  3. In wall light switch node - Custom PCB
custompcbinwallnodelight switchswitch
245 Posts 15 Posters 183.6k Views 23 Watching
    Samuel235
    UPDATE!
    Just a little update to keep you all posted; I have sent my Gerber files off, they have been confirmed to be of the correct format and my boards are now being produced. I ordered the parts last night, enough for backups/errors, soon as everything arrives i will get this made up and give you another update on the situation of the board. The only thing i wasn't comfortable with was the price of the screw terminal and the fact i used a through hole capacitor for the 100uF (C7). The next revision of the board i will be using a surface mount 100uF capacitor for this, now i managed to find it. The terminal for the switches, I'm looking at maybe having a crimped push connector on the switch that just slots onto some sort of header pin on the board instead of a screw terminal.
    Either way, Homini Light Switch Node Version 1.1 Revision 1 is on its way!
    MySensors 2.1.1
      Samuel235
      I have just received confirmation that the board house has released the PCB's. Lets see how long these take to get here! Itching to get this module on the move again. I will be back soon as they get here, don't go anywhere!
      MySensors 2.1.1
        Samuel235
        UPDATE!
        I have just received all components for the boards, we're just waiting on the boards themselves to arrive from ITead Studios.
        Time to get this project moving!
        MySensors 2.1.1
          Samuel235
          While waiting for my boards to arrive i decided to create a housing for my gateway including flashing status LEDs. Its in no means a finished product, but i feel its enough to house the gateway components while i'm building my network to save any incidents destroying the parts. Within the next few days i will get a guide up with images and maybe a video of the LEDs and their function up on a hardware guide topic. image.jpg
          MySensors 2.1.1
            Samuel235
            So then, we have another update!
            UPDATE!
            The boards ave arrived safe and sound, i have populated one of them with everything apart from the nRF module. So, its time to get the bootloader burnt. This is the daunting task for me, i have no idea what i am doing here, so if you guys feel like you could give me some helpful pointers in the right direction I would really appreciate all the help you can offer.IMG_7098.JPG IMG_7099.JPG
            MySensors 2.1.1
            • sundberg84S
              sundberg84S
              Hi! Depending on which bootloader you want, but why not go with the MySensors with OTA updates by tekka?
              http://forum.mysensors.org/topic/838/windows-gui-controller-for-mysensors/75
              If you want the original arduino bootloader: https://www.arduino.cc/en/Hacking/Bootloader?from=Tutorial.Bootloader
              S 2 Replies Last reply
              • sundberg84S sundberg84
                Samuel235
                @sundberg84 - I was reading that exact post from tekka as you posted this. However, i'm probing around on my board and found for some reason my 3v line is 0.24v. So I have to do some investigation work on that this morning. Hoping the bootloader will be a piece of cake once the hardware is working as should be.
                MySensors 2.1.1
                  Samuel235
                  @sundberg84 So i have my hardware issue corrected now. Am i reading Tekka's instructions correctly, this new board is to be connected through serial to my gateway and then programmed essentially by the gateway through MYSController which is connected to my gateway via ethernet? Does that sound correct?
                  MySensors 2.1.1
                  • sundberg84S
                    sundberg84S
                    #64
                    No, i would recommend you have a look at some youtube tutorials. Im not familiar with programming through the ISP headers which i think you should do. I use a seperate arudino uno as ISP programmer.
                      #65
                      @samuel235: cool. happy for you.
                      first you need to burn the bootlader in your atmel 328p. When it comes as ic-only, factory setting is 1mhz internal rc. and there is no bootloader yet. So you can't use ftdi at this moment, nor ota. So you need to burn the bootloader with avrspi. Like @sundberg84 said you can use the "arduino uno as isp programmer" method if you have an uno..On my side, I don't use this method, I prefer to use an usbasp. But both method works well.
                      When burning bootloader, you will need to set fuses too, corrsponding to the bootloader.
                      Sorry, I have not much time to make an howto, just point you in some direction..i hope it helps a little bit.
                      Edit: you can find some howto here http://www.gammon.com.au/breadboard
                      S 1 Reply Last reply
                      • scalzS scalz
                        Samuel235
                        @scalz I'm using a USBasp programmer, however i think i may have an issue with my reset pin. I have continuity on every other ISP header pin and the associated pin on the ATMega but not the reset pin. Is this normal, should i be seeing continuity between ISP RESET and pin 29 on the ATMega?
                        MySensors 2.1.1
                          I think you should have continuity between avrspi connector RST pin and your atmega RST pin...don't see why not. Have you checked your routing? I think so...Maybe a bad solder on this pin???
                          • scalzS scalz
                            Samuel235
                            #68
                            @scalz I may have found the problem, i have just completed a x25 magnification inspection on the boards and every board has atleast one filled VIA. I'm going to get a makeshift jumper in place on this board and test for continuity again.
                            I get continuity from the pin to the one side of the capacitor but nothing from the MEGA to the pin, it feels like the capacitor is stopping it coming through...
                            MySensors 2.1.1
                              #69
                              oki, so if continuity between rst atmega and one side of capacitor (dtr ftdi capacitor, right?) it should be ok. The capa is for dtr of ftdi (it is a trick for resetting atmega from ide when you want to upload).
                              Is your schematic updated on your first post? I don't see a 10k resistor pullup for rst...you need it to keep rst line to 1 and then when you push a rst button, or want to reprogram it by ftdi or avrspi, it will go to low/0 briefly to tell the mcu to reset.
                              if not done, try to connect a 10k res between your rst pin and vcc
                              • scalzS scalz
                                Samuel235
                                @scalz I have just uploaded a zip file with my .brd and .sch files. Sorry, forgot to update those
                                MySensors 2.1.1
                                  #71
                                  oki seems good. so I imagine you have continuity between rst atmega/one side of the 10k res. so what is your problem to program it?
                                  when programming with avrspi, be careful with the fuses, especially for clock freq. For instance, if you set the clock fuse for external crystal and you have no onboard, then you could have some problem to re-set the fuse to internal clock as at this moment, the mcu will wait for an external clock. I am not sure as I have never tested this, and I am careful when I set the fuses, but in eventuality I am tired and make a mistake, I like to put a crystal footprint. but sometimes, you have not enough room unfortunately.
                                  • scalzS scalz
                                    Samuel235
                                    @scalz I get continuity from the ATMega to the resistor and one side of the cap. But its not flowing through the cap. So you think i should be good to program from there? I try to test a connection to the board with AVRDude, by running "C:>avrdude -c usbasp -p m328p" and then i get
                                    avrdude: initialization failed, rc=1
                                             Double check connections and try again, or use -P to override this check.
                                    avrdude done. Thank you.
                                    MySensors 2.1.1
                                      yep, for capa it is not a problem. so it should work, but your log seems indicating a connection problem...but I don't see it :flushed: and I don't have much time for the moment...sorry.
                                      for avrdude cli, I can't help you as I use avrdudess. no need of cli, a little bit easier.
                                      • scalzS scalz
                                        Samuel235
                                        #74
                                        @scalz While feeding the board 3v, every part of the VCC line from the battery to the chip is perfect, however if i test a VCC pin and a GND pin on the chip, it reads 0.06. Would this be an issue?
                                        Maybe i should have connected all of the vcc's together or even pulled another to the battery directly, the only vcc connection going to the mega is from the DTR/RESET pin on the SPI header, that flows through the resistor to the mega. Is this an incorrect wiring issue?
                                        MySensors 2.1.1
                                          Samuel235
                                          Okay, so for some reason i seem to have not connected all the VCC's together unfortunately, i personally believe this is where my issue lies. If anyone feels differently, please shout out and let me know.
                                          MySensors 2.1.1
