  3. My motion / dallas / light sensor
3 in 1 example
7 Posts 3 Posters 4.8k Views 6 Watching
  • R Offline
    R Offline
    rtenklooster
    wrote on last edited by rtenklooster
    I was looking for a good working non-battery powered 3 in 1 sketch but couln't find one, that worked the way i wanted it to work. My wishlist:
    • Instant update's on temp and light changes
    • Only send motion stop if motion stopped for at least 10 seconds
    • Only send motion start if motion stopped
    • No delays
    • Make it easy to add other sensors / remove excisting ones *
    • Enable / disable serial debug by define *
    I have made this sketch, hope it can be usefull to someone else. Have tried to document the code as good as possible. I'm planning to add defines in the future to be able to add / remove a temp sensor without altering the whole sketch. So just define light / temp / hum / dhtxx etc, and the sketch will work. The same goes for serial debugging,
    What i used: Dallas DS18b20 , PIR, LDR
    // Include libaries
    #include <DallasTemperature.h>    // For Dallas temp sensor
    #include <OneWire.h>              // For Dallas temp sensor
    // Define mysensors data
    #define CHILD_ID_LIGHT 0             // LDR child ID
    #define CHILD_ID_TEMP 1              // Temp child ID
    #define CHILD_ID_MOTION 2            // MOTION child ID
    #define LIGHT_SENSOR_ANALOG_PIN A2   // LDR PIN
    #define MOTION_INPUT_SENSOR 2        // Motion input pin
    #define ONE_WIRE_BUS 3               // DALLAS pin
    #define MAX_ATTACHED_DS18B20 16      // DALLAS max nr. of sensors
    // Initialize mysensor
    // Initialize dallas
    // Store variables
    long previousMillis = 0;        // last time the sensors are updated
    long sensorInterval = 5000;     // interval at which we will take a measurement ( 5 seconds)
    int lastLightLevel;             // Holds last light level
    float lastTemperature[MAX_ATTACHED_DS18B20]; // Holds DALLAS temperatures
    int numSensors=0;               // Holds number of sensors
    boolean metric = true;          // Celcius or fahrenheid
    int calibrationTime = 30;       // the time we give the sensor to calibrate (10-60 secs according to the datasheet)
    long unsigned int lowIn;        // the time when the sensor outputs a low impulse
    long unsigned int pause = 10000;//the amount of milliseconds the sensor has to be low before we assume all motion has stopped
    boolean lockLow = true;
    boolean takeLowTime;
    // Initialize childs
    MyMessage msgLight(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
    MyMessage msgTemp(CHILD_ID_TEMP,V_TEMP);
    MyMessage msgMot(CHILD_ID_MOTION, V_TRIPPED);
      sensors.begin();
      gw.begin();
      // Send sketch info to controller
      gw.sendSketchInfo("Light sensor without delay", "1.0");
      // Register child sensors
      gw.present(CHILD_ID_MOTION, S_MOTION);
      // Set pinmode for motion sensor
      pinMode(MOTION_INPUT_SENSOR, INPUT);
      // Pull down motion pin
      digitalWrite(MOTION_INPUT_SENSOR, LOW);
          gw.present(i, S_TEMP);
      delay(calibrationTime); // Give pir time to calibrate
      // Check if sensors have changed
      sensorCheck();
      if(digitalRead(MOTION_INPUT_SENSOR) == HIGH){
        if(lockLow){
          //makes sure we wait for a transition to LOW before any further output is made:
          lockLow = false;
          Serial.print("motion detected at ");
          Serial.print(millis()/1000);
          Serial.println(" sec");
          gw.send(msgMot.set("1"));  // Send tripped value to gw
        takeLowTime = true;
      if(digitalRead(MOTION_INPUT_SENSOR) == LOW){
         if(takeLowTime){
          lowIn = millis();          //save the time of the transition from high to LOW
          takeLowTime = false;       //make sure this is only done at the start of a LOW phase
         //if the sensor is low for more than the given pause, we assume that no more motion is going to happen
         if(!lockLow && millis() - lowIn > pause){
             //makes sure this block of code is only executed again after new motion sequence has been detected
             lockLow = true;
             Serial.print("motion ended at ");      //output
             Serial.print((millis() - pause)/1000);
             gw.send(msgMot.set("0"));  // Send tripped value to gw
    void sensorCheck(){
      if(currentMillis - previousMillis > sensorInterval) {
        // Save the current millis
        // take action here:
        // Begin light measurement
        int lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
        Serial.print("Lightlevel: ");
        Serial.println(analogRead(LIGHT_SENSOR_ANALOG_PIN));
          gw.send(msgLight.set(lightLevel));
          lastLightLevel = lightLevel;
        // end light measurement
        // Begin dallas temperature
          float temperature = static_cast<float>(static_cast<int>((gw.getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
          Serial.print("Temperature ");
          Serial.print(i);
          Serial.print(" ");
         if (lastTemperature[i] != temperature && temperature != -127.00) {
            gw.send(msgTemp.setSensor(i).set(temperature,1));
        // End dallas temperarures
    • V Offline
      V Offline
      velkrosmaak
      I just gave this a try and it works great! I can't believe nobody else has commented yet.
      The only issue I have is that there doesn't appear to be a Celsius reading, despite the fact that metric is set to true at the top of the code.
      This is what I see over the console:
      Temperature 0 65.30
      Lightlevel: 290
      Temperature 0 65.30
      Lightlevel: 324
      send: 0-0-0-0 s=10,c=1,t=23,pt=2,l=2,sg=0,st=fail:69
      Temperature 0 65.30
      I'm guessing the 0 before the 65.30 is where the Celsius reading is supposed to be, but I can't see in the code where the temperature is being calculated.
      Excuse a noob! Thanks for any help! :)
      • E Offline
        E Offline
        ericvdb
        The 0 before 65.30 is the index number of the temperature sensor.
        And to get Celsius, you should make the controller return true for gw.getConfig().isMetric or change
        to
        float temperature = static_cast<float>(static_cast<int>((metric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
        • V Offline
          V Offline
          velkrosmaak
          Perfect! Thank you!
          • V Offline
            V Offline
            velkrosmaak
            Actually - it gets weirder.
            Does the DS18b20 contain a barometer? Not according to the datasheet. But this node, using the sketch above, seems to create additional sensors, some with garbage data, and some with what appear to be barometric pressure readings. I have some other (BMP180) mysensors which report the same value for pressure as the sketch above.
            I can't understand what's causing the garbage data though. For example, MySensorsDevice#33 has a reading of 1149829168. Some are null, and there are a few other random integers there too. Each with their own MySensorsDevice#.
            Can anyone point me in the right direction as to what's going on? It's getting annoying having to remove all these fake sensors daily! :)
            • E Offline
              E Offline
              ericvdb
              Are you using a wifi gateway? Others reported strange values too: http://forum.mysensors.org/topic/2934/wifi-gateway-motion-sensor-value-1107296256-instead-of-tripped/2
              • V Offline
                V Offline
                velkrosmaak
