/us/en/cui-vsk-series-encapsulated-ac-dc-modules/853
              • DammeD Damme
                DammeD Offline
                DammeD Offline
                Damme
                Code Contributor
                wrote on last edited by Damme
                There are smaller things too, http://www.cui.com/product/resource/pbk-3.pdf but I don't like the clearance on that component. and it has no temperature protection.. But there are tons of things to choose from. tell me if you find something you like.. :)
                Digikey search
                Edit; NOTE:
                If you are playing with mains BE CAREFUL about if you are buying a insulated one or not, You could have something like ~225v on your 0v and ~230v on 5v and if you touch this you will smoke.
                • DammeD Damme
                  Digikey search
                  Edit; NOTE:
                  RJ_MakeR Offline
                  RJ_MakeR Offline
                  RJ_Make
                  @Damme Awesome set of options. Thank You!!
                  Thanks for the warning, I'm a newb to electronics/arduino, but am very familiar with high voltage equipment. (HA-HVACR Tech.)
                  RJ_Make
                    Z Offline
                    Z Offline
                    Zeph
                    wrote on last edited by Zeph
                    For some projects, using cheap chargers can be a good option. However, I'd open any such cheap charger and have a look before using it. Some appear to be acceptably designed, and some appear to be dangerous designs, from the teardowns. For example:
                    http://www.righto.com/2012/10/a-dozen-usb-chargers-in-lab-apple-is.html
                    He rated 2 out of the batch as downright dangerous.
                    Even with one which appears to have a reasonable design with enough separation, I would not be poking around in the sensors or PCB while they are currently powered from 230V with a cheap charger. Unplug first. And if you need power for programming or testing, use your normal USB supply (eg: a laptop or a high quality power supply) or batteries. Maybe that's just me, but this seems like a reasonably easy additional precaution. Even if the PCB has good separation, the insulation between windings of a transformer could be marginal, for example.
                    Most readers here probably already know this, just thought it was worth noting for anybody coming to this hobby more recently.
                    11.9k
                    113.3k
