  3. SenseBender, check wires
14 Posts 4 Posters 4.4k Views 4 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    @Sweebee
    I can't see the + in the picture, that validates it as a nrf24l01+ ?
    Check page 73 in the datasheet for the markings http://www.nordicsemi.com/eng/content/download/2726/34069/file/nRF24L01P_Product_Specification_1_0.pdf
    You could try disabling the + variant check in the Mysensors core
    https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/MyTransportNRF24.cpp#L35
    And perhaps set RF24_DATARATE to 1Mbit instead of 250Kbit (as 250kbit is only available on the + variant)
    • SweebeeS
      SweebeeS
      Sweebee
      I have used this nrf with other arduino's and there they work fine.
      This is a close-up picture: https://i.imgur.com/CLnR6p6.jpg
      • mfalkviddM
        The + is clearly visible on that picture so no need to reconfigure for the non-plus chip.
          @Sweebee
          Do you have a multimeter (with continuity test) to help you check that the NRF socket pins is connected with the MCU?
          SweebeeS 1 Reply Last reply
            @Sweebee
            SweebeeS
            SweebeeS
            Sweebee
            @hek yes, the sockets are fine. Maybe i have to measure directly between the atmega and the socket?
            hekH 1 Reply Last reply
            • SweebeeS Sweebee
              @Sweebee
              Yes
                @Sweebee
                Yes
                SweebeeS
                SweebeeS
                Sweebee
                wrote on last edited by Sweebee
                @hek Every nrf pin has a connection to the atmega. But is it normal that the VCC and CSI are connected to each other?
                I measured a mysensors pir and they don't have a connection to each other.
                tbowmoT 1 Reply Last reply
                • SweebeeS Sweebee
                  tbowmoT
                  tbowmoT
                  tbowmo
                  @Sweebee
                  There shouldn't be any short-circuit between any of the pins on the connector. Could you check the board for solder bridges?
                  • tbowmoT tbowmo
                    @Sweebee
                    SweebeeS
                    SweebeeS
                    Sweebee
                    @tbowmo Can't find any bridges. On the atmega it's hard to see, but the pins that are connected to each other aren't close to each other.
                    • tbowmoT
                      tbowmoT
                      tbowmo
                      @Sweebee
                      The short is between two adjacent pins in the header, it could be that it's the socket that has a defect.
                      Next step is therefore to remove the socket. Either by desoldering it as a whole unit, or break it apart and remove 1 leg at a time. But do be careful not to damage the pcb.
                      • tbowmoT tbowmo
                        @Sweebee
                        SweebeeS
                        SweebeeS
                        Sweebee
                        @tbowmo Got it! thanks. Stupid me. There was some lost soldering in the header.
