  3. SenseBender, check wires
14 Posts 4 Posters 4.2k Views 4 Watching
  • SweebeeS Offline
    SweebeeS Offline
    Sweebee
    wrote on last edited by Sweebee
    I attached the nrf to the sense bender but i get: check wires.
    Can't see whats wrong?
    https://i.imgur.com/WNLenAb.jpg
    https://i.imgur.com/nW5Jubw.jpg
    I tried 5 different nrfs
    • mfalkviddM Offline
      Looks to me like the NRF is without +. See discussion and instructions in http://forum.mysensors.org/topic/2891/nrf24l01-will-not-start
      • SweebeeS Offline
        SweebeeS Offline
        Sweebee
        I checked them, but they are all the + version nrf24l01+
        • T Offline
          T Offline
          tbowmo
          @Sweebee
          I can't see the + in the picture, that validates it as a nrf24l01+ ?
          Check page 73 in the datasheet for the markings http://www.nordicsemi.com/eng/content/download/2726/34069/file/nRF24L01P_Product_Specification_1_0.pdf
          You could try disabling the + variant check in the Mysensors core
          https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/MyTransportNRF24.cpp#L35
          And perhaps set RF24_DATARATE to 1Mbit instead of 250Kbit (as 250kbit is only available on the + variant)
          • SweebeeS Offline
            SweebeeS Offline
            Sweebee
            I have used this nrf with other arduino's and there they work fine.
            This is a close-up picture: https://i.imgur.com/CLnR6p6.jpg
              The + is clearly visible on that picture so no need to reconfigure for the non-plus chip.
              • hekH Offline
                hekH Offline
                @Sweebee
                Do you have a multimeter (with continuity test) to help you check that the NRF socket pins is connected with the MCU?
                SweebeeS 1 Reply Last reply
                  @Sweebee
                  SweebeeS Offline
                  SweebeeS Offline
                  Sweebee
                  @hek yes, the sockets are fine. Maybe i have to measure directly between the atmega and the socket?
                  hekH 1 Reply Last reply
                  • SweebeeS Sweebee
                    hekH Offline
                    hekH Offline
                    @Sweebee
                    Yes
                      @Sweebee
                      Yes
                      SweebeeS Offline
                      SweebeeS Offline
                      Sweebee
                      @hek Every nrf pin has a connection to the atmega. But is it normal that the VCC and CSI are connected to each other?
                      I measured a mysensors pir and they don't have a connection to each other.
                      • SweebeeS Sweebee
                        T Offline
                        T Offline
                        tbowmo
                        @Sweebee
                        There shouldn't be any short-circuit between any of the pins on the connector. Could you check the board for solder bridges?
                        • T tbowmo
                          @Sweebee
                          SweebeeS Offline
                          SweebeeS Offline
                          Sweebee
                          @tbowmo Can't find any bridges. On the atmega it's hard to see, but the pins that are connected to each other aren't close to each other.
                          • T Offline
                            T Offline
                            tbowmo
                            @Sweebee
                            The short is between two adjacent pins in the header, it could be that it's the socket that has a defect.
                            Next step is therefore to remove the socket. Either by desoldering it as a whole unit, or break it apart and remove 1 leg at a time. But do be careful not to damage the pcb.
                            • T tbowmo
                              @Sweebee
                              SweebeeS Offline
                              SweebeeS Offline
                              Sweebee
                              @tbowmo Got it! thanks. Stupid me. There was some lost soldering in the header.
