  3. Adafruit CC33000 WifiGateway
10 Posts 2 Posters 4.3k Views 2 Watching
  • C
    C
    Connor Rigby
    Hello i don't know if this has been done before but i just wanted to throw my project out there. It isnt commented very well and im sorry but most of it comes from the Ethernet Gateway code anyway so i think it is easy enough to figure out.
    anyway here it is. Wiring is fairly simple, wire spi lines in paralles, then just follow the d#defines.
    https://github.com/pressy4pie/wifigateway/tree/master
    • C
      C
      Connor Rigby
      Also just a note it hits 98% of memory on an UNO. So any further revisions are almost garanteed to need a mega or similar.
      barduinoB 1 Reply Last reply
      • C Connor Rigby
        barduinoB
        barduinoB
        barduino
        wrote on last edited by barduino
        @Connor-Rigby very interesting.
        A good candidate to port to 1.6, if you're interested check this out http://forum.mysensors.org/topic/2709/mysensors-wifi-gateway-with-arduino-uno-and-cc3000
        Thanks for sharing
        • C
          C
          Connor Rigby
          wrote on last edited by Connor Rigby
          I haven't updated to 1.6 yet but I'll try it out tomorrow. Right now it needs a bit of self healing stuff in the actual loop itself. I had to remove some of the original Ethernet gateway code that should be added back. This was more of proof of concept. It does work but after the connection drops for any reason its hard to get it running again without resetting both the controller and the gateway.
          Edit: im using the development branch at mysensors now so if anyone wants to try it out, check here
          • C
            C
            Connor Rigby
            Bump check the edit on the last post
            barduinoB 2 Replies Last reply
            • C Connor Rigby
              barduinoB
              barduinoB
              barduino
              Hey @Connor-Rigby
              I will try it for sure.
              But one question when I go to https://github.com/PressY4EKG/Arduino/blob/2177387fc4f388de02f60cd4698f62e4a200fefe/libraries/MySensors/core/MyHwCC3000.cpp
              Its empty...
              Does this mean you're using the CC3000 libraries directly?
              C 1 Reply Last reply
              • C Connor Rigby
                barduinoB
                barduinoB
                barduino
                Hey @Connor-Rigby
                Here are my findings...
                Compilation perfect, no issues.
                The changes to the gateway example I used were just pin configurations:
                #define MY_RF24_CE_PIN 9
                #define MY_RF24_CS_PIN 10
                #define MY_RF24_CHANNEL  111
                #define MY_CC3000_CS 8
                #define MY_CC3000_VBAT 5
                #define MY_CC3000_IRQ 3
                It starts up like this:
                255;3;0;9;Starting gateway (RNNGA-, 2.0.0-beta)
                Starting WiFi
                CC3000 Started
                Connected
                Got IP
                All good.
                I wanted to tell me what was my IP address so I've added these lines to the MyGatewayTransportEthernet.ccp
                MY_SERIALDEVICE.print(F("\nIP Addr: ")); cc3000.printIPdotsRev(ipAddress);
                MY_SERIALDEVICE.print(F("\nNetmask: ")); cc3000.printIPdotsRev(netmask);
                MY_SERIALDEVICE.print(F("\nGateway: ")); cc3000.printIPdotsRev(gateway);
                MY_SERIALDEVICE.print(F("\nDHCPsrv: ")); cc3000.printIPdotsRev(dhcpserv);
                MY_SERIALDEVICE.print(F("\nDNSserv: ")); cc3000.printIPdotsRev(dnsserv);
                MY_SERIALDEVICE.println();
                But the results were not what I expected
                Starting WiFi
                CC3000 Started
                Connected
                Got IP
                IP Addr: 8.0.0.1
                Netmask: 0.255.252.225
                Gateway: 168.1.6.0
                DHCPsrv: 0.0.168.168
                DNSserv: 225.252.255.115
                Strange...
                Any way I've fixed the ip address on my router
                0_1454263821040_upload-af65d368-3fba-4abc-897e-ff9cd3b6d411
                and can ping it from a terminal
                RVB:~ rvb$ ping 10.0.0.7
                PING 10.0.0.7 (10.0.0.7): 56 data bytes
                64 bytes from 10.0.0.7: icmp_seq=0 ttl=64 time=4.674 ms
                64 bytes from 10.0.0.7: icmp_seq=1 ttl=64 time=19.361 ms
                64 bytes from 10.0.0.7: icmp_seq=2 ttl=64 time=4.335 ms
                64 bytes from 10.0.0.7: icmp_seq=3 ttl=64 time=9.256 ms
                64 bytes from 10.0.0.7: icmp_seq=4 ttl=64 time=7.163 ms
                64 bytes from 10.0.0.7: icmp_seq=5 ttl=64 time=10.054 ms
                64 bytes from 10.0.0.7: icmp_seq=6 ttl=64 time=24.724 ms
                64 bytes from 10.0.0.7: icmp_seq=7 ttl=64 time=4.882 ms
                ^C
                --- 10.0.0.7 ping statistics ---
                8 packets transmitted, 8 packets received, 0.0% packet loss
                round-trip min/avg/max/stddev = 4.335/10.556/24.724/7.046 ms
                I'm also able to send commands via MYSController
                0_1454263909893_upload-5f627acc-db71-4c57-a234-60cf066bfcf9
                0;255;3;0;9;Eth: connect
                0;255;3;0;9;Eth: 0;0;1;0;0;123
                0;255;3;0;9;Eth: 0;0;1;0;0;456
                0;255;3;0;9;Eth: 0;0;1;0;0;789
                So Kudos Mr. @Connor-Rigby you did it, excellent work!!
                And since we love pictures...
                • barduinoB barduino
                  Hey @Connor-Rigby
                  Its empty...
                  C
                  C
                  Connor Rigby
                  @barduino said:
                  Hey @Connor-Rigby
                  Its empty...
                  Yeah it is. i was going to dump the code into that file and header but i decided to just usee the library.
                  @barduino said:
                  Hey @Connor-Rigby
                  Starting WiFi
                  CC3000 Started
                  Connected
                  Got IP
                  All good.
                  Starting WiFi
                  CC3000 Started
                  Connected
                  Got IP
                  IP Addr: 8.0.0.1
                  Gateway: 168.1.6.0
                  Strange...
                  ^C
                  yeah the cc3000 handles all that information weird. on monday ill try to get that going. i decided i wasnt actually going to use this on my project anyway.
                  • C Connor Rigby
                    @barduino said:
                    Hey @Connor-Rigby
                    Its empty...
                    @barduino said:
                    Hey @Connor-Rigby
                    Starting WiFi
                    CC3000 Started
                    Connected
                    Got IP
                    All good.
                    Starting WiFi
                    CC3000 Started
                    Connected
                    Got IP
                    IP Addr: 8.0.0.1
                    Gateway: 168.1.6.0
                    Strange...
                    ^C
                    barduinoB
                    barduinoB
                    barduino
                    @Connor-Rigby
                    I can try to give it a shot.
                    My objective is the MQTTGateway but with what you've done so far I think I can try to tackle it.
                    It would be interesting to add this to the development branch I wonder what @hek and the MySensors folks think about that possibility
                      @Connor-Rigby
                      C
                      C
                      Connor Rigby
                      @barduino
                      i made a pull request for the development branch but they want me to change a couple more things before they merge it. I just havent got around to it yet. Ive never messed with the mqtt gateway nor do i really even know what it is but let me know if i can help you out
