  3. Motion sensor withput the interrupt
8 Posts 5 Posters 3.5k Views 1 Watching
  • ferpandoF
    ferpandoF
    ferpando
    I'm planning on building a node with motion sensor, light detector and a dimmer.
    For it to work, I guess I can't have the node to sleep, so it will be able to receive command from the gateway.
    So my question is how to adapt the motion sensor sketch to not use the interrupt.
    Would something like this work?
    boolean tripped = digitalRead(DIGITAL_INPUT_SENSOR)
    if(tripped== HIGH) sendTripped();
    //send light level if changed
    //dimmer control code
    function sendTripped()
    Serial.println(tripped);
    gw.sendVariable(CHILD_ID, V_TRIPPED, "1");
    • JohnJ
      JohnJ
      John
      The above should work, but i would also set an extra variable to check if there has been no movement at first. Otherwise it could continuously send movement.
      Just as example:
      boolean tripped = false;
      boolean prevTripped = false;
          tripped = (digitalRead(DIGITAL_INPUT_SENSOR)==HIGH)?true:false;
          //// Only send when there has been no movement first.
          if(tripped==true and prevTripped==false) {
             sendTripped();
          prevTripped = tripped;
      ferpandoF 1 Reply Last reply
      • ferpandoF ferpando
        @ferpando You can just leave the interrupt in. It will no longer wake the Arduino from sleep (as it won't be sleeping) but the interrupt will still be handled on motion!
        • ferpandoF
          ferpandoF
          ferpando
          Yes I thought so, but also thought the interrupt could mess with the rest of the sketch?
          If the node receives a message from gateway and an interrupt happens, how would it behave?
          JohnJ 1 Reply Last reply
          • JohnJ John
            Just as example:
                   sendTripped();
            ferpandoF
            ferpandoF
            ferpando
            @John
            It was just a quick proof of concept.. I guess I should set tripped to false once the message is sent
            Z 1 Reply Last reply
              JohnJ
              JohnJ
              John
              @ferpando
              I asked almost the same question in an other thread, and i got the answer it is not interrupt save... I can not exactly say how it would behave.
              • NuubiN
                NuubiN
                Nuubi
                Out of curiosity...how did you solve this?
                  @John
                  Z
                  Z
                  Zeph
                  wrote on last edited by Zeph
                  I think you are on the right track. There' s no need for the interrupt in your case. So you don't have to worry about what process is being interrupted.
                  John had the right logic. You don't want to set tripped false until the input (ie: motion dectector output) goes false, not when a message is sent.
                  His suggested logic sends one message whenever the motion detector goes active, and not again until it goes inactive and active again.
                  (Which happens after no motion for some time period adjustable via a pot on the motion detector).
                  12.5k
