  3. In wall light switch node - Custom PCB
custompcbinwallnodelight switchswitch
245 Posts 15 Posters 183.6k Views 23 Watching
    #90
    I think you may add some net labels at RST, DTR. So it is less ambiguous to read ;)
    Here a basic sparkfun arduino mini schematic so you can check :)
    https://cdn.sparkfun.com/assets/0/7/5/5/1/51eec304ce395f104c000000.png
    S 1 Reply Last reply
    • scalzS scalz
      Samuel235
      @scalz - Labels have been added to make it easier to understand.
      However, this is exactly how I wired Rev1, it didn't work until I hacked together the reset pin. I'm getting even more confused at to why my Rev1 didn't work now, I thought that by bypassing/altering the connections with some wires and it working would indicate that I had wired Rev1 incorrectly, I used the link you sent to me as reference while I was making Rev1.
      However, i have done as you have suggested and attached images below. I've also attached my eagle files in case you wanted to trace any routes you can't see clearly on the images.
      0_1453481212181_HominiSwitchNode.zip
      MySensors 2.1.1
      • m26872M
        m26872M
        m26872
        Looks good now except that AVR ISP (JP1) pin 5 should connect straight to RESET and not to DTR.
        • m26872M m26872
          Samuel235
          @m26872 - Does the FTDI need to go to RESET or DTR? I'm feeling DTR because all the FTDI programmers i'm using is labeled with DTR and not RESET, am i correct in assuming this?
          MySensors 2.1.1
          m26872M 1 Reply Last reply
          • S Samuel235
            m26872M
            m26872M
            m26872
            @samuel235 Yes.
            • m26872M m26872
              @samuel235 Yes.
              Samuel235
              #95
              @m26872 - Perfect. Thank you for your assistance, I really appreciate it! I'll get these ordered tonight hopefully and then keep looking at the circuitry for my RESET and DTR line to memorize it and work out why its so hard to get into my brain xD.
              Just one last confirm, since I'm not that confident with myself at the moment regarding this RESET line, if you don't mind.
              MySensors 2.1.1
              • S Samuel235
                m26872M
                m26872M
                m26872
                @samuel235 Reset and Dtr routing looks correct, but you still have DTR silkscreen label next to AVR ISP.
                • m26872M m26872
                  Samuel235
                  Indeed I do, the board itself isn't finished yet, I just wanted you to clarify the wiring was correct. Time to tidy it up, finish the annotating and get it finalized. However, thank you for pointing it out to me (Shows you're actually paying some attention to this). Thank you, yet again. The level of support and time you dedicate to helping others on here is outstanding. It is most certainly noticed!
                  MySensors 2.1.1
                  • S Samuel235
                    m26872M
                    m26872M
                    m26872
                    @samuel235 You're very welcome. We'll all benefit when you succeed.
                      Samuel235
                      UPDATE!
                      Revision 2 boards have now been submitted for manufacturing. Standard shipping used, so expecting within the next 23 days. This is going to pain me!
                      On the side note, I've enrolled for Open University and will be studying now for around 4 years. I'm doing a Computing and IT degree to follow on from my existing IT Qualifications (Microsoft and CompTIA). I do hope to incorperate this community and the projects i take on with you guys into my studying. I also do not expect this to effect the time and effort I'm able to spend with you guys here and developing our projects together.
                      I will update you ASAP, when these boards get here :)
                      MySensors 2.1.1
                        great :)
                          Samuel235
                          I will upload this device to Openhardware.io as soon as i have it built up and the basic functionality working. Hopefully then it will become much easier for the starting MySensor budding builders to understand and follow. I may do a 'basic build instructions' that can be followed on how to get this working, including putting the hardware together.
                          MySensors 2.1.1
                            Samuel235
                            Board Revision2 got delivered today and obviously i set about populating the board instantly!
                            I have the board all completed and now I'm attempting to burn the bootloader on. Before i go ahead and screw my IC up (I read if you use the wrong fuse reading for the timing of the clock you can't Re-burn anything else to it) i would like some advice. I've detected the current/pre-set fuse readings through AVRDUDESS using a clock speed of 93.75KHz, so i know the connection between my computer and the board is working. The readings for the fuses are below:
                            I'm currently using the fuse calculator here to workout the fuses needed. I'm also looking at Maniac's blog post here as he made a very low power module. The only thing i would question about his version/board is that his brownout is set to 2.7v. I've checked the nRF module and the lowest voltage it can go is 1.9, so maybe i should bring the BoD reading down even more or even disable it all together (I plan on reading the battery voltage from this module anyway).
                            The below settings for the fuses are my own workings out with the fuse calculator linked above, I'm doubting myself here, i'm in territory that i'm not comfortable with so I'm more than likely making a mistake here but what do you think? The BoD is set to 1.8 here:
                            Low: 0x62 | High: 0xD9 | Extended: 0xFE
                            Once i have confirmed a fuse setting, Do I edit them into the board.txt config of Maniac's blog post or do I use that of @tekka's?
                            MySensors 2.1.1
                            • m26872M
                              m26872M
                              m26872
                              I have a very brief guide here, under 'Software'. There are some links to other guides as well. I think you use (42, DE, 07/FF) together with that linked bootloader (important).
                              I also think Maniacs guide is a little old. You should get a a lot lower power by using MySensors lib and other some other tricks and settings.
                              • m26872M m26872
                                Samuel235
                                @m26872 From having a quick look at your guide, you bring your clock speed right down to 1MHz, am i correct in thinking this? Do you have any timing issues at all, is the node still quick enough to respond to switching and sensor detecting or is there a delay in the signal sending?
                                MySensors 2.1.1
                                • S Samuel235
                                  m26872M
                                  m26872M
                                  m26872
                                  @samuel235 Yes, it's working. But you can't use some things like DS18B20s and DHTs at these low frequencies. Si7021 etc are used instead. Button switches and other simple things are exellent applications.
                                  • m26872M m26872
                                    Samuel235
                                    #106
                                    @m26872 - Well, I was planning on maybe having a temp sensor in there at some point, but not this revision. So if i went without that function at the moment it wouldn't be the end of the world, i would just revise even more for the next revision. I'm presuming that you have taken it to 1MHz for power saving or?
                                    This is the configuration i'm thinking:
                                    ######## settings for 8Mhz internal clock
                                    proMYSBL8.upload.tool=avrdude
                                    proMYSBL8.upload.speed=57600
                                    proMYSBL8.bootloader.low_fuses=0x42
                                    proMYSBL8.bootloader.high_fuses=0xDE
                                    proMYSBL8.bootloader.extended_fuses=0xFF
                                    proMYSBL8.build.board=AVR_UNO
                                    proMYSBL8.build.core=arduino
                                    That would remove the brownout, enable SPI, and put the clock to 8MHz. What is your thoughts on this config?
                                    MySensors 2.1.1
                                    • S Samuel235
                                      m26872M
                                      m26872M
                                      m26872
                                      @samuel235
                                      • You'll need low MHz for ot to work when battery runs out and voltage decreases.
                                      • Those fuses are for 1MHz, not for 8MHz.
                                      • I've never used MYSBootloader. Someone else has to confirm the settings if you use this.
                                      • m26872M m26872
                                        @samuel235
                                        Samuel235
                                        @m26872
                                        Lower clock speed would last through the low power phase of the battery. Obviously, thank you for pointing that out! However, I'm looking at Maniacs battery testing graph and the battery is stable down to around 2.4v for around 150 hours, then it will rapidly drop off to 0v, so I'm thinking "is the lower clock speed really worth the extra 10 hours of use?".
                                        The fuses, although I am going off of what you suggested, i entered them into my fuse calculator and its showing up at 8MHz, with no modification needed to the speed.... I'm a little confused at this part as you have now said that those fuses are for 1MHz.
                                        I'm now wondering if its worth using MYSBootloader or the one you used, I can see that you used this and programmed through the Arduino IDE, from your post you said you're more comfortable with using the Arduino IDE (Which i am too, but can adapt if needed).
                                        MySensors 2.1.1
                                          #109
                                          @samuel235: don't worry about 1mhz...there is no big difference 1Mhz vs 8Mhz at 3V in deepsleep mode. In deepsleep mode, at 3V 8Mhz internal rc, you can get 140nA. So you can't have such interesting diff.
                                          In other hand, if node is wake up, you are in mA range, and here it can be interesting to play between clock and voltage ;) you can do it on the fly in sketch and it's good to know that for timing things, atmel clock and voltage are linked.
                                          So i would suggest you to stay with internal rc 8Mhz, BOD 1.8V and MYSBootloader. If I remember right it should be ok. Other thing good to know, you can disable BOD=0V when in deepsleepmode (this is done like this in lib I think), but it's not a good practice to disable it when wake up. Keep 1.8V limit, it can prevent some bugs..All is described in datasheet ;)
                                          Another thing good to know, as I see lot of peope estimation for coincell...there are lot of chance that you can't get the full coincell capacity, depending on the application, the use. A common "prevision is to plan 80% of its capacity. It's due to the rate of discharge of battery and coincell's one is small..
                                          There are lot of others resources on the subjects but here few links :
                                          https://www.dmcinfo.com/Portals/0/Blog Files/High pulse drain impact on CR2032 coin cell battery capacity.pdf
                                          http://www.embedded.com/electronics-blogs/break-points/4429960/How-much-energy-can-you-really-get-from-a-coin-cell-
                                          http://www.ti.com/lit/wp/swra349/swra349.pdf
                                          S m26872M 2 Replies Last reply
